Question about Air Tools & Compressors
Cambell hausfeld lt500802 compressor transfuer tube leaks
Needs copper or aluminum tube also check valve
Editor925
  • 285 Answers
SOURCE: Cambell Hausfeld FP2028 Compressor - What is the regulator knob?
It is generally above the air outlet where the hose connects?
Posted on Mar 01, 2009
digritz
  • 530 Answers
SOURCE: need to find out how to replace belt on WL65
Not sure how easy it will be to locate repair instructions if they are not in your manual. However maybe the diagram of the pump is all you need. Just click on the first link below. It will open up the pump diagram. #14 is the belt.
I also included the link to the site where you can get a look a at the parts list and order parts for your compressor.
Hope something here helps.
If not please let me know and I'll try and describe the proccess for the belt remove to you.
Pump diagram:
http://www.mastertoolrepair.com/images/WL390100-Pump.jpg
Compressor diagram and parts list:
http://www.mastertoolrepair.com/wl650003-wl650102-wl650102aj-wl650202-wl650601-p-28707.html
Pump parts list:
http://www.mastertoolrepair.com/wl390100-p-17694.html
Posted on Nov 20, 2009
rogrrabbit
  • 986 Answers
SOURCE: Air compressor's safety release valve pops open.
You need to replace the pop it valve with a preset on. they are cheap and readily available. You could adjust yours with a proper steup. But it may need new parts just replace it.
Posted on Nov 28, 2009
  • 760 Answers
SOURCE: leaking air
When the Pressure switch shuts off, the little air valve in the pressure switch vents the copper line from the compressor, to blead the pressure from the compressor so it's easier to start the next time. If it continues to leak, the check valve between compressor and tank must not be holding.
Posted on Jul 17, 2010
puertobori
  • 7733 Answers
SOURCE: I need a service manual for cambell-hausfeld model
Search for Campbell Hausfeld Product Manuals
Posted on Nov 02, 2010
Campbell hausfeld wl600701an starts fine when you use it and pressure drops it tryies to star and kemicms breaker I seen are it said it ha a one way chem vlve that will cause thus are is it loated
I think you are asking where is the check valve or one way valve. There is a copper tube that takes the air from the cylinder head of the pump to the tank - the check valve is combined with the fitting that attaches that tube to the tank.Most of it actually stickes inside the tank.
Nov 29, 2016 | Campbell Hausfeld Air Tools & Compressors
Similar to another persons question...have a circa 1995 cambell hausfeld piston type compressor, has been great for past 17 years. it was building pressure, albeit the source at the tire fitting...
Woody:
Your compressor is losing pressure somewhere... check both ends of the air tube between the compressor head and the tank. The loud pop may have been the packing at one end or the other. You'll have to remove the head again to remove the air tube, but I believe your problem is the pressure seal at one end of the tube or the other.
Mar 11, 2013 | Air Tools & Compressors
My Campbell Hausfeld compressor model WL650101AJ will only pump to 80psi and will not shut off.
TAKE THE COVER OF THE TOP HAS 2 PHILLIPS SCREWS AND SNAPS OFF. THERE IS A COPPER TUBE THAT GOES BETWEEN THE COMPRESSOR HEAD AND THE CHECK VALVE TAKE THE TUBE COMPRESSION NUTS LOOSE AND REMOVE THE TUBE. CHECK THE RUBBER SEALS IF THEY ARE MISSING OR TORN YOUR COMPRESSOR LEAKS WHEN IT IS RUNNING BUT IF YOU SHUT IT OF THERE IS NO AIR IN THE PIPE SO CHECKING IT WITH IT OF WONT DETECT THE LEAK. MY COMPRESSOR WAS DOING THE SAME THING AN THIS FIXED IT.
Jan 26, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
When my compressor turns off air starts to come out somewhere around the on and off switch.
If the air leak lasts for about five to ten seconds, it's supposed to do that. It's releasing the pressure in the pump head so it can start up again. If it never stops, your check valve is not working correctly. Follow the main air line, usually a copper tube to where it goes into the tank. The large brass fitting it goes into is the check valve. There should also be a black line running from the check valve to the pressure switch. You have to remove the black airline and copper tube to remove the check valve. If there is something stuck in the valve it may be useable if you can clear it out. If the valve or valve seat is damaged or the spring is broken, replace it.
Jan 21, 2011 | Campbell Hausfeld Air Tools & Compressors
Nov 28, 2009 | Northstar Electric Stationary Air...
I accidently punctured a hole in a cooling tube in a small kenmore fridge freezer and lost all the coolant.. i have since repaired the hole but can't seem to find the fitting on the compressor to recharge...
If you punctured the aluminum tubing or the freezer aluminum evaporator , it cannot be repaired . If the puncture is in the copper tubing , only silver solder will fix . On the compressor , you will see a short piece of tubing , capped off . This is where the access fitting was . A good technician will ALWAYS remove the access valve , due to possible refrigerant leak . After removing the end of the tube , silver solder another valve into the tubing . Evacuate the system , recharge with correct amount of refrigerant , crimp the tubing at the access valve and remove the access valve . Re-solder the end of the short tubing , and it's done .
Oct 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hose from compressor to air tank
Campbell hausfeld parts are available at www.chpower.com, however, you can use standard parts like copper tube or rubber pressure hose available at Lowes lumber or True Value Hardware. Check for cause of failure of the airline, could be from vibration due to loose motor mount or faulty check valve at tank causing back pressure. Enjoy
Dec 09, 2008 | Campbell Hausfeld 13 - Gallon Air...
Cambell/hausfeld air compressor model# wl650102aj air compressor
Well currently dealing with a similar situatio with a Wl650102aj CH ocmpressor, in my case it was that factory bend copper tube that runs from the motor into the check valve on the tank, it was cracked, havn't been able to find a replacement yet, and bending your own will not work... as they must be stamped out, there is no way to really get that particular bend in them.
So that may not be your case, but I would be willing to bet if it's not pressuring up and the check valve is good, and your manifold isn't leaking... that your having the same problem
-rk
Dec 03, 2007 | Air Purifiers
Air Tools & Compressors Logo
53 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
