Question about Microsoft Xbox 360 Console
Broken usb port smashed prongs wont even come on
I pullled out the play anfd charge kit on my xbox 360 and when i did it pulled the black piece out and also bent th prongs how do i fix it. help PLEASE!!!!!!
  • Anonymous Feb 17, 2009
    the usb connector is stuck in my controler usb/ the connector pulled out when i pulled my controlor out.
    Problem Solver:
  • 5 Answers
Un bend it
Posted on Jan 18, 2009
Xbox 360 wont charge play and charge kit
First thing to do is check your USB ports on the console. Plug in a flash drive or anything into all 3 USB ports to test them. If they all work you have eliminated the console as the source of the problem.
Alternatively, if you believe it may be the play and charge kit itself, simply plug it into any usb on any pc with a controller attached. If the red charging light turns on, it is working properly.
If both check out it simply means it's time to replace the battery pack in the controller. They have a life cycle depending on usage, and they vary greatly.
Dec 23, 2009 | Microsoft Xbox 360 Console
No sign of life on switching on
Ceck to see if the USB's is all ok. I fixed a friends his showing same symptoms and one of the USB was broken and the prongs were tou=ching causing a surge to go through it., just move the prongs so they are not touching put a piece of tape over the usb so you wont use it again
Oct 21, 2009 | Microsoft Xbox 360 Console
My xbox 360 play and charge usb wont work
My Play and Charge Kit won't work for my Xbox 360 and it doesnt charge the controller How do I fix it?
Jun 27, 2009 | Video Game Consoles & Games
Help Microsoft Xbox 360 Wireless Receiver For Windows, help help
Hello my name is Tim Ehrhart, If the reciever is not lighting up then it is dead, you can try to take it to walmart and exchange it for a working one, they are usualy good at swapping out and if they give you a hard time buy a new one and return it with the old reciever instead of the new one. I hope this helps you.
Mar 11, 2009 | Microsoft Xbox 360 Wireless Controller
Assembling the play and charge kit
The wire piece connects to the top of the controller. Align it so the light is on the front, and press straight down until it snaps into place. Connect the other (smaller) end to your console.
Jan 10, 2009 | Microsoft Xbox 360 Wireless Controller and...
Microsoft Xbox 360 Wireless Controller for Windows
HI perform a system restore to before you installed the drivers
(start,Run System restore)
then reinstall them
should work :)
please rate .
Dec 17, 2008 | Microsoft Wireless Receiver For Xbox 360
Front usb port of xbox looks broken, unit does nothing now
Simple. Just solved it with advice from this site. If you see any of the gold prongs touching the side (or possibly each other) then find a thing tool and try to hook the gold prongs so they point direct upwards. how bad they get bent doesnt matter, just get them all standing up and not touching the sides. you probably cant use the port again but atleast it turns on.
Oct 16, 2008 | Microsoft Xbox 360 Console
My xbox won't turn on
hey guys i was freakin out because i had that same problem.  i didnt want to pay an extra 1000$ just because the stupid repair guys wouldnt tell me the answer.  So look inside your broken usb port, there should be like golden prongs in there.  if they are bent, straighten them and you can turn your xbox back on.  Now this might not be the case with you, but that is how i just solved my problem.  if you have any questions ill try to keep posted and see if i can help further. also you can get me at my gamertag for xbox live.  its volcomxskater37
Jul 05, 2008 | Microsoft Xbox 360 Console
My xbox 360 won't turn on!!!
yo i tried everything and it turned out to be what one dude on her said about the usb ....if u look close in the usb port ...ther is 4 things sticking out ..in one port they were all straight ...in the other port they were crushed up against the wall so i took a knife and smashed them back down away from the wall make sure they are pointed down AWAY from the walll i cant plug a controller in that port but i can the other port.....soooooooooooooooooo it dont matter and bammmmmmmmmmmmm it came on i started **** in front of everyone
May 10, 2008 | Microsoft Xbox 360 Console
Xbox 360 controller stopped working
I have the issue mostly when the batteries are about to die, Try changing the batteries, or if you are using a play and charge kit (sold seprately) connect it to your xbox 360 and one of the front usb ports. Or replace the rechargeable battery.
Apr 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
452 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
