Question about LG 24 in. LDS 5811 Built-in Dishwasher
Does the LG Ld1452WFEN2 dishwasher need a pressure reducer on the inlet hose or is it incorporated in the hose
New dishwasher requires .6mpa max inlet pressure. Washer is on tank water with 15BAR pump fitted and occassionally on mains pressure when tank is low.
SOURCE: IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Posted on May 06, 2007
rickzilla
  • 706 Answers
SOURCE: LG LD-14AW3 Dishwasher leaking after cycle
Sounds like you've diagnosed the solution on your own.. Most of the inlet valves are spring loaded so that if power is removed or disabled.. it defaults to a closed state and doesn't allow water int the wash basin. To open, they need to be energized by the control system so you may have one of two issues.. a faulty inlet valve that doesn't spring closed when it is not energized or a controller that is comanding that valve to open ( less likely of the two) For a quick test.. make sure the DW is dry inside and open the door. wait and watch for water to enter the basin.. If it does begin to fill up.. your inlet valve could be the root of your problem.. It is also possible that you are back-siphoning waste water in from the drain system. If the water looks dirty then that is more than likely the problem so you may have a clogged pump, kinked drain hose or your drain system itself is not draining as fast as the DW pump forces the water out.
You should routinely clean the pump filter so that the pump can remove all the wash water without having to draw it thru food debris caught in the filter.. Hope someof these ideas will help you solve your problem..
Posted on Sep 01, 2008
MNTECH
  • 1543 Answers
SOURCE: IE input error on LG dishwasher Model LDF6810ST
Chris;
The float you speak of is located behind the left side panel. (be careful if you remove the panel, the back edge is real sharp,.... I left a pint of blood at one house !) Water enters the dishwasher fill assembly and turns a paddle wheel, which allows the control to count the revolutions, determining the amount of water filling into the dishwasher. The float is inside a chamber in front of (and attached to) that water guide and it has two micro switches at the top of the float chamber. If I recall correctly, the float is only for overfill protection, as the paddle wheel determines water amount. You should check the screen at the water valve to make sure nothing is obstructing inlet valve water flow. Also, make sure you are not using a "flood safe" inlet hose, which are designed to shut off water if a hose breaks (but can cause water supply issues). You may have a bad control board or wiring connection. On a new unit I would suggest calling for warranty service.
Please don't rate this solution, as anything but a FixYa will lower my score.
Thanks, Carl.
Posted on Nov 20, 2008
  • 110 Answers
SOURCE: E1 error on LG dishwasher
As per my email reply chazmano5, the problem is likely to be the water pump/motor assy.
They have a very common fault of the impeller breaking on the motor shaft. The motor still spins, but the impeller doesn't, so there is no water being pumped.
The machine senses there is no water pressure and shuts down, displaying E1 (eg: it thinks no water pressure means there must be a water leak) Unfortunately the motor/impeller is only available as a complete assembly.
Posted on Dec 11, 2008
SOURCE: LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Posted on Apr 06, 2009
My bosch wfl 2400 does not wash, it starts by letting a bit of water come in, then stops. I can drain the water out, ok. But nothing more
Have you tried altering the inlet water pressure? Where the water inlet hose of the machine is attached to the water supply of the house, do you have an isolating valve. If so then shut it part way off to reduce the water pressure entering the machine. If it is already set at a reduced input, then open it to see if that helps. You may need to try several different settings, so be patient.
If altering the water inlet pressures does not work and you are still having the same problems then the machine will require an expert to fix it. It could be a program error and requires a new circuit board or the water inlet sensor may be faulty. Hope that is of some help and good luck.
Nov 20, 2015 | Bosch Washing Machines
Dishwasher will not fill with water
depending on the make and model of dishwasher the solution can vary. A good guess (assuming the inlet hose is connected and tap is turned on), is the water pressure setting may not be matching with your normal mains pressure. Check installation instructions for setting mains water pressure. Also some dishwashers like Bosch have special inlet hoses which detect water leakage and shut of the water inlet valve. Need to check if your dishwasher has got this feature and need to confirm the hose is correctly fitted.
More importantly check when you turn wash cycle on if you hear click of the inlet valve or not.
Dec 29, 2012 | Dishwashers
Model LD 12AW2 not drawing water displaying 1E error
Hi afarugia,
The IE error you are seeing means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame - Please check the following:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Straighten it.
- Is the Inlet hose filter (Found when unscrewing the hose form the inlet on the machine) dirty? Clean it.
- Is the tap completely open? (Low pressure)
- Has your home gone under any plumbing alterations? (This could have also caused low water pressure - Too little water)
If all of these come back OK, and it still gives the same problem, I'd suggest replacing the inlet valve (Found on the opposite side of the inlet pipe - inside your Dishwasher), could also be a pressure switch (Found at the bottom of your Dishwasher - accessible from the bottom).
This should solve any problems.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful - please rate it
Jul 10, 2011 | LG Dishwashers
Gets a 1E code. already checked water is on
Hi shadyron11,
Kind Regards :-)
Jedemeyer1
Jul 08, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
Displaying code IE
Hi jakkirker,
Kind Regards :-)
Jedemeyer1
Jun 15, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
My lg ld 1403w1 dishwasher fills with water and then error code I.E appears have bailed out water and tried it three times same result
Hi june1245,
I.E means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame (varies on model) - Make sure of the following first:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Un-kink it.
Kind Regards :-)
Jedemeyer1
Jun 06, 2011 | LG Dishwashers
LG LD2131SH Dishwasher displays a ie error
Hi santjiesfras,
The error code your receiving is an "Inlet Error" message. This means that no water is going into the Dishwasher. Please check the following:
1) Is the tap open.
2) Is the inlet hose kinked?
3) Is your water pressure fine? Because anything less than 0.3kgf/cm(bar) is not going to work
If all of the above is fine, then take off the inlet hose of the dishwasher, and clean the filter which is between the hose and machine (small circular filter). If still not working, then you will need to replace the inlet valve. I would suggest getting a L.G service agent to do so.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Apr 13, 2011 | Dishwashers
Bosch SRS4302GB Replacement Inlet hose - which type?
it should have and is delivered with the narrow bore high pressure hose
if your water flow rate is high more than 20 ltrs p min you could get away with a standard low preessure hose
you can download the instruction manual from the bosch web site or from the bsh home appliances web site
good luck
Mar 06, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
LG Dishwasher
Had a similiar problem I tried reducing water pressure from water inlet (external to dishwasher) and this worked to a certain degree, although may result in being unable to fill, if you turn down too far. Water silencer (try plumbing stores) was fitted between mains and dishwasher and this fixed the problem.<!-- from fixya rte -->
May 16, 2008 | Dishwashers
Portable dishwasher
The first thing you might want to do is check the water pressure in the house. Ideal water pressure should be from 55psi to 75psi max. I have seen homes that had pressure around 125 psi which will cause pressure leaks in water heaters, softners, washer valves, r/o systems. Check to see that all, if any inlet screens are clear and free from any grit and sand. It's possible that your inlet water valve (wd10m0010) has become restricted. Other than that, the complete uncoupler hose assy. part number is wd24m0030. These parts are for the dishwasher model ending in gsc3400j00bb. They are the same for model number ending in 00ww. Good luck.
May 07, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
161 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
