Question about GE Profile JT952 Electric Double Oven
Installing ge profile double oven not convection in new build trying to find out electrical requirements ( size breaker 50,60amp ?)
  • 8,197 Answers
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Posted on Jan 18, 2009
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
How to install GE JKP35DPBB 27" Double Electric
The specs for this double oven give a rating of 5.1kW at 208V so it needs a 30 Amp circuit breaker. This assumes that the oven is the only appliance on the circuit. So you should be able to use the same circuit breaker.
A bigger consideration is that the opening for the double oven needs to be larger than that of the single oven. If the opening does not have a solid bottom, it must be able to support a heavier load. The runners and braces under a single oven has to support 200 pounds (91 kg). A double oven must have braces and runners designed to hold 375 pounds (171 kg).
Also check if your household uses aluminum wiring. The new oven has copper and problems will occur at the interface if you do not use the appropriate precautions. (Products designed for mating copper and aluminum are available - follow the directions).
I hope this helps.
(btw: you can find the User's Guide and Installation manual for the double oven at GE's website: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JKP35DPBB . See the section Literature and Manuals on the left hand side of the page below the picture of the oven.)
Oct 29, 2010 | GE 27" Built-In Double Electric Convection...
I Lost the instructions for my GE profile Oven probe. Need advic
I need oven probe instruction and oven conversion time with the convection oven for cooking a forty pound turkey.
Nov 25, 2009 | GE Profile JT952 Electric Double Oven
What is blue wire on ge built in oven for
The blue wire goes to a seperate 15 Amp circuit breaker or fuse.
This breaker should be powered by the L1 (black) supply feed in the breaker box. The circuit supplies power to the display and control buttons. The red and black wires go to a double ganged 20 Amp breaker. Check inside the oven back cover for a wiring diagram.
Sep 07, 2009 | GE Profile 30" Built-In Single Electric...
Breaker sizw
In most cases look on the model number tag, the one with the serial number on it and in most cases it will tell you what amperage breaker you should run it off of. It could be a 30 amp 40 amp or 50 amp 220 breaker.
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Fuse location
are you talking about the breakers that are outside or in the garage? Look where the main power goes into the building and there is where the breaker for the oven should be.
Dec 24, 2008 | GE Profile JT952 Electric Double Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Jkp56T
The relays are soldered to the printed circuit. You would need to find a relay and then unsolder the old one and resolder the new one. This requires special skill. I would not recommend it unless you are comfortable with printed circuits.
An alternative would be to contact CG Industries at www.cgiltd.com.
They repair applicance electronic components.
Good Luck,
Powerman
Feb 22, 2008 | GE Profile JKP56 Electric Double Oven
Ge profile double wall convection oven
My solution for the F7 problem may work for you. It won't cost you anything to try it. It is simple and free. You can find it at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
Please let me know if this works for you. You can email me at:
hutchipop@yahoo.com
Good Luck,
Powerman
Feb 03, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JT952 Electric Double Oven Logo
519 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
