Tivo set me up with a random code to get the remote working only w/o mute. After a few days volume stopped working and the sound/picture had a delay. On/Off also not working as well as the control buttons on the tv itself.
SOURCE: Controls Don't Work
I have this EXACT SAME problem with my Insignia 26" LCD TV. I was three weeks out of warranty when it happened and Insignia wouldn't do anything to help me. I brought it to three repair shops and each repairman said that they couldn't guarantee they could fix it even IF they got the right parts. Anyhow, the TV repairman had it for three months (getting parts shipped from Asia, repair time, etc.) and he couldn't fix it. He also told me that tons of other people have the issue and that Insignia is replacing their TVs under warranty. So, if your TV is still under warranty, call Insignia. You just have to pay for shipping and shipping insurance. Hope this helps!
SOURCE: LG 37LC7D remote doesn't work
I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
SOURCE: My New LG LED TV
you can down load your manual from this link, i did notice that your product number is not listed in full or has been removed . if you add 00 at the end you will still be able to receive a manuel with instrustions for the remote and resetting.
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1) From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Push the TiVo button on the remote. Then push "Messages and Settings," followed by "Settings," and finally press "Remote Control." This will show you the three areas of the remote that are programmable. "TV Power, Volume and Mute," is one section. "AV Volume and Mute," is the second section. The final section is "TV Input."
Pick "TV Power, Volume, and Mute" by pushing right on the direction pad of the remote. This will open up a list of all the brand names of TV that exist. You will find most TV brands will be there.
Find your brand of television and select that option. If your brand is not there, simply go to the TiVo webpage and under "Setup and Support" you will find others who have experience this issue. There you will find a code for your TV. This happens sometimes when the TV is a lesser known brand.
Hold down the button you are programming (i.e. TV Power) for 5 seconds until the red light on top stays on. Then enter one of the codes on the screen.
Push the newly programmable button to test its functionality. If it does not work, repeat the steps with all the possible codes available. One of the codes will work.
Push "Live TV" at this point to watch television.
Use the manual which came with your TiVo in addition to this guide. In the front of the booklet will be a starter guide, which will lead you through the steps necessary to set up your remote for optimum use.
