Question about Panasonic CS-S9NKUW-1 Multi-System Wall-Mount Ductless A/C
Panasonic split type aircon timer keeps on blinking
4 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: airswing function not working on panasonic aircon
Remove side screws and pull out the PCB compartment, and check wiring to swing motor. Most of the time, the clip would have been removed on transportation or during service time. If connection is good, replace swing motor. Thanks.
Posted on Feb 05, 2011
  • 4736 Answers
SOURCE: Hi, I have a Panasonic split
A fairly quick solution is to turn the unit OFF & unplug it for 15 - 20 minutes. Once the time has elapsed, plug the unit back in & turn the ON/OFF Switch to ON. During that time out, the electronics should have reset and reverted back to the original factory settings. You should now be able to set the controls as you like.
Hope this helps and thanks for Choosing FixYa.
Posted on Aug 24, 2011
SOURCE: my panasonic ceiling aircon model cs-d24db4h5-1 timer light on and not cold.
is your filter dirty? i could see it stoping if the filters dirty. check the filter and if that is not it take it into a shop or send it in. if it cost's more to fix it just forget about it and get a new one good luck.
Posted on Jun 24, 2012
Timer of my panasonic inverter ac is blinking n aircon is not getting on. how do i resolve it
Unplug the power cord or if you are unable to turn off power that way, use fuse box and leave power off for 20 minutes. This should enable the system to reset to default settings and you can then set system to your needs.
May 06, 2016 | Panasonic Heating & Cooling
My air con just suddenly stop blowing air and the timer button just starts blinking. every time i switch on the aircon it will auto shut down and the timer button lights up please help me to fix it.
Owner's manual? troubleshooting? Possible it's smart enough to know you have an air filter that needs changing or cleaning.
No manual? Try MFG web site, or email their customer service, or try manualslib.com
Apr 02, 2015 | Panasonic Heating & Cooling
Panasonic cs e9nkr aircon. Shuts down timer continuously blinks. Checked for fault codes h00
I haven't got the service manual for this but the error codes should be on a sticker behind the front cover. Take that of and it will guide you to the fault.
Feb 19, 2015 | Panasonic Heating & Cooling
Panasonic A75C559 remote has timer blinking on 12:00, aircon unit is not working at all.
Try pressing the manual start button on the front panel near the electrical cover on the right hand side under the filter cover. If it starts and cools after a few minutes, you probably have a faulty remote.
Jan 18, 2015 | Panasonic Heating & Cooling
LG aircon operation flashes blinking light 8 times and then shifts to timer light flashes blinking light 4 times
Sounds like a 48 code. (There is no 84 to my knowledge).
Outdoor unit coil outlet (liquid line) thermistor has disconnected or has shorted out.
call a LICENSED hvac repairman
Apr 21, 2014 | LG LS-L1210CL Mini Split Air Conditioner
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Not turning on
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If it wont work replace your Room Air and Coil Thersmistor or test the thersmistor with mulitester. The resistance reading of thermistor is 10 kilo ohms @25deg. C room temp. If it is shorted or open the unit wont operate.
Hope this can help :)
Dec 30, 2008 | Carrier 36KCARMS Air Conditioner
Panasonic CS-S9NKUW-1 Multi-System Wall-Mount Ductless A/C Logo
37 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
