Question about GE Ovens
Replace WB27k5298 with WB27T10276
Replace control panel
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: I am replaceing the ERC on a GE wall oven
The new control pad has a removeable plug. Take it out and insert the old touchpad plug in its place.
Should be 2 qick connect snaps on the new control to remove the insert.
Posted on Mar 28, 2009
GE Double Oven Controller WB27T10276 Connection Details
I successfully replaced my WB27T10063 with the WB27T10276 (ERC3-GE-M) by following the instructions (Pub. No. 31-10515).
"they tell you for the Broil Relay to connect L1A to the common terminal."
This is simply a misreading of the poorly written instructions.
  1. Bake: yellow goes to yellow NO.
  2. Broil: violet goes to violet NO.
  3. Broil: black L1B goes to violet COM.
  4. AUX 2 goes to AUX2 (black and white wire).
  5. AUX1 goes to AUX1 (daisy-chained black from violet COM/L1B).
  6. OV2 goes to OV2 (white wire).
  7. OV1 goes to OV1 (brown wire).
  8. L1A goes to L1A (daisy-chained black from AUX1).
  9. N goes to N (daisy-chained white from OV2).
  10. GND needs to be "tucked under the (steel) clock bracket" on the control panel.
The hardest part was disconnecting the wires from the old ERC. Took a LOT of force! I also had a hard time figuring out how to release the green tape thing apparently labeled "J1" on the old ERC. Piece of cake after that.
Aug 09, 2012 | GE JKP27 Electric Double Oven
FO ERROR ON OVEN
Seems F0 is a problem either with the control panel or with the key panel
Here is a test to find out whether its your control panel or control board:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
You can go to this site to find replacements
Mar 14, 2008 | GE Profile JKP56 Electric Double Oven
Error codeE6 F2
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
- The part number for the new control board AP3595759
- The part number for the black/stainless control panel AP3131755
Good luck.
Gene. __________________Hi I did some research for your oven and this is what i found , someone with the same problem , control board needs to be replaced , if you click on the web page below it will explain it to you , good luck Frank
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html#ixzz1gYuqvZnV
Dec 14, 2011 | Whirlpool RBD275PR Electric Double Oven
IM GETTING F1
Hello there and thank you for using fixya
Well i wish i had better news for you but your f1 code is teling you that 1 of 2 things are failing.
First is that you electronic range controle has failed and needs to be replaced
Or that your touchpad has stuck and needs to be replaced .
Here is how to test to see which one it is
Remove the back panel from the oven controls to expose the controle panel .
Jan 24, 2011 | Amana AEW3530DD Electric Single Oven
Need wiring diagram for part number WB27T10276 for ge oven model JRS04BW3BB
For anyone installing a replacement oven controller #WB27T10276, there is a GE publication # 31-10515 that should answer your questions. I bought a rebuilt control that did not have this info. with it. Lucky for me, a retail appliance parts store opened a box with a new control in it and copied the instructions for me.
Aug 14, 2010 | GE 24" Built-in Single Electric Wall Oven...
Warning codes f2 & e3 on Whirlpool oven . Warning beeps alerted us to a problem.
good luck
Feb 27, 2010 | Whirlpool Ovens
Control panel on oven not working (clock/heat time, etc..) (model fgf326a)
HI, this control(clock/timer), will need to be replaced at this time. this code represent a control fault within the chip set(logic). this control has failed.
Jun 01, 2009 | Frigidaire FGB24S5A Gas Single Oven
I am replaceing the ERC on a GE wall oven #JKS05BW2BB. The ribbon connector from the touchpad has a ''plug'' and the new ERC had a ''socket'' for just the ribbon. Will the touch panel have to be replaced...
Mar 28, 2009 | GE Ovens
Control panel Roper gas range replace or buy new range?
4337979 Control-Clock/Oven
Retails for $206.90 easy to replace good luck..
Sep 28, 2008 | Ovens
Ovens Logo
80 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
