Question about Goldstar MV-1501 Microwave Oven
Microwave door has burn spots on the glass of the door...
There seems to be brown spots on the inside of the glass door. I cannot clean off these burn spots on the outside of the door, nor the inside of the door. It actually seems that the spots are inside the glass. I'm starting to think there is actually 2 sheets of glass and the spots are between the glass.... does this make any sense? weird. Perhaps there is a way to remove the glass? Please assist/advise. Thanks, Tony
  • 7 more comments
  • Lewis Aug 14, 2013
    I had the same problem with my Roper MHE14XKQ
    Those spots are not burn marks nor are they stains. The door has glass on the outside, a piece of perferated metal painted black in the middle, and a clear decal similar to packaging tape on the inside. The problem is the paint flakes off the metal grid over time and rusts. What you are seeing is rust. Take off the top plastic vent above the door, then you can lift the door off it's hinges. Then pry the black plastic outer frame from the inside of the door, then pry the metal frame out, be sure to remove the door handle screws first.
    next, clean the rust off of the glass, and take the metal part and spray it off in the sink. You will then need to set the metal part in front of a fan to dry for about 30 minutes as drying with a towel, etc. will not get all the water out of the grid.
    if you want to fix it right, you can peel the clear tape off the metal grid, and re paint the grid, then order a new clear tape piece from partsselect.com or similar for around 20 bucks.
    if you put it back together as is, it will look great for about another year until the rust forms again.
    just make sure you remove the door and do this procedure on a table. If you try to take it apart while on the hinges, you will likely cause the glass to drop out and break, and you don't want to do that because it costs 80 bucks to replace.
  • Anonymous Mar 13, 2014
    inside glass cracked so how to take off the door to replace the glass
  • Anonymous Mar 16, 2014
    how do I remove the door glass due to spotting between glass. This spotting is getting worse.
  • Anonymous Mar 26, 2014
    how to remove metal screen / mesh inside glass door
  • Goldstar Master
  • 9,156 Answers
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Posted on Jun 26, 2007
How do I clean inside of glass on door of AMV5164BAQ?
You can use normal glass cleaner or bleach with anything but metal abrasive pads
Mar 02, 2015 | Amana AMV5164 Microwave Oven
Magic Chef microwave oven
On alot of models the door comes as a complete assembly and can't be taken apart. Magic Chef is made by Maytag and I am pretty sure theirs do not come apart. If it does come apart then it is likely held togther by plastic tabs that have to be pried apart. The problem is they break easy and then you will be replacing parts. Guess you will have to decide if it is worth taking that chance because doors are expensive. I don't see your model # in the description but you can try looking a diagram by typing in your complete model # located on the sticker inside the microwave. Try sears.com and click on parts and various other repair sites. Hope this helps. Let me know if you have any other questions.
Oct 07, 2007 | Microwave Ovens
Clean inside glass door jenn-air jmc8130dd
follow your instruction manual, download from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Dec 09, 2013 | Jenn-Air JMC8130DD Microwave Oven
Problem with the Whirlpool GH5184XPQ 1100 Watts Microwave Oven: In turning the microwave on this morning, a faint electric sparking was heard. Upon shutting it off and opening the door an acrid burning...
The problem is that the magnetron is arcing when it is running and it has found a couple bare spots 'exposing the metal'. The microwave uses a special industrial white enamel paint to prevent arcing, it is very important that the oven be removed from service until the situation is rectified otherwise there is a danger of shorting out the magnetron.
Feb 22, 2011 | Whirlpool GH5184XPQ Microwave Oven
How do you clean inbetween the oven glass door?
To clean between you need to remove one of the pieces of glass...usually the inside is the best....
There are a few screws on the inside of the door theat hold the frame, which holds the inside glass...
remove the frame and carefully remove the inside glass... clean the inside of the outside glass, then clean the inside of the inside glass and then reinstall the froame over the inside glass...
Now you have a clean ove glass again...
heatman101
Nov 16, 2010 | Microwave Ovens
Steam got inside door of microwave behind glass. Now there are white spots where water dried. How do I clean the inside?
Look and see if there are screws holding the inside of the door to the outside of the door.
If so, remove the screws and the door should come apart, and may be cleaned.
God bless your efforts.
Jun 29, 2010 | GE HVM1540SNSS Microwave Oven
There are spots in the glass in the door can you take it appart
There is a screen behind the outer glass of the door which protects you from harmful microwave emmisions. Residue will build up here over time. Trying to clean this screen may damage it and subject you to serious problems. I have been using Microwave ovens for 35 years with no problems. I dont worry about this because germs will be eliminated by the emmisions.
Nov 13, 2008 | Frigidaire PLMV169DC Microwave Oven
Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Oct 01, 2008 | Maytag MMV1153A Microwave Oven
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
1,962 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Mike
Kevin
Kevin
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
