Runtime error 216 at 0051E9FF
After my tera copy finished moving my data. then suddenly error notice appear after i report error problem the runtime error message appear. please help me to fix this problem
  • 18 Answers
SOURCE: runtime error
There might be a problem with your graphic card or the game you are playing that your graphic card can not support. or you might have to uninstall the game you are trying to play and install the game again.. most likely it will be the graphic card not supporting the game.
hope that helped.
Posted on Dec 27, 2007
  • 242 Answers
SOURCE: Facing problem with outlook plz help
Either the message you are trying to send is too big, e.g contains a too large attachment, or your mailbox on the server is full...
Posted on Mar 31, 2008
  • 3940 Answers
SOURCE: Moving files from Windows xp
The file on the hard drive is corrupt, run scandisk and fix the file error, but the video is likely a loss
Posted on Jul 06, 2008
SOURCE: Photo Exploer Runtime Error
My solution:
I found another solution(workaround) instead of reinstalling the program:
1. Try to remember wich devices you used in de Photo explorer (USB-stick, external drive, DVD- CD-drive, or photo-camera connected by USB;
2. You can only start PEX(Photo Explorer) with a volume loaded in this devices!
3. if you don’t remember wich devices you used before, plug in a volume in every device your system has.
4. Start PEX. On my system it is then starting without error!
5. If PEX is normaly started: goto File/Preferences/ (or F6 key), take category Cache and under “History” clean all adresses and maps by clicking the button.
6. Close PEX. Remove all the volume’s you don’t need;
7. Restart PEX. Now the program will start without any error.
8. Advice: each time you use PEX with an external device do action 5. before closing the program.
Posted on Nov 06, 2008
  • 28 Answers
SOURCE: sage line 50 nominal reports.
reinstall ODBC Drivers usually found in your sage data directory
Posted on Nov 11, 2008
I am using Sony vaio S Series - VPCSB36FG. I keep getting a runtime error message when Google Chrome is running.
Go to www.google.com and in the search box type "download google chrome" (without the quotes). Download and install a fresh copy of Google Chrome from Google Chrome's website without losing any of your bookmarks.
Mar 20, 2012 | Computers & Internet
When i switchon my machiene an error occured Print Unable 52 please get me out of here regards
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the top cover and remove any foreign obstacles from inside the fax machine. If you see jammed paper or another item inside this area, gently pull it out and then close the top cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Step1: Transfer the Fax Journal Report
  1. Press Menu/Set on the Control Panel of the machine.
  2. Press the up or down navigation key until MISCELLANEOUS appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until DATA TRANSFER appears on the LCD. Then press Menu/Set.
  4. Press the up or down navigation key until REPORT TRANS. appears on the LCD. Then press Menu/Set.
  5. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Fax Start.
Step2: Verify and Transfer faxes in memory
  4. Press the up or down navigation key until FAX TRANSFER appears on the LCD. Then press Menu/Set.
  5. If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3.
    If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Fax Start.
Step3: Reset the machine
After the Fax Journal Report and faxes in memory are transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If the message continues to appear on the LCD, please contact Brother Customer Service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 19, 2010 | Brother Multi-Function Center MFC-240C...
Everytime i open iternet windows script host appear with the following data: Line 24, Character 1, Error permission denied, Code: 800A0046, Source:Microsoft VBScript runtime error. Please help me to solve...
It is a Windows Internet Explorer bug that could be fixed by upgrading your IE to version 8. Also, check your "home page"found at Tool => Internet Options and set it to some legitimate website. The error message simply means that the page you are viewing has scripts that return an error.
Feb 02, 2010 | Computers & Internet
Microsoft Visual C++Runtime Library
hello there
please follow this link for a explanation and a fix for this ok
  1. "Microsoft Visual C++ Runtime Library Runtime Error" error message ... Describes the error messages that you receive after you install Office XP or an ... "Microsoft Visual C++ Runtime Library Runtime Error" error message after you ...support.microsoft.com/kb/307817
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
' file integrity violated' error message.. copy problem
A message display as file integrity violated display when i try to copy or move the file
Jul 23, 2009 | SanDisk CompactFlash PCMCIA Adapter
I'm getting lots of runtime errors!
Here's a link to typical runtime errors in IE.
If you are getting errors from other applications, you can look them up in the event viewer, (link here).
It might be a good idea to do some system maintenance, clearing out temp files, etc by running disk cleaner. And it probably wouldn''t hurt to run chkdsk c: /f on your hard drive to look for corruption. (The results can be seen under winlogon properties in event viewer after you run it.) Instructions to do that here and here.
If you suspect malware could be a possibility, (and it seems possible, from the sound of it,) these are the malware removal protocols I recommend you follow.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 27, 2009 | Dell InspironTM 1501 Notebook
FILE INTEGRITY VIOLATED
if you have any fast copying software then uninstall it
Dec 23, 2008 | Computers & Internet
Dvd disc will not play or copy w/ WMP
I would try first washing the DVD. Use dishwashing liquid and hot water, with only your hands, and use side-to-side motions to move the soap around the underside of the disc, never 'with' the grain of the data grooves. When finished, rinse the disc thoroughly, and pat it dry with a clean paper towel or other lint-free cloth. When dry, try it again.
Hope this will FixYa!!!
Jun 11, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
