Question about KitchenAid Kitchen Ranges
Superba gas range flame too low
Adjust flame
catriver
  • 878 Answers
SOURCE: Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
Posted on Dec 23, 2006
Amigaman
  • 248 Answers
SOURCE: cannot adjust flame on gas burner
Is this lp or natural gas? The screw you turned adjusts the low flame only. Did this just start, or has it always done this? Let me know.
Posted on Nov 20, 2007
SOURCE: gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Posted on Feb 19, 2008
burzerko
  • 254 Answers
SOURCE: new gas range converted to propane
I think it sounds like one of two problems either the wrong orifaces were installed in the gas valves for the conversion or the pressure on the output side of the gas valve was not set correctly.
Posted on Jun 22, 2008
SOURCE: Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Posted on Aug 31, 2008
How to adjust the oven flame in a Unique Elite Gas Range UGP-36E ON1?
contact your gas supplier . perhaps the person that converted it forgot about the oven orifice needing changed too
Aug 18, 2017 | Kitchen Ranges
Gas orifice
Check your LPG pressure. This is very dangerous! Employ a gas expert to make it safe.
Feb 27, 2014 | KitchenAid Kitchen Ranges
My LRG 30357ST gas range burners flame are too low, How can I increase them?
Do they go out on low setting? If so then your regulator is faulty, Never adjust flame higher unless reg. checks out fine. Even then get a qualified tech to do that
Feb 04, 2013 | LG LRG30357ST (Dual Fuel) Stainless Steel...
I have a Kitchenaide model KGSS907SBL01 gas range. Everything works fine except that we find that the amount of heat generated is disappointing. This seems to come from the fact that the top of the grill...
It would seem like reasonable thing to do.However the adjustment is typically for the low setting so you can adjust just the small flame just enough to simmer a pot without the flame going out from being so low its susuptable to going out on the low setting, also it so you can adjust the flame smaller so on low it isnt too high,causing it will boil when you intend to only simmer a dish your cooking. A question;is it all burners and have they always been that way?
Gene
Aug 13, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
Need to adjust burners
Pull the knob off and look down the middle of the shaft. There may be a small slotted screw for adjustment. It should be adjusted on low setting only.
Jan 09, 2010 | Whirlpool SF110AXS Gas Kitchen Range
Gas cooktop flames are too high
are you natural gas or lp
and is your range set correctly
is your flame blue
or orange
Sep 15, 2009 | Kenmore Kitchen Ranges
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
Cannot adjust flame on gas burner
Nov 20, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Open Questions:
Kitchen Ranges Logo
42 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
