I have a cedar ridge blue flame propane heater from lowes. Once it gets cold enough to kick the heater on the flames seems to shoot very high to top of heater box then comes down to normal looking level. Is this normal?
joboo1
  • 257 Answers
SOURCE: Propane gas burner now has red flame instead of blue
Hi, If you have the same problem with your stove , furnace and water heater, Then you look for things in common that would cause the problem. Any change in the flames is an indication of a change in the fuel/air mix. The item that would be common to all would be the pressure diaphragm. This is not something a customer should work on without a through knowledge of how they work. I think you would be well advised to have a service call. Good Luck!
Posted on Feb 10, 2009
  • 744 Answers
SOURCE: low flame even on high
Check the propane regulator if equipped
Check the gas orifices - they may be carboned up and require cleaning
Check the venturi tubes (the tubes that go over the gas jets) - they may have spider webs or other insect cocoons in them
Make sure the gas valves work correctly (high/low)
You mentioned that you replaced the burners - are they correct for the unit and installed ok?
Make sure the gas valve on the propane tank is opened all the way
Posted on Mar 22, 2009
  • 148 Answers
SOURCE: pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
Posted on May 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: low flame
The newer type tank has an anti tip safety device. It gets all boo boo'd when the grill is moved around. Remove the tank. Open the valves on the grill and close them back. Re install the tank and slowly open the valve.
Posted on Jun 27, 2009
  • 139 Answers
SOURCE: Have Model CGP30TB Copmfort Glow propane
sounds like an obstruction in pilot assembly.try using canned compressed air to blow directly into pilot. this technique is successful about 70%. if not,pilot assembly must be removed and cleaned thorougly
Posted on Sep 16, 2009
Propane blue flame heater. Why does it flare/pop when the flame shuts off.Lights well ,flame is nice and blue but when the thermostat shuts it off it pops.?
Its just a small explosion from the mixture of propane and the oxygen rite at the time it gets to the percentage of O2-ph. Its safe. An oxy/acetlene set up does the same thing when the mix is to high in O2.
Feb 07, 2015 | Blue Flame Heating & Cooling
I have a 40000 btu all pro and it lights but the line freezes up and it starts throwing a large flame out, what is going on ?
Sounds like the regulator is bad or the tank is overfilled. The liquid propane is supposed to vaporize under high pressure within the tank, and the regulator lowers the pressure to feed the burner. It seems that your regulator is getting liquid and it is vaporizing at low pressure in the regulator. When the liquid vaporizes at low pressure it gets super cold.
Jan 26, 2014 | All-Pro Propane Garage Shop Heaters - All...
Why does new furnance with propane conversion have yellow flames?
Make sure the kit included smaller sized orifice's and spring kit for the gas valve. The number on each orifice should be cross referenced with total btu's rating of the furnace. It does seem like there is too much fuel or not enough air intake (combustion air). The inches of W.C. seem fine, but you still may be getting too much volume of fuel with too large of sized orifice's. Hope that helps
Dec 20, 2013 | Heating & Cooling
I have a Mr Heater infra red propane wall heater. My problem is it turns itself off (pilot light) after running for an hour or two. I have no problem getting it turned back on but for some reason it d
Your pilot flame should be blue with a small yellow tip, and it should cover the thermocouple (a small rod in front of the pilot light). If the flame is too small and doesn't cover the thermocouple, it may be adjusted too low, or you have low gas pressure or you have a leak in your gas line coming in to the heater. If the flame looks like a lazy yellow flame, you are probably not getting enough air to the flame. Check that your air openings around the pilot are not clogged up. If the flame looks like a waving blue flame then you probably have excessive draft at the pilot. If the pilot flame looks good and covers the thermocouple, then the thermocouple might be bad. Best of luck. I hope I have helped.
Nov 23, 2013 | Heating & Cooling
Im not getting enough fuel pressure to create a decent flame, everything lights as it should and stays lit but its not letting enough pressure out. Could it be the pressure regulator on the line thats...
Check what type of fuel, if using butane on cold days it will stuggle to stay alight, always use propane on outdoor patio heaters, propane will work in vvery low temperatures. If using propane check for leaks, do a leakage test, found this patio heater specialist site very useful.
Feb 21, 2011 | Endless Summer Blue Rhino 235000...
Dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Jan 13, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
Table top propane heater: tank freezes, fire goes out
I have a table top heater and was wondering why I have flame shooting out of the top of it when I should have like a blue flame, what can I do
Dec 14, 2009 | RTO Bernzomatic Brushed Nickel Patio...
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Wall heater not working properly--sputtering blue flame
Ok, either your fuel pressure is too low or too high.. When you light the unit, Light it in low, then turn it up slowly Just crack open your tank valve.about1/4 turn. The air in the tubes has to be displaced with gas before you get a good flame
Dec 02, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
271 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
