Question about Bose Acoustimass 5 III System
Bose speaker connection
So, how can I connect these lousy Bose Acoustimass 7 speakers, other than going through the bose controller (not a subwoofer at all)? I have a Yamaha RX-V1800. Your help is greatly appreciated.
PS..I could not select acoustimas 7 in the subject line because it was unavailable.
  • frankwmccart Feb 22, 2009
    I am trying to connect my AM 5 as a sub woofer in 5.1. I am using the sat speakers as the rears and a pair of 301's as the fronts and a vcs-10 for the center.
  • Anonymous Mar 16, 2014
    How do I connect 7.2 receiver to Bose Acoustimass 5? Not getting any bass from speakers...
    Brigadier General:
  • 8,546 Answers
The Bose systems are SYSTEMS for a very good reason. They're made for people who want good sound but don't want to manipulate the hardware much. The speakers and amps are designed for each other ONLY, not only electrically but through soundshaping to provide the smooth final result. The design is for you to feed the electronics a Line Level source and the magic and distribution happens internally. These are NOT mix 'n' match components. The special connectors are a clue. The Yamaha will probably blow them up if you manage to succeed with your plan.
Posted on Dec 28, 2009
  • Tony Vigil Aug 04, 2010
    Yeah! I have just acquired a Bose Model 614810 - Tuner/CD Player Unit. I have tried to hook up the Bose end with "mini-phono jacks", as required, on that end, while using a "bare-ended" wire end to hook up to some Sony Speaker System Speakers, which require a "bare-ended" wire into a insertion hole. The Bose turns "on"....I can select tuner, and appropriate tuner stations, but no sound comes out, why do I need this elaborate connection system, which is not versatile at all, but unique within itself?
    Tony
    vigilaw43@hotmail.com
  • David Dunn
    David Dunn Aug 04, 2010
    You could just get the manual from bose.com and read up on it.
    Not sure what you mean by the "Bose end with mini-phone jacks". What are you connecting to what - in detail?
    Do you see the word 'speakers' anywhere on the back of this thing?
    This unit is a tuner/CD and will not drive speakers directly so I don't know why you would think modifying its RCA output to match speaker inputs would magically do the trick. You need an amplifier between this unit and speakers, or self-amplified speakers. A mini-jack might work from the headphone output but the RCA outputs would be preferable.
Can i connect my bose acoustimass 800 with any other receiver?
hi,
Surly you can connect these speakers to any receiver. It has an active subwoofer and 5 passive cube speakers. It can handle power up to 150W.
ok
Apr 28, 2011 | Bose Acoustimass 6 III System
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
Apr 30, 2010 | Bose Acoustimass 10 III System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Can I connect my Bose Acoustimass 5 - Series II to Bravia unit?
Yes, there should be no issues using your Bose speakers with your Sony receiver. Sony has a "hookup guide" to help here -
http://esupport.sony.com/US/perl/model-home.pl?XID=M:products:crmportal&LOC=3&mdl=DAVHDX265
Please rate my answer, thanks.
Apr 30, 2009 | Audio Players & Recorders
Connect a laptop to a bose acoustimass sistem
If your laptop has speaker outputs that you can attach the provided bare wire cables to, maybe. Otherwise, NO. It requires speaker level inputs.
Apr 14, 2009 | Bose Acoustimass 15 6.1 Rear Speaker
Connecting Bose Acoustimas Wofer to a Sony receiver
you cannot hook a bose system up with any other system not even another bose
Jul 01, 2008 | Bose Cinemate Digital Home Theater System...
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
Bose Acoustimass 5 III System Logo
1,964 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
