Question about Garden
My Homelite d3300 DX series runs great for a while then quits some say its a stopped up but it looks clean some say air filter it is clean do you have any solutions I mixed gas ratio 40:1
Serial No. HS1950889 also will it handle a 18 or 20" bar
    Sergeant:
  • 391 Answers
Hal:
Check the fuel filter at the end of the fuel line in the tank... sometimes it will get hung up in the tank and won't be immersed in the gas. also check to see if there is enough fuel line in the tank to ensure that the fuel filter stays immersed in the fuel in the tank.
Posted on Jan 06, 2013
  • 597 Answers
SOURCE: homelite 240 chainsaw spiting gas?
Spitting gas is not good. It's probably leaking there instead of going into the carburetor where it can fire the engine. Need to find that leak and change the hose it's running out of. You get gas to the carburetor by gravity and vacumn from the engine. With a broken hose you loose all gravity effects and vacumn that would pull the gas to the carburetor.
Homelites from the beginning of time have spilled mixed gas down over the cylinder head by the spark plug from the gas cap. Then you go out and cut massive amounts of wood and all the sawdust swirls around the head, sticks to the oily gas residue and sooner or later it builds up in the cooling fins surrounding the cylinder head. This causes the chainsaw to run hotter because it can't cool efficiently and the gas tank is right there close to the head and cylinder so it absorbs a lot of extra heat, so much so that i've seen the gas inside the tank literally boiling hot which forces it out of the gas cap vent and spills more oily gas mixture over the head to accummulate more sawdust and cause more overheating. Care should be taken not to overfill the gas tank. Keep the saw and cylinder head clean of buildup so it can run cooler and change gas tank caps often so that you have a clean vent incase you do build up pressure.
Posted on Jun 03, 2009
dontbother10
  • 2220 Answers
SOURCE: Have an older XL 16
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/87d4d17cf11a7c8b88256c280064b0b8?OpenDocument
XL-12 and 15 agree with your mixture, no 16 listed.
32:1 = 1 gallon of premium fuel to 4 ounces of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 19, 2010
dontbother10
  • 2220 Answers
SOURCE: I have a 1979 Homelite XL Chainsaw model # UT
32:1 according to this.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/57a3b86d6acae4e188256c260048b728?OpenDocument
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 14, 2010
  • 14 Answers
SOURCE: What is the proper oil to gas ratio for a Homelite...
Most of the old Homelites were 32:1. I eliminated the mix problem for all my equipment when I started using a synthetic 2-cycle oil called OPTI-2. Somehow it works for all 2-cycle saws/trimmers/blowers etc. I've got equipment that's 20+ years old and still running strong with the OPTI-2.
Posted on May 20, 2010
miket756
  • 2702 Answers
SOURCE: I have a used Homelite d3300 UT10779 and no
there normaly a 40-1 mix,,,i run mine in a 30-1 mix,, now i know your going to say "thats a bit ritch!" but my saw is 20 years old now? and i look at it this way,,,if you can see smoke you got oil?
if you run it on two stroke or engine oil you need to run it on the ritch side,,,so stick on 30-1
Posted on Nov 25, 2010
Homelite chain saw csp 3314 will start if i tip petrol in spark plug home but wont stay running
There could be a problem with either the fuel line going to the carb or the impulse line that's connected from the cylinder base that generates the 'pulsing' action that operates the diaphragm fuel pump. Today's alcohol rich gasoline has a tendency to weaken or even rot the rubber lines causing fuel delivery issues.
If you don't use your saw for extended periods, dump the tank empty then start the engine and run the residual gasoline from the line. This will help extend the life of the fuel lines.
Another possibility could be a blocked fuel filter, but that is remote.
Feb 22, 2015 | Homelite 12" Oregon Chain Saw Repl. Chain...
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
My 93 oldsmobile cutlass ciera stalls too much
Check the oil. Quite a few cars do that when they are low.
Sep 26, 2017 | 1993 Oldsmobile Cutlass Ciera
How do you clean out a stopped up muffler on Homelite d3300 chainsaw
Hal:
I remove the muffler, and clean it with a spray bottle filled with rubbing alcohol... make sure that the alcohol is completely evaporated before starting the saw with the muffler on it. You can also use carburetor cleaner. An old toothbrush comes in handy also.
Jan 02, 2013 | Garden
My Homelite chainsaw is hard to start and stops running after 5 to 10 seconds.
Could be the filter in the tank or the cap. The tank needs to be vented to allow fuel past the filter.
Jul 03, 2012 | Homelite Garden
I have a used Homelite d3300 UT10779 and no manual... need the gas oil ratio.
Nov 25, 2010 | Homelite Garden
Homelite d3300 chainaw has stopped lubbing itself
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 23, 2009 | Standard Oregon Chainsaw Chain For...
I have a homelite chainsaw model d3300 every time I hold down the throtel it dies any idea why thanks Code dog
there are a number of things that can cause this. # 1, a dirty air cleaner element. # 2 the high speed jet needs to be adjusted out. # 3 a bad spark plug. # 4 a vacuum in the gas tank. # 5 the chain brake is on. Hope this gives you some clues.
Sep 10, 2009 | Homelite Garden
MY HOMELITE ST 275
Hi Glenn,
First, check the fuel lines for cracks/breaks. Replace if bad.
If they are o.k.,then you will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 14, 2009 | Homelite Garden
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
