Question about NetGear RangeMax Dual Band Wireless-N Gigabit Router WNDR3700 - wireless router
How to install to att 2wire 2701hgb modem router
Having trouble connecting my wndr3700 router to my att 2wire 2701 modem .it was running at first and my kid unpluged i pluged it back the roght way first modem then router last cpmputer ive benn getting drop signals and waiting for dns information.im setting up my home network with my ps3 wich is the only device on ethernet... help
  • 826 Answers
Plug power cord into back of modem and then into an electrical outlet. At this point you should see the lights on the front of the modem beginning to come on.
Check the front of the modem for a solid green DSL light. If the light is still blinking, allow a few more moments before proceeding to step 5. A blinking DSL light indicates a break in the network and will require the help of your service provider if it does not turn solid green.
Open your internet browser and type the default gateway into address bar. The default gateway will be provided by your service provider. Newer model 2Wire modems automatically direct you to the installation instructions when the browser is opened.
Click on "Run System Setup Wizard" in the lower right-hand corner. It may require the system password. This password will be provided by your service provider.
Select your timezone and click 'Next.'
Enter your ISP provided login information and click 'Next'. This should authenticate your credentials on the network and complete the installation.
Posted on Jan 02, 2013
sandrew
  • 2961 Answers
SOURCE: Wireless connection fails: won't assign address
As ever starting with the simplest of solutions normally works, well spotted.
Posted on Nov 28, 2006
Alex1413
SOURCE: Connecting Ipod touch 8(GB) to Wi-fi
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Posted on Nov 05, 2007
CRTN
  • 716 Answers
SOURCE: Internet connection dies when phone rings
There are a number of tests you can perform to find the problem unhook all the phones in your house and then call to see if it still does it. If it doesnt it may be one of your phones. If it does check the wiring in the jacks and make sure the wires are not backwards in any of them. If they all appear to be fine there maybe a problem at the pole or box whichever the company has installed in your neighborhood. Once you have determined that none of the above is present its not your fault and the providing internet company should not charge you to come out and check the outside lines. It can be as simple as a little short in the wire especially if its underground.
You may also wanna locate the phone box on the outside of your home and see if it disconnects when connected to there.
The box Outside Should Look Like This
And You'll Need To Disconnect All Of The Lines From These Plugs And Then Plug Your Internet Directly Into One Of Them. This Will Disconnect All The Phone Lines In The House. Now Place A Call To Your Home Via Cell Phone Or Have A Friend Call And If It Doesn't Disconnect Your Internet The Problem Is In The House.
If It Still Does Its The Phone Company's Problem And You'll Need To Call Them To Fix The Problem.
If This Does Not %100 Solve Your Problem Let me Know And I Will Continue Further Trouble Shooting With You.
Sincerely,
Michael Scott
Posted on Feb 04, 2009
  • 145 Answers
SOURCE: Can't connect Netgear router with ATT DSL
After you hook everything up the first thing you want to do is power cycle everything. So unplug the power cord on the router and the modem, Then plug the modem back in first and once the lights all come back on then plug in your router and once those lights come up i would reboot your PC and see it that helps.
Posted on Apr 08, 2009
redhaze89
  • 854 Answers
SOURCE: Netgear wgr61 Wireless Router
you can also check the settings of your wifi security. I would suggest you use WEP or WPA-TKIP (personal). You can also try considering this options below;
Getting an intermittent wireless connection can be attributed to the following factors:
a. 2.4 GHz wireless interference
b. Wireless settings of your router
c. Location of the devices
d. Obstacles
You may also refer to the common causes of interference:
Window in brick wall 2dB
Metal frame, glass wall into building 6dB
Office wall 6dB
Metal door in office wall 6dB
Cinder wall 4dB
Metal door in brick wall 12.4dB
Brick wall next to metal door 3dB
In order for us to isolate the problem, please refer to the steps below:
1. Avoid obstacles.
a. Try to move the router to different locations in order to get better connectivity. We suggest placing the router on high location to avoid obstacles that may be blocking the signal.
2. Reduce wireless interference in the area.
a. Try to move the router away from devices that are operating on 2.4 GHz frequency like your cordless phones and microwave ovens.
b. Try to move the router away from windows. Windows let in interference from the outside world.
3. Adjust the wireless settings on the router.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. For security reasons, the router has its own username and password. When prompted, enter admin for the Username and password for the Password, both in lower case letters.
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab.
e. Change the Network name or SSID to your preference.
f. Change the Mode to g and b only.
g. Change the Channel to 11, 1, 6 or 9.
h. Click on the Apply button.
i. Reconnect your computer to the wireless network and see if it fixes the problem.
Note: If the problem persists, you may need to upgrade the firmware of the router.
4. Upgrade the firmware.
a. Please verify the router version and model either underneath or at its side panel.
b. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router.
c. Click the appropriate version of the router.
d. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. If your computer has wireless connection, then please disable it first.
e. Before upgrading, please write down all current settings since you need to enter them manually.
f. Using the computer hardwired on the router, please access the router’s setup page again by going to http://192.168.1.1 or http://www.routerlogin.com/basicsetting.htm
g. Click on Maintenance and then Router Upgrade.
h. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.
i. Please wait for the router to reboot.
5. After a successful firmware upgrade, you need to reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards.
The router can be reconfigured using the setup CD or by manual configuration.
Posted on Apr 11, 2009
I bought a 2701hgb 2wire modem on ebay. How do I
You shouldn't need any drivers it should be plug and play but once you recieve it let me know and i will be glad to help.
Mar 19, 2010 | Dell Computers & Internet
Att dsl internet on deskop and want wireless for my laptop
Yes you can buy a different DSL modem and that should not be a problem , then once you have the new DSL you just contact ATT and they will set up the settings on it...
Oct 09, 2009 | 2wire 2700HG-B Router (2700HGB)
How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
Aug 19, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
ATT 2wire-2701HGB modem not working properly
Please loot at his post, i replyed to his question.
Jul 16, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Connecting ADSL wireless modem router to COMCAST
unfortunately you can't because the 2wire is a dsl modem it has to use the phone line to connect to the internet, it would be different if it was just a router but since it is a modem it needs that connection to the phone line in order to work
Oct 15, 2008 | 2wire (1000-400108-001) Router
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
2701HGB modem - dsl light flashes red
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire 2701HG-B.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
May 07, 2008 | 2wire (1000-000057-000) Modem
NetGear RangeMax Dual Band Wireless-N Gigabit Router WNDR3700 - wireless router Logo
206 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
