Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Surfboard updates cannot connect with WII
My iphone won't connect to my SURFboard SB6141
Ensure the pass code is correct.
For additional support call ARRIS support.
Mark
Motorola Mobility Support
Jun 16, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Cant connect xbox to wireless internet
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Feb 29, 2012 | Arris SURFboard SBG900 Wireless Router...
My wire internet is not connecting to my wii what can i do so i can get the internet to work on my wii judy
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter.
Jun 04, 2011 | Nintendo Wii Console
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
Problem connecting acer aspire 4736, motorola surfboard sb5101
2ways:
go to the msi website and use the live update
or you can get drivers from here
Jul 24, 2009 | Arris SURFboard SB5120 Modem
Password,Username, and SSID
The SB4200 Modem according to the Motorola website does NOT have wireless capabilities. In fact not a lot of cable modems do have wireless built in to them.
http://broadband.motorola.com/consumers/products/sb4200/default.asp
That is the modem to which you refered and it does not have wireless. In order to connect your Wii wirelessly you would need to purchase a WIRELESS ROUTER, which most major stores carry varios brands such as Linksys or Netgear.
Jun 21, 2009 | Arris SURFboard SB4200 Modem
How do i get connection 24 on my wii?
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.....
Mar 09, 2009 | Nintendo Wii Console
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
103 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
