Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
TUB NOT DRAINING - Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
  • Official Brand Answer
  • 4,342 Answers
Hello Maria Fernando - I will be happy to assist you and I understand that you are stating that the tub is not draining, however or you speaking about a dishwasher or washer? May I please have the exact model number of your unit so I can assist you further in pinpointing you the correct information?
Posted on Jan 06, 2013
Morgan hot tub
I found the drain snakes very helpful to unclog a drain even it is a bathtub. Dran snake found both hand cranked and power cranked. for home use, the hand crank is enough but for professional plumbing power cranked drank snake is best.
Learn more from here -
https://www.toolsfreak.com/best-drain-snake/
Jun 30, 2014 | Pool & Spa
Tip
The washing machine is draining but the water is coming back inside?
Check out this possibilities for water not draining in the washing machine: This problem relates to the hose connected to drain pump. The drain hose should not be in laundry tub more then 4 to 5 inches. Measure it and if it’s more then 4 to 5 inch then cut the excess hose in the tub. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly. But if the drain pump hoses are ok checked then this problem relates to slow drain of water from laundry tub. You can solve this issue by cleaning the drain pump blockages and dirt build up this will make the flow of water proper in the draining of the laundry tub.
This will help.thanks.
on Mar 18, 2010 | Washing Machines
I have a saniflo pro used for toilet , whb and shower .Unit works ok until soap ,shampoo is used which causes foam to come out of the vent .Any ideas would be appreciated
go to spa dealer and get anti foam chemical pretty cheap drop a few drops in tub before draining or a couple drops in sink before draining tub will solve problem
Feb 28, 2014 | Home
Washer stopped draining
Something like a sock or small rag is stuck in Pump. That will have to be removed if possible or replace Pump.
Nov 14, 2017 | GE WJSR2070B Top Load Washer
My prodigy WPSE4200SA is not draining
first check if you have power if so then check your waste pipe is not blocked if that is not the problem manually drain the tub by opening filter then the water run out just remember you need towels and any pipe to redirect water to a suitable drainage point.
May 08, 2012 | GE Profile Prodigy WPSE4200A
My tub won't drain correctly, we followed the maual and still not draining fully from tub. I have a maytag front loader.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 15, 2010 | Maytag Washing Machines
New washer draining out while washing or rinshing
If this is a brand new unit, make sure that the drain hose is hooked up at a level at or above the level of the tub. If it is too low, it can siphon the tub of water.
Apr 30, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
May 12, 2009 | GE Nautilus 24" Built-in Dishwasher
I have a error code coming up saying E:04. Any solutions?
It has been 2 1/2 weeks since this was posted so it has already been solved probably. Open the basket on the pump to see if the water is draining freely from the wash tub. (You can access the basket by removing the round panel in the lower right corner of the front panel). If the water is freely draining, check for plugging of the drain line from the pump to the outside. If the water is not freely draining, remove the rubber boot between the wash tub and the pump and clean out the debris around the ball at the wash tub end.
Apr 11, 2009 | Bosch WFMC2100UC Nexxt Essence Washer
Maytag legacy series washer not holding water
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
Jan 06, 2009 | Maytag Legacy Series Top Load Washer
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
47 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
