Question about Garden
How do you clean out a stopped up muffler on Homelite d3300 chainsaw
    Sergeant:
  • 391 Answers
Hal:
I remove the muffler, and clean it with a spray bottle filled with rubbing alcohol... make sure that the alcohol is completely evaporated before starting the saw with the muffler on it. You can also use carburetor cleaner. An old toothbrush comes in handy also.
Posted on Jan 06, 2013
  • 42 Answers
SOURCE: On a homelite chainsaw model d3300 i have all fuel
The line that hooks up at the front of the carb (#17 in picture) goes to the fuel tank. the line that hooks up at the rear of the carb (#18 in picture) goes to the primer bulb. Hope this all helps. Let me know. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chcp%5cimages%5c06%5c01%5c13%5c0007.tif&ilsc=12&iliv=0&ilbr=0&ilif=p&ilre=8
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: HOMELITE 245 CHAINSAW. IT WILL START
check gas tank vent and cap. Adjust carb a small amount ie. back out screw marked L 1/4 turn. If that does not work adjust screw marked "H" 1/4 turn out if no results adjust back to original position and go 1/4 turn farther in.
Posted on May 09, 2009
  • 302 Answers
SOURCE: I have a homelite chainsaw model d3300 every time
there are a number of things that can cause this. # 1, a dirty air cleaner element. # 2 the high speed jet needs to be adjusted out. # 3 a bad spark plug. # 4 a vacuum in the gas tank. # 5 the chain brake is on. Hope this gives you some clues.
Posted on Sep 10, 2009
jyackle5
  • 8197 Answers
SOURCE: Homelite chainsaw d3300 14 inch
The clutch is held on with a E-clip. On the link below page 6 part # 18 will show you.
http://www.odref.com/homelite/chainsaw/ut-10933.pdf
Good Luck and please accept the answer
Posted on Sep 25, 2010
miket756
  • 2702 Answers
SOURCE: I have a used Homelite d3300 UT10779 and no
there normaly a 40-1 mix,,,i run mine in a 30-1 mix,, now i know your going to say "thats a bit ritch!" but my saw is 20 years old now? and i look at it this way,,,if you can see smoke you got oil?
if you run it on two stroke or engine oil you need to run it on the ritch side,,,so stick on 30-1
Posted on Nov 25, 2010
My Homelite d3300 DX series runs great for a while then quits some say its a stopped up but it looks clean some say air filter it is clean do you have any solutions I mixed gas ratio 40:1
Hal:
Check the fuel filter at the end of the fuel line in the tank... sometimes it will get hung up in the tank and won't be immersed in the gas. also check to see if there is enough fuel line in the tank to ensure that the fuel filter stays immersed in the fuel in the tank.
Jan 02, 2013 | Garden
Homelite 4HCPS
take off the muffler and try it if ok open the muffler and clean the screen off
May 16, 2012 | Garden
Saw runs then quits
REMOVE THE MUFFLER WHEIR WILL BE A SMALL COVER ON ONE SIDE. REMOVE THIS COVER AND YOU WILL SEE A SMALL WIRE MECH CLEAN THIS WITH CARB CLEANER AND REINSTALL. THIS SHOULD CURE PROBLEM. LIGHTNING MAN
Jan 12, 2011 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a used Homelite d3300 UT10779 and no manual... need the gas oil ratio.
Nov 25, 2010 | Homelite Garden
Homelite Chain Saw UT10550 / 18 in. engine starts but will not run at enough speed to cut
It sounds like not enough fuel, air, compression or restricted exaust. Take the muffler off and run it and see if that fixes it. If so clean the muffler and exaust port and your good to go.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 02, 2010 | Homelite Garden
Hello, I have came upon a Homelite Super2 chainsaw i can get it to start for a seconds then sputters out. Would like to take it apart and clean it up, any help is appreciated and thank you. need a manual.
Check the fuel filter for plugging, the fuel lines for hardness/cracks/splitting, and the air filter for plugging. Check the muffler for plugging as well. If still reluctant, dismantle the carburetor, clean, and re-kit. The lower diaphragm is prone to harden and crack. Good luck!
Apr 19, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite d3300 chainaw has stopped lubbing itself
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 23, 2009 | Standard Oregon Chainsaw Chain For...
Cant find a muffler for 1984 approx. 245 homelite
I tried the Homelite site (no longer available). You probably did too.
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/673d78ec01557aea88256b00005457e6/53fd90eee11e3fe8882572a300167f51?OpenDocument
There is at least one old Homey parts source.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did a search there are many hits on Homelite saws one matches your model... that you spud? HTH
Lou
Oct 01, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a homelite chainsaw model d3300 every time I hold down the throtel it dies any idea why thanks Code dog
Sep 10, 2009 | Homelite Garden
On a homelite chainsaw model d3300 i have all fuel lines lose and have forgotten location of where they go. What is the locations of the supply lines from the gas tank to the carburator?
Feb 23, 2009 | Homelite Garden
Garden Logo
126 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
