Question about Sony Wonderbook: Book Of Spells PS3
Can't calibrate move controler
Trying to play the game... but it wont get past the setting up process... I'm getting a message that the room is not bright enough but all windows are open and all lights are on...
That's happening to mine as well, if the lens is broke that's **** and if its a fairly common fault they should fix it
Posted on Jan 21, 2013
2 Suggested Answers
  • 17 Answers
SOURCE: I moved my ps3 in my front room and it wont read
the blu-ray lens may be broke, its a fairly common fault.
speak to sony tech support,
i hope its in warranty
Posted on Nov 23, 2009
Intec ps3 infinite play not working pc
It's not meant for the pc, but instead for the ps3.
Jan 03, 2013 | Intec Sony PS3 Infinite Play Wireless...
Medion MD 96340 Video Driver not working
Hmm..Can you please run a "dxdiag" & paste the output here? You need to enable the hardware acceleration which means that the processing will be done in the video card (GPU) as well as in CPU. It speeds up the processing.
Aug 12, 2012 | Medion MD 96340 PC Notebook
It keeps telling me a file is corrupted. ive restarted & everything but every time i turn back on the message pops up. Do u know what i can do?
If you get a corrupted file, there really is not anything you can do. Corrupted files are generally caused by somehow forcing a process to stop while it's writing to a file, and that file becomes corrupted. For example, if I am playing a game and I try to save, but then get bored of waiting and turn off the console while it's still saving, the file will become corrupted and unusable.
Don't fall for online scams of tools trying to recover corrupted files, there is really no way to save a file that's been corrupted. You should just delete the file and move on. If it's DLC you can redownload it, if it's a game save you can work your way back.
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
How do I get started using the gun?
See the Top Shot Elite Set Up Guide on the Discussions Tab at Facebook.com/ActivisionHunts or contact Activision Assist on Facebook. http://www.facebook.com/topic.php?uid=133041143393695&topic=331
The same is below.
Activision HuntsCablela's Dangerous Hunts 2011: How-to-Guide for the Top Shot Elite
You have two options when playing Cabela's Dangerous Hunts 2011 with your Top Shot Elite. You can either play with the default setting, or you can calibrate the gun to your television set.
Option 1: Default Setting - Sensor Bar Position
The default setting will work fine for most people. However, you will need to ensure that the sensor bar position is set up correctly within the game. If it isn't, you may have issues with aiming and lining up the reticle that appears on the screen.
How to Setup the Sensor Bar Position:
1. From the main menu, select "options"
2. Select "Controls"
3. Make sure that the "Use Calibration" option says "No".
4. Select the Sensor Bar position that matches your setup. Top means that you have the Sensor Bar above your TV, and Down means that you have the sensor bar below your TV.
Option 2: Calibrating your Top Shot Elite
Calibrating the Top Shot Elite is not necessary to play the game, but it can help improve the aiming experience if done correctly. It should be noted, however, that not all homes are ideal for calibration. You should only calibrate if you can stand comfortably 6-8 feet in front of your television.
How to Calibrate:
• From the main menu, select "Options"
• Select "Controls"
• Select "Yes" in the "Use Calibration Option."
• On the calibration screen, you'll see a target in the upper left hand corner of the screen.
• Stand at least 6 feet away, aim through the scope and line up your crosshairs over the target. Pull the trigger to continue.
IMPORTANT: A message will say "Cannot detect gun position" if it cannot read your Top Shot Elite. Usually this means that you're standing too close to the TV. Try backing away from it. If you're still unable to line up the scope with the target, read through the tips section below to ensure proper setup.
• Next, you will see a target on the lower right of the screen. Aim through the scope and pull the trigger to continue.
• Now check the calibration. Look at the screen through the scope. When you move the gun around the screen, the on-screen reticule should stay within view of the scope. As long as the reticle is visible, your calibration should be ok. If, however, you can't see the reticle at all times or you're simply not happy with the results, select the calibrate option to retry.
• Once you're happy with the setting, you'll need to save them. Exit the calibration screen and select "Yes" (you would like to save your settings).
Note: Moving your position within your room may throw off the calibration. If you decide to change positions, we recommend recalibrating for the best results.
Additional Tips and Tricks to Having a Good Experience with Your Top Shot Elite.
1. Room Setup
• Make sure your room is comfortably lit - not too bright. Your TOP SHOT Elite has a built-in infrared camera and will have less trouble seeing the infrared lights from your sensor bar if you turn down some of your lights a bit.
• Make sure you've removed extra lights near or around your television. The TOP SHOT Elite includes a small camera that looks for infrared light. If you've got little lights or even candles around your television, your camera might have a hard time seeing the sensor bar.
• Turn off other gaming consoles. Other gaming consoles might interfere with your TOP SHOT Elite. For example, if you're trying to use your Xbox 360 TOP SHOT and you have your Wii turned on, the sensor bar from your Wii could interfere with the wireless sensor bar for your TOP SHOT Elite.
• Give yourself plenty of room. The TOP SHOT Elite works best if you're standing about 6 to 8 feet from your television. In addition, you want to make sure you don't have any breakable objects near you when you're playing with the TOP SHOT Elite. This includes vases, lamps, other people, and anything else you wouldn't want to accidently hit with your TOP SHOT Elite.
2. Sensor Bar Setup
• Set your sensor bar at a comfortable height. Your TOP SHOT Elite needs to see the sensor bar at all times. Generally speaking, you want to set your sensor bar above or below your television so that it is as close to eye level as possible.
• Make sure your sensor bar is on. Please note that the wireless sensor bars that come with your TOP SHOT Elite don't stay on all the time. To save on battery life, the sensor bars have a built in timer that shuts off automatically. You can set your timer by adjusting the small switch in the back of the sensor to 1, 2, or 3 hours. When your sensor bar is on, you'll see a little red light in the front.
• Why isn't there a Sensor Bar Position option when I calibrate? When you calibrate the Top Shot Elite, the game automatically figures out where your Sensor Bar is, so you don't need to manually set it up.
3. The TOP SHOT Peripheral
• Turn it on and sync it up! Your TOP SHOT Elite peripheral is a wireless controller that needs to be synced to your console. If you need help syncing your TOP SHOT Elite, please refer to the following guide to help you out: Customer Service FAQ
• The forward control stick. Sometimes you need just a little extra help. Located on the front left of your TOP SHOT Elite is a second control stick that you can use to help you quickly turn while playing Dangerous Hunts 2011.
Jan 03, 2011 | Activision Cabela's Dangerous Hunts 2011...
Problem with the Activision Cabela's Dangerous Hunts 2011 with gun for Xbox 360. When aiming for calibration it wont turn red unless you point gun directly at sensor bar
The same is below.
How to Calibrate:
• Select "Controls"
1. Room Setup
2. Sensor Bar Setup
Dec 31, 2010 | Activision Cabela's Dangerous Hunts 2011...
Character moves side ways without me touching it. it also fights me for control while i'm playing
go to control panel and open "game pads" or "game controllers"
then choose properties for your game pad and choose the calibration tab, calibrate and set click ok and check if problem has been resolved
Jan 05, 2010 | Sony PS2 Dual Shock 2 Controller...
I am trying to install reader prs600. I have
http://esupport.sony.com/US/perl/swu-download.pl?mdl=PRS600&upd_id=5300&os_id=7
Dec 26, 2009 | Sony Reader Touch PRS-600
Console will not play video game disk
The laser may need to be replaced or calibrated
Dec 07, 2008 | Sony Playstation 3 (PS3) Console
Promblem
Normally there is no reason to re-calibrate the Logitech Cordless Action Controller for PlayStation2. In rare cases where the mini-joysticks may need to be re-calibrated, you can use the process below. Please note that this process only works for the Logitech Cordless Action Controller for PlayStation2.
  1. Remove one battery.
  2. Hold the L1 and L2 buttons while re-inserting the battery. (NOTE: Do not touch or move the mini-joysticks at all during this time. It is very important that the mini joysticks are allowed to center themselves during this step or the calibration procedure will not be successful.)
The mini-joysticks should now be re-calibrated. Please note that in some cases you may need to resynchronize the gamepad and receiver after this procedure.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=1414
Aug 13, 2007 | Logitech Cordless Action (9633200403) Game...
Sony Wonderbook: Book Of Spells PS3 Logo
235 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
