Question about RCA RT2360 System
Only 2 spearkers working
All spekers work when useing test tone but only to r showing lite up
I have a dell latitude D810 and the spekers dont work
try installing this audio driver. ftp://ftp.dell.com/audio/R99254.EXE
get back to me if that doesnt work
Feb 01, 2014 | Computers & Internet
Speakerphone doesn't work
Possible. Check out your manual regarding speaker phone settings, etc.
Aug 29, 2017 | RCA ViSYS 2-Line Speakerphone
Very dull sound from the 4 rear spekers on my 7.1 set up for the ONKYO 802. This happens for the satellite input for tv channels, is this normal that I will only get surround sound via a disc or other...
Your basic setup through the Onkyo establishes the base levels of each speaker channel with test tones. The tones should also sound pretty much the same from speaker to speaker.
How a given surround mode works with a given input would be documented in the manual. Even stereo sources can be proecessed into some form of 7-speaker output.
"ONKYO 802" is not unique. Are there letters?
Jul 20, 2011 | Audio Players & Recorders
Putting spearkers in and had ignition on. cut through wires while ignition was on! spearkers work but both my windows dont go up or down! no power to them. Allso interior light does not come on! While...
you could have shorted the window relay,, But if I was you, I would check the fuses with a meter first along with the interior light bulbs , what make and model is this car and what year ?
Jul 10, 2011 | Ford F-150 Cars & Trucks
Ear piece working.but buzzer not working?
Hai, if you see symbol headset on display screen, open your set, clean that pcb on charger n connector area, some time this happen during splash water. if pin of connector do not tuch on board, headset or car symbol will be apear on screen, ringtone cant be function thru loud speker.. But if problem still happen, maybe tone in need to change. 6256730.png
Jul 29, 2010 | Nokia 1600 Cellular Phone
Speekar problam
check you speker, u can test using multimeter, if no reading or beep sound, change that speker.
Apr 20, 2010 | Nokia 6085 Cellular Phone
Change text message tone on tocco lite
I have F480 touchwiz (right now my screen has stopped working) but if I remember correctly, I go to settings - profiles, choose a profile to change, and the tabs on the top of the screen allow you to change ring tone, sms/txt tone and email tone. Hope this helps
Jun 17, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Surround speakers work in test mode but won't come on during play
Check that you set it to Pro logic and check the speaker set-up. Set it to 5.1 Sounds like somthing is in the wrong setting.
Dec 22, 2008 | Yamaha HTR-5830 Receiver
Spearkers
I would suggest you test your speakers with another source of audio (eg. walk-man). Using cellphone radio intruption isn't a good test.
Then you can try to troubleshoot your sound card.
1) assuming your using windowsxp you should download the drivers from the manufacutrers website. (if you have a brand name computer eg. dell, sony etc.. it makes determining your sound card driver and download easier). If generic system you have to open your computer and locate the sound-card manufacturer. (NOTE: please use caution when opening computer and have to be grounded and in a secure surface with proper tools.
2) once you have downloaded the driver; right-click "My Computer" and choose manage. From the device manager
 choose sound and remove the driver. Reboot your system and when it boots up it should detect your sound card;  from the location you have downloaded and save the files update the driver when it prompts you.
Hope this helps
Oct 15, 2007 | Audio Players & Recorders
RCA RT2360 System Logo
20 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
