Whirlpool automatic washer model LA5500XT leaking water during cycle
aborcass
  • 2651 Answers
SOURCE: KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Posted on Mar 07, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE2 Washing Machine Leaking
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
Posted on May 04, 2008
robocop
  • 90 Answers
SOURCE: whirlpool washer wont spin during high spin cycle
Try www.Repairclinic.com.
Posted on Jan 19, 2009
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Maytag washer lat8600
That model doesnt come up on Matags web site?
Nov 25, 2013 | Whirlpool Washing Machines
Kenmore, model 796.4031, water draining out of opening in back of washer onto floor during spin cycle, this hole is not on the picture in the manual!
Seven water should not be coming out of anything but the drain hose-open it up and look for loose hoes or connection which would leak because of the vibration during the spin cycle-cheers Denny
Oct 18, 2013 | Whirlpool Washing Machines
Whirlpool HFW95HEXW. During the Clean Washer cycle, water trickles down the front of the washer and pools in the pedestal drawer. The amount of water is small, but this happens during every Clean Washer...
YOUR WATER MAY BE OVERFLOWING A BIT AT THE TOP, JUST UNDER THE MACHINE'S COVER.
A SENIOR LADY FRIEND HAD SIMILAR SITUATION
WE TILTED UP THE TOP ON HER AUTOMATIC WASHER AND DISCOVERED THERE WAS A LARGE BUILD UP OF LIME, LINT , OLDE SOAP AND SOFTENER .
WATER GOING INTO THESE AUTOMATIC WASHING MACHINE IS OPEN TO THE AIR AND NOT CLOSED IN.
THIS HARDENED MESS WAS INTERFERING THE WATER FLOW, CAUSING SOME WATER TO RUN DOWN ONTO THE FLOOR.
Feb 09, 2018 | Whirlpool WFW95HEX Washer
During the wash cycle of the 24" combo washer dryer, it leaked
A hose inside the washer is your most likely culprit. On older whirlpool washers they used a plastic hose to run from the pump to the back case of the machine that was pretty susceptible to cracking.
Jun 28, 2010 | Whirlpool LTE6234D Top Load Stacked...
Washer leaking water during wash cycle. Does not
There is a bad seal where the tub mounting with the transmission shaft to cause the leak. It leaks when it tuns. To access this, the agitation fin need to be out so you can see the big nut holding the tube in a place with the shaft. Below this nut is a seal or gasket to prevent the water getting out of the bottom tube. Replace this then you are good . Good luck.
Apr 21, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer leaking during clean washer cycle
the highest water fill cycle for your waher is the clean cycle.it will fill up with 2x the normal amount of water in this cycle than any other.look for a cut or wrinkle in your door boot(grey rubber outer ring that seals between door and boot)if you find one,only fix would be to replace door boot.also clean inner door glass that comes in contact with door boot ring,any hard water build up or sediment(dog,cat or human hair)will break the seal and allow it to leak.good luck
Sep 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
