Question about Lexmark X2500 All-In-One Printer
Problem with lexmark x5320 printer-paper out of alignment.
I have a lexmark x5320 printer. I attempted to print on an envelope. It didn't work and now I can't get the regular 8 by 11 paper to align properly. Can anybody help me?
SS
  • Anonymous Feb 20, 2009
    8x11 paper won't align properly
Democritus
  • 120 Answers
SOURCE: Alignment is messed up.
I would suggest running it through a cleaning cycle or two.
Posted on Jun 13, 2008
iqbal_del
  • 655 Answers
SOURCE: Lexmark 1400 printer always does alignment page at turn on wasting ink
It sounds that your printer did not finish the last aligment process. If it will finish after cartridge change then it will not be prompted again untill re-installation of cartridge.
When it asks for aligment do the complete process as permanual then the problem will be fixed.
Thanks
Iqbal
Posted on Jun 26, 2008
amfigue
SOURCE: Alignment error after replacing black ink. Lexmark X5495
I found a pencil inside my printer and took it out. It was not easy but now it does not jams the paper. Disconnect the power cord and softly shake the printer from side to side making sure you are holding on to the top scanner door so it won't flip open and listen for anything rolling or loose inside. It just might be your problem.
Posted on Mar 24, 2009
  • 54 Answers
SOURCE: Lexmark X4650
Here is how to align your print cartridges
Using the printer control panel:
1 Load plain Letter-size paper.
2 From the printer control panel, press tools , and then press ok.
3 Press the arrow buttons until Align Cartridges appears, and then press ok. An alignment page prints.
Using Windows
2 Do one of the following:
• In Windows Vista, click the windows globe (start button) .
• In Windows XP and earlier, click Start.
3 Click All Programs or Programs, and then select the printer program folder from the list.
4 From the printer folder, click Maintenance Align Cartridges.
5 Click Print.
6 Follow the instructions on the computer screen.
Using Macintosh
2 From the Finder desktop, double-click the printer folder.
3 Double-click the printer utility icon.
4 From the Maintenance tab, click Print Alignment Page.
5 Follow the instructions on the computer screen.
If you aligned the cartridges to improve print
Posted on Apr 14, 2009
SOURCE: hp psc 2210 all in one series printer: align cartridge repeatedly
Bypass the allign cartridge function bu pressand holding settup then press option. The printer will immediately acccept orders.
Posted on Apr 20, 2009
My envelopes will not print -
Did you remember to specify envelopes in the printer properties dialog box? Click the button that says Preferences. Then click the Paper/Finishing tab. Under Paper Size, select your envelope size.
The printer will not feed the envelopes correctly without specifying this. The Lexmark printers adjust feed tension based on paper size settings.
Oct 15, 2014 | Lexmark E260dn Laser Printer
I have a brand new ink cartridge in my printer. It printed the test page ok. When I try to print envelopes, it always says paper jam (there is no paper jam) the envelopes just wont feed. It's a Lexmark...
Make sure to set the correct paper setting on the printer or the Lexmark software before sending the print job. Adjust the printer's paper guide to the correct envelope dimension.
Dec 12, 2011 | Lexmark X6170 All-In-One InkJet Printer
I cannot get the envelope fuction to work correctly. The printer tells me I have a paper jam, when in fact I am trying to print an envelope
The printer will stop printing is there is an error, check for any paper jam before printing. Take note of the error message and locate the exact jam.
Use the manual feeder when printing on envelopes. You may click on the link http://bit.ly/rnHp5b to see instructions on how to go about the procedure using the manual feeder.
For further assistance, please call Lexmark Technical Support.
Mar 08, 2011 | Lexmark C532n Color Laser Printer
How does one print address to a number 10 envelop in the Lexmark e232 envelop slot?
If you go into Printing preferences before you print, you want to go into the tab that is calle dsomething to the effect of Paper/Quality. Look for the section called Paper Option. Under paper option there should be a part that lets you choose the paper size, there is where you can choose Envelope #10. Make sure also you have the Lexmark Universal Driver installed for this printer.
Feb 28, 2011 | Lexmark E232 Laser Printer
Keeps wanting to print alignment page
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Apr 20, 2009 | Lexmark X2470 All-In-One InkJet Printer
Dec 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
Newly installed won't stop jamming paper
Paper Jams in the Printer ID:412
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
If this didn't work please replace the printer by the company..
Apr 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
Printer has suddenly stopped printing envelopes
Just fixed it thanks to Lloyd at Lexmark.com Go to Technical Support > LIVE CHAT. To print envelopes all I needed was to check the print in "Black" only button. Under Quality make sure the Print Color images in Black box is checked, select Apply and OK.
Jan 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X2500 All-In-One Printer Logo
317 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
