Question about Gateway Computers & Internet
After install of vista set up
Help to set up after install
  • Gateway Master
  • 7,627 Answers
Take a look at this video: http://www.youtube.com/watch?v=cswg5hWDKfE .
Posted on Jan 02, 2013
How do I get Vista updates to install
Here is a helpful Microsoft Knowledge base article that should help! Install Windows updates
Apr 27, 2014 | Microsoft Windows Vista Ultimate Edition
Unlock windows vista
1 fix for this issue is to use the restore disc that came with the pc. If you don't have those and u have a vista disc you can use the Vista disc to install Vista and get the vista code off the Microsoft sticker on the pc. You can contact Microsoft for help as well they may have a way of unlocking it. Also if you are looking to upgrade the pc and u have a Vista install cd you could just put in a new hard drive and then install Vista on it. Hope this helps you. The other issue is there may be a BIOS Password if so then there is a whole new set of issues.
Aug 28, 2012 | Compaq Computers & Internet
Forgot password, does not have cd rom drive, need to restore to factory settings. How???
How to obtain Vista Recovery Media and/or use the Vista Recovery Partition on your computer to put it back to Factory Settings.
There is no legal free Vista download available.
Contact your Computer Manufacturer and ask them to send you a set of Vista Recovery disk/s.
They normally do that for a small $ cost.
Also, ask them if you have a Recovery Partition on your Computer/Laptop to restore it to Factory settings.
See if a Manual came with the computer, or go to the Manufacturer's website, email or phone them for info on how to do a Recovery.
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
They will tell you how to do that.
Each Computer Manufacturer has their own way of making Recovery Disk/s.
Or borrow a proper Microsoft Vista DVD(not Dell, HP, etc).
A proper Vista DVD contains all Vista versions.
The Product Key determines which Vista version gets installed.
There are 2 Vista disks: one for 32bit Operating System, and one for 64bit Operating System.
If a clean install is required with a proper Vista DVD (not HP, Dell Recovery Disks):
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation > Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 09, 2011 | Compaq tc4400 Tablet PC (RL875AW#ABA)
How do i reset my laptop to factory settings after installing vista
If you have removed the restoration partation while installing VISTA, you are done.
If you did not backup your programs before installing VISTA, you are done.
If however you had VISTA on the unit and you have re-installed it on the same, you may have a chance.
The best way to restore you computer back to factory is from the restoration disks or partation.
You can aways contact acer for a restoration disk set.
Hope this info has helped.
Sep 20, 2009 | Acer Aspire 3000 Notebook
NO SOUND OUTPUT
Check if the correct device is set for default output
Click Start
Control Panel
Sound
Select the correct speakers and set as default (like described as Realtek High definition Audio)
if you double click them, you can also change some settings there, I recommend you disable enhancements.
Finally, with the realtek driver comes a little application that runs in your tray (usually and orange speaker) verify settings there as well
Good luck, hope this helps
Feb 03, 2009 | Microsoft Windows Vista Ultimate Edition
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA
dont mind it...
if you want to install xp to your computer while you are using utimate vista you can install it...
but you must have a large space of memory to install xp, tnx anyway hope that i can help...
Jan 08, 2009 | Microsoft Windows Vista Ultimate Edition
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA FROM DVD DRIVE
first you must check your XP/Vista cd if it is bootable then open the bios setting change the first boot to CD ROM save and exit the bios insert CD wait for a second if the CD is BOOTABLE if so then follow the instructions of formating drive. But before you do that you must be sure that you have all the driver need to you PC for security you must use the black drive then install the XP OS.
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
Sathish_pmssld
  1. You have to go to your bios settings by Pressing Delete key while booting and change your boot sequence to cd, floppy, hdd. Save and Exit.
  2. Insert your Windows XP SP2 disc.
  3. Press any key to boot from cd...
  4. Wait while Windows is setting up.
  5. When a TOA appears, Agree with their agreement by pressing F8.
  6. Install a fresh copy of Windows XP by pressing ESC key.
  7. Install on the selected Partition and Press Enter Key.
  8. Choose Format it to NTFS file quick.
  9. Wait until it reboots your computer automatically.
  10. This time after rebooting, the message "Press any key to boot from cd" shows up again. *DON'T Press any key to continue to Windows Installation.
  11. The Windows Installation is approximately 39mins. On 33mins, a message box will appear. Set your Time and Regional Settings and then click OK.
  12. Wait again 'til the box appears to Enter your Product Key.
  13. When you successfully entered the right key, wait 'til it completes your installation.
  14. Just click Next,Next, then Finished.
  15. After Clicking the Finished button, your installation finishes and loads through your desktop.
*Your vote is highly appreciated. Thanks in advance. Feel free to ask me anything. I would be happy helping and assisting you.
Best regards
Dec 26, 2008 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
XP to vista and install sata drive
Yes vista will format & install on the new drive. Just make sure if there is an o/s on the old drive that you set up windows vista as a dual boot if you wish to keep using the o/s on the old drive. Hope this helps.
Dec 25, 2008 | MSI K8N Neo-FSR Motherboard
My laptop contains windows vista and i want to install Windows XP
i am using toshiba satellite l300model laptop. My laptop also contains windows vista. i want to install Windows XP as well. Some of my music software does not support Vista. Can you
please help me on how can i install Windows XP and how can i download the
XP drivers. I... Read more
May 20, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
