Question about Car Audio & Video
Lites dim when u turn up the stereo - Car Audio & Video
  • 3 Answers
It means that the stereo is hungry for power so uses all of the electric which is used for the lights. Also maybe your car battery is dying
Posted on Jan 02, 2013
The dashboard illumination is dim and won't go bright also the Foglights will not turn on and also the stereo is dim. Changed the light switch but still the same
is it adjusted by the light switch left on bright right dim all when lights are on all dash lights will dim thats normal
Apr 19, 2016 | 2008 Volvo XC90
What does the sony stereo orange wire connect to in 96 jeep cherokee
The orange wire from the Sony is the illumination wire, 12 volts put to this wire will dim the display on the stereo. The Jeep's BLUE/RED wire should have that function. Use a test light or multi meter to check for 12 volts + on that wire when the park lights are turned on.
The stereo will still function perfectly without the connection, just won't have the auto-dim feature.
Feb 18, 2014 | 1998 Chevrolet Malibu
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
How do i get lites on face they are dim
Check your car battery. Try to turn off your headlights and aircon then look at your stereo if its bright, if it has bright light try to turn on your aircon and headlights then if the light of your stereo turns dim the problem is now on your car battery. The battery cannot supply all the electricity needs of your car.
Jun 28, 2011 | Jensen CD-4010 K CD Player
My digital dash lights have gone out i cant see anything on the dashboard at all, what is my problem i have an 89 ninety eight oldsmobile 4 door
hi ther .it sounds like you your dash lites have been dimmed. you should be able to turn your head lite switch to the right and they should come back on. or there might be a dial to turn under the headlite switch to brighten the dash lites. but there is a switch that dims or brightens your dash lites. hope this helps. have a good day
Jan 15, 2011 | 1989 Oldsmobile Ninety Eight
Interior lights do not shut off when door is closed and engine is running or not running
if you have a pull out knob to turn on the lites then you need to turn it to right and inside lites will go out.
when you turn it the dash lites go high or low but if you turn it all the way to high side it will turn on inside lites.
if you have a rocker switch for lites then should be a thumb switch to dim dash lites and it works same way .
Jul 27, 2010 | 1999 Oldsmobile 88
My stereo turns off and lights get dim while
Take your car to Advance Auto or other auto parts store and have them run a free diagnostic test of your alternator.
Nov 04, 2009 | Radio Communications
Ctsy/dome lites remain on dimly when door is closed
Try removing one bulb or the other at one time preventing power completing the circuit if the problem in a light. Those ones are tuff to find but second place I would start is removing front door cils and cleaning out and playing with wires in there to see if you can find a problem, also wires in the boot between door and frame, usually drivers side cause it's used more often.
Apr 11, 2017 | 1987 Chevrolet S-10 Pickup
When lights turn on, stereo light go completely dim
Sir,
cut the dinner wire from the back of the radio and light will be bright again
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 10, 2009 | 2005 Honda Civic
Ds lite bottom screen
Could be the back light.Probably need to replace it.They are reasonably cheap.
Jul 01, 2008 | Nintendo DS Lite Console
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
