I have canon ir 6001 machine but i have problem the code error 264 . it have not ebale to reset . so i want salotion how i can do it and what is the problem .
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
spinal
  • 287 Answers
SOURCE: canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Posted on Apr 20, 2008
SOURCE: How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Posted on Jul 12, 2008
SOURCE: Canon IR 8500 Error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
Posted on Aug 05, 2008
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
Sir you tell me how can I reset canon ir 2002n error code e002-0000
Hello . to clear that error you need to replace the fixing heater unit
Apr 25, 2016 | Canon Office Equipment & Supplies
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
Nov 05, 2015 | Office Equipment & Supplies
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
Canon iR 6001 showed me error code of e000005-0000 what can i do to solve the problem
The error code E000005-0000 means that you need to replace the upper cleaning web for the upper fixing roller. When you pull the transfer unit out and you see the fixing unit with the yellow cover on it. The web is under the cover. It needs to be replaced to solve the problem.. Good Luck
Sep 17, 2012 | Canon imageRUNNER C6800 Copier
Canon ir2116j the problem is after pressing the print butten the lamp carrage not moving right side and display light shut down then again reset what is this problem
wich is the error code that machine shows? i.e. E00002-000
You said that machine says turn off and on, these happens when the error code is present.
And by the way do you mean IR2016J, 2116 do not exsist!
Aug 24, 2010 | Canon iR 2016i Black and White Copier
Canon ir 7086 error code e00005-0010
give me the solusion of error code 225 of machine cannon 7086
reply plzzzzzzz
Apr 07, 2010 | Office Equipment & Supplies
E000005-0000 what i can do to solve this problem
canon copiers model ir 6001 error code 000005-0000 what i can
do to solve this provlem please
Oct 19, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Alignment of Tocuh Screen Panle of Canon Copier IR-6000/6001
I believe under the aditional funcation screen, you can calibrate the touch screen. Is the screen working at all? Does it look like there is Water on it and you can not wipe it OFF. If so, the display screen is cracked and needs to be replaced.
Apr 02, 2009 | Canon imageRUNNER 6000 Copier
32 people viewed this question
k24674
