Question about Canon IP2700 Inkjet Printer
The printer is ready but an error always occured
It keeps on telling me that Error Number 5100 has occurred. I turned it on and off for so many times and it is still not working!
  • 70 Answers
nyilasrobert
  • 627 Answers
SOURCE: Error 5100
error 5100 in all Canon printers is almost always something simply blocking the carriage.
Posted on Jul 24, 2009
IB4G2008
  • 3587 Answers
SOURCE: Canon Pixma MP150 service error 5100
sounds like an engine failure..from that code..is this under warranty, by chance?
Posted on Mar 25, 2008
  • 1126 Answers
SOURCE: Canon mx330 Error 5100 Error 5100
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Posted on Nov 04, 2009
  • 1382 Answers
SOURCE: an error 5100 always occur in my pixma iP1980 whenever i print a
This particular error has a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.You can find the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display). Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Thank you !!
Posted on May 25, 2010
  • 2246 Answers
SOURCE: always time sow Error number; 5200 A printer
Here's How to Reset Canon IP2770 Error 5200:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Posted on Mar 16, 2011
Error occured/error 5100
just reset your printer eeprop by software.type generaltool for canon mp160 and googlee it.run software,connect your printer and reset your printer eeprom.
Jun 17, 2012 | Canon PIXMA MP160 All-In-One Printer
New printer canon pixma mx360....... when i pushed the botton on it says printer error has occurred 5100
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the Error 5100.
To solve this error follow the given steps:-
First of all turn off printer
then remove both the cartridges from the printer.Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches. After it return the cartridges and turn on the printer.Error will be automatically remove
I hope this solution helps you
Let me know If you have any more Confusion, questions or issue regarding your problem
Thank you and Keep using FixYa!
Jul 18, 2011 | Canon Pixma MX360 Printer
Always time sow Error number; 5200 A printer
Mar 16, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Error - 5100 and 6A00 keep appearing. What should I do?
Error 5100 means an error occurred in the carriage encoder signal. Error 6A00 means an error occurred in the AP motor during purging operation. To fix these two errors you need to replace:
- Carriage unit (QM2-2922)
- Timing **** strip film (QC1-6394)
- Logic board ***'y (QM2-3078)
Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM
information print). If the waste ink amount is 7% or more, also replace the ink absorber kit (QY5-0146) when
replacing the logic board ***'y.
- Carriage motor (QK1-1500)
-Sheet feed unit (QM2-2916)
-Purge unit (QM2-2925)
Feb 02, 2011 | Canon Office Equipment & Supplies
An error 5100 always occur in my pixma iP1980 whenever i print a
Thank you !!
May 25, 2010 | Canon Office Equipment & Supplies
Keep getting service error 5100. did a deep
An error occurred in the carriage encoder signal. - Carriage unit
Timing **** film Logic board* Carriage motor
Oct 08, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Error 5100
Jul 24, 2009 | Canon PIXMA MP150 All-In-One InkJet...
5100 error
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
good luck
May 19, 2009 | Epson Stylus Multifunction Inkjet Printer/...
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Mar 25, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon IP2700 Inkjet Printer Logo
76 people viewed this question
old marine
old marine
