Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Icemaker won't stop making ice
The icemaker keeps making ice to the point that after the ice bucket fills to overfloeing, the ice freezes up in the maker and we have to use up all the extra ice asnd then remove the icemsker, thaw it and reinstall. This starts the cycle again. Any suggestions?
    Novelist:
  • 88 Answers
There should be a saftey shut off bar or something in there to shut the ice maker down, look inside and see if there is a bar, or holes where a bar should be installed, if there is a bar, the the auto shut feature is not working you will need to replace it if thats the case, best of luck, hope that helped
Posted on Jan 20, 2009
ED25RFXFW01 icemaker
Sounds like the=> W10408179 Dual Water Inlet Valve
has began to seep water at the valve and out through the ice maker fill tube and down into the ice bucket. About all you can do when this happens is replace the above W10408179 Dual Water Inlet Valve. I will be here should you have questions, Thanks Sea Breeze
How to test the valve can also be found HERE
Nov 08, 2012 | Whirlpool Refrigerators
Ice maker quit water line works intermittingly
icemaker quite? hire a new icemaker. industry joke sorry.
First things first, is it cooling ok? if yes then proceed.
im assuming it stopped making ice altogether, and not a matter of making ice but not dispensing.
If your ice bucket is located in the door itself, you have an electric eye icemaker system, which electronically determines if the bucket is full or not. this electric eye system, located on both side walls of freezer, consist of a transmitter board and a receiver board. you could have a problem with these boards, the icemaker itself, a bad water valve, or depending on the model year, a icemaker fill line that can get clogged with ice, but due to a faulty design, a fill tube heater must be installed.
if your bucket is not in the door, but located directly beneath the icemaker, then disregard the electric eye system info and the fill tube heater info as well.
Mar 01, 2010 | KitchenAid Superba Architect KSCS25INSS...
My icemaker in my large French door Samsung refrigerator takes forever to make more ice. Is there some way to increase ice production? It takes 2 to 3 days to fill up the ice bucket. There is nothing in...
There is no way to speed it up..
If the bucket is empty - 2 to 3 days to fill is normal..
It takes somewhere around 37 minuets for new cubes to freeze,, then dump.. Cant make the ice freeze faster..
If it has a inline filter on the water line - replace it.. If it is clogged it could slow the water that is going in..
If you-all use allot of ice and empty it before it catches up - I would suggest getting a bag of ice from the store and put some in the bucket to keep the ice level up..
Have a nice day...
Sep 08, 2009 | Samsung RF265AA Bottom Freezer French Door...
Icemaker makes Ice But doesn't dispense it.
Had same problem. Looked everywhere and found no solution i'm a not a repairman...they probably do not want to post so they can make 150 for a repair visit. At least try this first it may save you $$. Remove ice bucket from freezer. Remove 2 screws @ auger...remove cover and auger ....remove spring and large hex shaped shaft. heat the large shaft end with a torch and put it back in hot side toward motor until the motor end is not frozen. No torch you can use hot water...but that may freeze again.
This was happing because my flap to the ice was not closing all the way .
Manual for parts can be found here it shows ice maker parts on page 7.
Good Luck Kono
Aug 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker not working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Dec 05, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice on whirlpool refrigerator
Hello.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
Dec 05, 2008 | Whirlpool Refrigerators
Icemaker quit working
Hello.
Nov 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Sub-Zero 685 Ice Maker Problems
There are 2 important things to be aware of with these icemakers. One is that they need to be completly level, both side to side and front to back. Second, the fill on these icemakers should be right about 100 milliliters. Get a measuring cup with Ml markings and pull out the icemaker. Fast forward the icemaker by jumpering the little test terminals behind the square cover. You need to connect the terminals labeled T for thermostat and H for heater together with a piece of wire. Be careful, as there is 110 volts to these terminals. Keep the wire there for about fifteen seconds,then pul it out or the icemaker will get really hot. Just as a note, for all this to work the icemaker must be plugged in, turned on , and you must hold down the switch that is pushed by the bucket. If there are no test terminals on the icemaker, then you can just fast forward it by pushing the fingers around in a clockwise direction looking at it from the square end. Anyways, once you get it moving, put your measuring cup under the fill tube and wait for the fill cycle. the water should be very close to 100 ml (range is 90-120ml). If your fill is correct, and the icemaker is PERFECTLY level, then make sure the fill tube is inserted all the way into the icemaker. Hope you can wade through all this for an answer. Good Luck!
Jun 25, 2007 | Sub-Zero 690 Side by Side Refrigerator
Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Jun 15, 2007 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
189 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
