Question about Fisher and Paykel Refrigerators
Door dropped and dont seal good - Fisher and Paykel Refrigerators
    Top Expert:
  • Fisher and P... Master
  • 35,672 Answers
The door hinges are adjustable to correct sagging and poor sealing
Posted on Jan 02, 2013
How to replace door seal miele novotonic 502
Hi Adrian,
Open machine door then turn power off. Remove 3 bolts on front of machine. Remove the soap draw and remove the 2 (or 3) screws.Separate the front of the door seal from the metal front of the machine and fold the door seal in towards the drum. Front of whole machine will now hinge open (there is a spring catch at the bottom where the pump filter is - so dont be scared to use a little force). Use a screwdriver to loosen and remove the metal wire clamp that sits around the door seal. Once off, door seal can be removed from the outer drum. Replace with new door in reverse order. Note that putting on the new door seal to the outer drum is a bit of an art and may take you a few attempts (so be patient but persistant), as you must make sure it is seated in position correctly. Good luck.
Aug 19, 2015 | Miele Washing Machines
Brand new upright Freezer forming Ice above top shelf and now drops of moisture inside door model WFM1800 door seems to be shut tight
Is the unit level to the ground or platform it sits on? The reason I ask is that many cases after closing the door a vacuum occurs, after this vacuum settles the door can allow gap in which will cause this issue. So with out opening the door or 10 mins after, check the door seal to assure a good seal. Some door can be modified to seal by heat (blow dryer or steam). BUT, inspect unit before assuming this is the issue! I can further assist you in how to apply heat to reform gasket on door or even reshaping door to seal better if needed.
Get back to me on model you have and the results of your findings about this seal issue.
Basically, you have an air leak and this is the cause of a seal issue. Results in a condensing warm air mixing with cold air and causes ice cycle to form. Usually around the top because heat rises and cold air drops. With this information you can adjust the door to meet the cabinet and seal you years to come.
Good luck and feel free to send me information if needed.
Oct 23, 2013 | Westinghouse Refrigerators
Door was not sealed tightly for about a day resulting in some frost inside freezer. Door appears to be closed but door ajar light is still lite and alarm is still beeping. What do I need to check?
The door seal has a magnetic property to it. Until the freezer gets to a certain degree the magnetic porperties of the door seal dont react properly. Make sure the door seal is properly adjusted. If the door was left open it could have semi warped the door. This gets corrected when temp drops to correct temp. Reset freezer by unplugging and waiting for a few minutes. If problem persist contact appliance technician.
If you have any more questions you can comment me back.
Jul 28, 2011 | Frigidaire Freezers
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Apr 21, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Wateris leaking fromfront of both drawers
I am assuming this happens when you run the dishwashers. It is likely the drawer door seals are dirty. This is the brown liner around the door. The other reason could be the vacuum seal is not working. The dishwasher runs a small pump when you start it which helps create a vacuum seal. But this failing in both units at the same time is unlikely.
Try cleaning the door seals (refer owner's manual) and see if it makes a difference.
Good luck
Nov 06, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Door does not seal, hinge looks fractured. the door looks like it has dropped and does not seal at the top, also when lowing the door there is no resistance and it wants to just flop down. Both hinges look...
you'll probably need to replace the whole door and hinges. the internal springs (inside the door) may have failed and allowed the door to drop and damage the hinges. don't believe it's fixable, but is replaceable.
at what cost, i can't guess- even if the parts are still available! compare the cost of fixing to the cost of replacing!
good luck!
Oct 04, 2009 | Ovens
How to remove and replace door seal on a hotpoint wt 741
the door seal are hard to do just take a good look at it befor you take it off you can take the frount panel off the washer to do this job give your self a few hrs so you dont rush
Jun 28, 2009 | Hotpoint Ultima WD72 Front Load...
Fidge will not stop nunning and is not very cold
How old is it?  Coolant level may be low.
May 29, 2009 | Refrigerators
Refrigerators Logo
99 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
