Question about Sony Televison & Video
Sony flat panel has sound no picture solid green light.
There was a flash and lound sound with a little smoke then the picture was gone. the sound is fine and the channels can be changed. The on light says green. Can this be fixed if so how?
  • Sony Master
  • 8,617 Answers
Replace the inverter board I would need the model number to assist further but usually its the inverter if you have an LCD tv and the sound works but no picture
Posted on Jan 02, 2013
  • 8 Answers
SOURCE: no picture or menu
If your dealer has not already told you, I suggest you unplug the unit from the wall and let it sit for 30-45min. Plug it back in and hope...
Posted on May 04, 2007
pattersj78
  • 70 Answers
SOURCE: Sony Flat Panel tv with no Picture
Flat panel TV's typically do not have "bulbs," but rather backlighting.  Plasma displays are especially touchy during movement.  I would suggest checking your warranty status, as it's probably not something you can easily repair.  If you wanted to take on the repair yourself, be careful not to lay down the screen, as it will drastically shorten the life of the Plasma display.  I would start with checking the system boards for possible damage, since you did hear a "click," It was probably a fuse, chip, etc.
Posted on Oct 19, 2007
  • 12 Answers
SOURCE: My Sony KDE-37XS955 won't show
I would need more information ,count the exact number of flashes and any pause in between flashes this is a code for troubleshooting. The TV went into protection mode
Posted on Dec 23, 2008
  • 3 Answers
SOURCE: sound but not picture - capacitors look okay, hair dryer didn't w
Insignia NS-32LCD has problems. Has sound but no picture. Back light is present as well as green and purple vertical lines. I replaced power supply and PC BOARD 782.32FB18-520A no help. Flashlite test showed nothing. Any suggestions???
Posted on Aug 14, 2009
  • 50 Answers
SOURCE: Toshiba 42hp66 without an image
Hello, You most likely have a bad Y sustain board! Part #'s are:
6871QYH053A, 6871QYH053B, 6870QYH005B, 6871QYH953A, 6870QYH105B.
Here is a link to the part you need!
http://www.discount-merchant.com/Y-SUSTAIN-PN-6871QYH053A-6871QYH053B-6870QYH005B-p/vizio-sku9506.htm
I hope this help you! Please feel free to give me a call or message me if you have any questions! Ask for Dave!
Thank you! :-)
Dave
1-503-432-9904
pleasefixitdave@yahoo.com
Posted on Aug 26, 2009
Solid green light but no picture
I think this is a projection set. Sonys are called SXRD type lcd projection . Little diff from DLP types. But they do have a lamp. Unplug set plug back in then turn on . Count blink code. Check lamp also. blink code is 2 digit code. Code will give clue to failure.
Oct 01, 2013 | Sony KDF-E42A10 42 in. LCD Television
I have a sony kdl-32S2000. No Video - screen is black. No sound. Power light is on solid - does not flash - and is green.
Sounds like SCL - SDA line has some short circuit. Contact any service technician. This is not a user repairable work.
Sep 05, 2013 | Sony Bravia KDL-40S4100 40 in. LCD TV
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
TV won't power on
ya u repair ur smps power sullpy soon ,nither ur power supply gone damage
Jun 02, 2010 | Sampo PME-42S7 42 in. Plasma EDTV
My 50 in jvc will try to turn on but the lights
sounds like main board/if it was anything else u would get sound no picture john
Jan 08, 2010 | Televison & Video
MY SONY 006 IS FLASHING 4 GREEN BLINKING LIGHTS
U have power and sound right?The backlight video inverter board is the prob.
Sep 29, 2009 | Sony QUALIA 006 Television
Same problem: picture goes out
Sounds like you need to replace the lamp. The owners manual should show you how to replace the lamp. You can order the lamp through Sony on their website. Good Luck
Jan 24, 2008 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
63 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
