Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
Sony Wega kdf50we655 replaced bulb lights flashes green five times then goes red what's the issue?
  • LG Master
  • 8,617 Answers
The 5 blinks is indicating the lamp driver (ballast) has failed. You can get the replacement ballast for your model at the top of the following page
http://tvcircuitboards.com/sony_projection__dlp_circuit_boards
They can also assist with installation information,
Posted on Jan 02, 2013
  • 208 Answers
SOURCE: Sony Wega
Most of the time this is caused by a defective lamp. If the light blinks the number of blinks is a failure code.
Posted on Feb 03, 2008
plopit40
  • 16 Answers
SOURCE: light bulb flashes 3 times, TV won't turn on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bud news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois
Posted on Nov 15, 2008
SOURCE: Replacing the bulb for LG RE-44SZ21RD Projection TV
Do you see the microswitch on lamp cover?
Posted on Dec 30, 2008
SOURCE: lg 52sx4d not starting up
The flashing green bulb light means the access door for the bulb on the lower right side of the TV is open or loose. There are two screws that hold it in. If they are tight, maybe the interlock switch is bad or disconnected. Open the door, and hold in the little white interlock button while turning on the TV. If it still doesn't work, there are wires leading from the switch to a connector about halfway across the TV on the bottom. Connector might be loose. Unfortunately, it is hard to reach. You might have to remove the screws across the bottom rear edge that hold in the chassis and gently slide it out to reach the connector.
Posted on Mar 11, 2009
  • 8457 Answers
SOURCE: I have a LG rear protection tv. I believe
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Posted on Jun 05, 2011
Sony grand wega 3lcd light is flashing red 3 times
U might just have a bad ballast. It generates the high voltage to fire up your bulb.
Jul 28, 2017 | Sony Televison & Video
I have a Sony tv KDF50WE655, the other day while I was watching tv, heard a noise and the tv went off, displying the lamp red light..I ordered and replaced the lamp. I made sure the lamp is ok and the door...
Please make sure lamp cover is fixed properly in its position after lamp replacement as it has to press a safety switch located nearby lamp cover.
3 times red blink problem is related with that lamp cover safety switch only.
Hope this will help.
Thanks.
May 27, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a tv sony wega 50" model is kdf50we655 the screen doesnt show nothing but the sound woks,i wanna buy the lamp to see if it is the problem,but i would like to know if there is another issues...
the lamp always shatters when blown,and go with a bang.remove the front speaker grille via the black coin-taking screws either side at the rear.the lamp is located fairly central.the lights flash red/green red/green when the lamp has packed up...hope this helps
regards,steve
Jan 18, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
After replacing a bulb, when power on, it flash first green and goes to flash red continue to flashes red about 5 flash each time what should i do?
5 is a lamp driver fault, could be a poorly seated bulb or a bad ballast. Usaly it is a bad ballast. Previous bulb failure could have dammaged the balast.
May 07, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Sep 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
106 people viewed this question
Computer Repairing
Computer Repairing
