Question about Asrock Computers & Internet
Just built my first PC and it is stuck on POST screen and I cannot reset BIOS. Is there a way to do so besides jumper'ing it and/or taking out the battery on the mobo. I have tried both of those.
Stuck on splash screen displaying AsRock logo. Will not install Win7 from optical drive, will not recognize keyboard to enter BIOS. Will not reset BIOS so I can reconfigure it.
  • 5,660 Answers
Hate generic information.
What is the model number?
But in the meantime..................
1) Do you have all the power cables needed plugged in?
Besides the 20 or 24-pin ATX main power cable, there is another power cable that goes to the motherboard -> Maybe.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This is power for the Processor. Some of the older AMD boards do not use it. Intel Pentium III's and Intel Celeron's (Of the same period), do not use it.
Newer motherboards may require this power cable instead,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
NOT to be confused with this graphics card power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
Yes? We're good to go?
2) Let's regress then.
The motherboard is mounted to a Support Plate.
The Support Plate can be a separate metal plate, that mounts to the motherboard; or is an integral part of the computer case.
The motherboard mounts to the Support Plate with either plastic Spacers, or metal Standoff/s.
If you are using metal Standoff's make SURE that everyone of them on that Support Plate, line up with a motherboard mounting hole.
If not there is the likelihood that a metal Standoff could touch an exposed solder joint, on the bottom of the motherboard.
Result?
Short Circuit.
MOST of the time the problem can be alleviated by removing the 'offending' metal Standoff; or moving it to the correct spot.
4) Did you FOLLOW Anti-Static Precautions?
5) Did you apply Thermal Paste, and properly?
6) Is the Processor fan hooked up?
7) Have you removed the Ram Memory, and reinstalled again?
Ram Memory can easily be bumped during the build, and you won't know it's loose.
Visual inspection will NOT do.
You have to remove, AND reinstall to be Assured.
Do you know if the Ram Memory is correct for your motherboard, AND the Processor you have installed?
Ram memory typically operates at HALF, of the Processor's FSB.
Front Side Bus.
Do you have a Ram Memory module ('Stick'), inserted into ram memory Slot 1? (DIMM 1)
This is the ram memory slot the Processor reads first.
MUST be a ram memory module in Slot 1, no matter what.
Where the other ram memory modules are (If more than one), installed doesn't make a tinker's dam in this particular moment.
You can rearrange for setting up Dual Channel later.
(If the motherboard supports using ram memory in a Dual Channel configuration)
8) Have you tried using JUST the Processor, and Ram Memory?
You should get the BIOS Setup screen.
If not something is dead wrong with that motherboard.
(Provided that the Power Supply is deemed GOOD)
9) Yep. You guessed it. Power Supply.
Do you know beyond a shadow of a doubt Mr.Mason,.......
(Wait a minute...........too much Perry Mason...........)
Do you know the Power Supply is good?
Sometimes even a new one is a dud.
Do you have an inexpensive multimeter I can guide you with, for testing the Power Supply?
They're about $5 to $12. Available at a multitude of stores. An auto parts store is but one example.
I have seen them in checkout aisles at major discount stores.
[Your Power Supply is a converter.
Converts high AC Voltage; 100 to 240 Volts;
to Three main low DC Voltages;
3.3 Volts, 5 Volts, and 12 Volts.
In comparison two D cell flashlight batteries produce 3 Volts DC.
I can safely guide you in testing ]
If not, do you have an alternate KNOWN to be good, Compatible power supply; that can be used for a temporary test unit?
Do you know the Power Supply has the required Wattage?
Did you use, may I ask, a Power Supply Wattage Calculator to arrive at that conclusion?
http://support.asus.com/PowerSupply.aspx?SLanguage=en
http://extreme.outervision.com/psucalculatorlite.jsp
Let's get you into BIOS Setup, and go from there.
(Yeah I know. Duh!)
Please post additional questions in a Comment.
Regards,
joecoolvette
Posted on Jan 02, 2013
  • 6 Answers
SOURCE: winfast k8s755A freezes at startup
Ok I got e-mail from Foxconn and they told me to use a single sided 256 DDR RAM to get past post. So I did, then I wnt to BIOS and set all my settings, saved it restarted turned off the PC then returned my 1GB Ram then all worked just fine. This is an issue coused by haveing a Samptron 64 CPU.
Posted on Nov 21, 2007
map9966
  • 2351 Answers
SOURCE: asus m2n-e sli locks up at bios post splash screen
Sounds like a bios issue. Try resetting the bios, pg. 2-19 in user manual. After clearing the bios jumper, make sure you set it back to pins 1 & 2. If you still can not get into the bios main menu than head to Asus, click this link.
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Since this is a new board & all Asus boards are warranted for three years I suggest you talk with an Asus tech. If you flash you're bios during the warranty period you may void the warranty. You can call Asus M-F, EST 8:00AM-5: PM.
1-812-282-2787. Not sure you have this number in you're manual. Chances are Asus will send you a new bios. Or you can buy a new bios for $5.00 not including S/H. From Asus online store. Click on this link. http://estore.asus.com/shop/
If I can be of more service, just post back & let me know how thing go.
Mike
Posted on Apr 27, 2008
  • 3 Answers
SOURCE: New system, stuck at the Gigabyte Logo screen with no keyboard
It is a CMOS PROM problem. Better to go for a replacement of the mother board.
Posted on Apr 17, 2009
  • 733 Answers
SOURCE: Problems with the P35 Platinum board. Gets stuck
that's easy check on the motherboard for a battery pull out but carefull to not brake the support put it back and try again .
Posted on Nov 30, 2009
bronk50
  • 27725 Answers
SOURCE: I decided to make a
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
if this does not fix the problem
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
Posted on Dec 02, 2010
My new PC build is stuck on AsRock POST screen
Check that your new build PC is connected properly. Also make sure that the RAM is seated properly and that it is the correct type and speed.
Jan 02, 2013 | Computers & Internet
Remove or reset Dell inspiron 530s bios password
try this:
1- shut it down then open the computer box
2- find a green or blue jumper beside the memory slot or Data cable slots
3- remove jumper , then turn computer on
wait for 10 sec then shut it down
4- put the jumper back and close the computer box
5- turn the pc on and have fun
Feb 08, 2012 | Dell Inspiron 530s Desktop Computer...
I forgot my bios password. and i cant access my pc. can you help?
You got 2 options:
1-Start the pc and when you see Windows Welcome screen / Login screen, press ctrl>+alt>+del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows. Now you can reset your account password from "Control Panel -> User Accounts". Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2-Some computer systems have a setting in the BIOS Setup to disable the password. The BIOS Setup is accessed with the F1, F2 or DEL key during boot up. If you have forgotten your password, most systems have a jumper on the motherboard that can be pulled off to clear the password. If there is no jumper available, you can also remove the battery for 5 minutes to clear CMOS.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 05, 2011 | Samsung R519-53S Notebook
The compuyter made a very funny running sound and then the screen with black. I can not start up the laptop, but 2 blue power buttons are on.
You got 2 options:
Aug 05, 2011 | Dell Vostro 1500 Notebook
Hello, I have a Dell Studio 1537. I can turn it on but I can't get the user password to open into Windowsw. Help????
You got 2 options:
1-Start the pc and when you see Windows Welcome screen / Login screen, press <ctrl>+<alt>+<del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
For assistance with this process we recommend that you contact Technical Support for more interactive support or you may choose to go to a Authorized Service Center. There may be a consulting charge for this service.
Aug 05, 2011 | Dell Studio 1537 Laptop
I have a studio 1537 Dell laptop and I can not open nor can I change the password to get to Windows. Can you help
You got 2 options: 1-Start the pc and when you see Windows Welcome screen / Login screen, press ctrl>+alt>+del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows. Now you can reset your account password from "Control Panel -> User Accounts". Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen. 2-Some computer systems have a setting in the BIOS Setup to disable the password. The BIOS Setup is accessed with the F1, F2 or DEL key during boot up. If you have forgotten your password, most systems have a jumper on the motherboard that can be pulled off to clear the password. If there is no jumper available, you can also remove the battery for 5 minutes to clear CMOS.
Aug 04, 2011 | Dell Studio 1537 Laptop
My dg31pr gets stuck on bios screen and no matter how many times i restart it it keeps getting stuck there.if i m lucky after an hour or so it starts.i really need help with this problem.my pc has 500 gb...
Hi.
Fisrt of all remove the 2 external hard drives from the computer, boot the computer up and see if it still hangs on the post information screen.
If it doesn't then the BIOS has a problem detecting the externals thus why its hanging on the BIOS.
If it still hangs try to completely reset the BIOS either by putting the plastic jumper in the "on" possition and turning the computer on. The jumper is located to the left hand side of the "Front Header" (power switch, reset etc) or remove the power cord from the rear of the computer and then take out the motherboard battery and leave it out for 20 minutes.
That should clear the CMOS and reset the BIOS and stop it hanging on the post screen. Remember that once you have done this you will need to set the date and time.
Regards.
Jun 15, 2011 | Computers & Internet
I can not access the BIOS lenovo thinkpad T2 because Already Locked .. Even when I unplug my battery can not even access the BIOS at all .... please help me
I am glad to HELP YOU!
I have to tell you that sometimes removing the CMOS battery doesn't solve the BIOS password resetting.
You have to take some other steps to succeed:
# power OFF
# remove the back cover of your machine [the DIMM cover only = Dual Inline Memory Module]
# put a jumper on the password jumper contacts to short the circuit [or short-circuit the password jumper pads]
# restart the machine and wait until the POST is done
# now the password should not appear again, so the security code was removed
# put back the the DIMM cover
YOU'RE DONE!
For some extra-details read HERE.
GOOD LUCK!
Apr 22, 2011 | Computers & Internet
Reset bios password toshiba a200
You can use Kill Bios or just take the cmos battery out for 10 mins
May 24, 2010 | Toshiba Sattelite® Pro A200 PC Desktop
ASUS P5N-E SLI
Try RAM with a different speed. My 800 mhz RAM didn't work until I installed 533 mhz RAM and adjusted to 800 mhz in BIOS. Newly built PC, default must be set as 533 mhz because I reset the CMOS and still couldn't POST to BIOS. Only taking out all RAM gave me any sort of audible error code. Luckily I found some 533 RAM before I RMA'd the board.
Jul 06, 2008 | ASUS P5N-E SLI Motherboard
Computers & Internet Logo
98 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
