How do i fix the convergence on my apex gb5801
I am having a problem setting my convergence on my apex tv model number gb5801
  • 8,617 Answers
Replace the convergence ICs very common problem for all rear projection Tvs that develope a convergence control issue.
Posted on Jan 02, 2013
  • 579 Answers
SOURCE: APEX GB65HD09W Convergence Issue!
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem by gently moving the heat sink (which the modules are connected to). This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests.
Best of luck, hope ya fix it.
Posted on Jan 18, 2008
  • 4 Answers
SOURCE: Sony HDTV Convergence Issue
I have the same issue, on my 60pp9202. It works some times, and then its ok. If I leave it on, it will be ok, until it gets turned off.
Chuck
Posted on May 09, 2008
  • 70 Answers
SOURCE: i have a 52 inch
you can go into the menu and manually adjust the convergence it will look better most likely but a television should always be converged by a professional when first bought any way because they can do things we at home cant. i have mine done by a professional once a year and do it myself once a month to maintain the best possible picture. good luck
Posted on Sep 22, 2008
ladywinn
  • 5138 Answers
SOURCE: Apex GB4308 43" tv have to set convergence each time I turn it on
Replace your STK ICs and look for Bad capacitor by vertical IC 100uf 35v.
Posted on Feb 16, 2009
  • 6 Answers
SOURCE: My apex gb5108 convergence lines wont line up.I'm watching 3d
possibly the convergance ics have failed or convergance module
soldercon or both not a very costly repair
Posted on Oct 04, 2009
Need diagram to rebuild and fix convergence issues
In a APEX set change the convergence chips (2) AND use the original remote to adjust the set. There are several sites like TV parts.com that sell kits based on brand and model number.
Apr 30, 2012 | Apex Digital GB43HD09 43" Rear Projection...
I HAVE A 51 IN APEX TV WHEN I TURN ON THE TV IT HAS PROBLEMS WITH CONVERGENCE IT HAS RED LINES BLUE & GREEN WHEN I GO AND GET THE REMOTE AND GO TO CONVFRGENCE ON THE MENUAL I PUSH RIGHT ON THE REMOTE...
Tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must require replacing,to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Apex Digital GB51HD09 51" Rear Projection...
I have a model GB43H09 apex tv. I am having a convergence problem, can this be fixed.
http://rds.yahoo.com/_ylt=A0geu.ZgCKhLgjIAXBFXNyoA;_ylu=X3oDMTEzbGQ5ZTZnBHNlYwNzcgRwb3MDMwRjb2xvA2FjMgR2dGlkA0g1MzJfMTQ2/SIG=126kbj3eb/EXP=1269389792/**http%3a//www.apexdigitalinc.com/manual/GB43HD09W.pdf
Here is your manual if all it is is adjustment. It most likely is the IC's that go bad that handle the convergence circuits. It is not hard usually, but you do need some electronic skills to get this done right. Brad
Mar 22, 2010 | Apex Digital GB43HD09 43" Rear Projection...
Aug 25, 2009 | Apex Digital GB5108 51" Rear Projection...
Convergence out of line
STKs must not have held up Look in back of set they are 2 Big Black ICs will have part number on them example STK392-110,if 110s use 150s.you can order parts from MATs 1-800-628-1118.
Aug 20, 2009 | Apex Digital GB5108 51" Rear Projection...
Unable to set convergence on apex gb51hd09 , controls won't get it into the ballpark
Replace both of your convergence ICs STKs big black ics will have part number on them STK392-110s etc if 110s use 180s other wise use same number on old parts. Call Mats 1-800-628-1118.
Aug 07, 2009 | Apex Digital Televison & Video
Apex GB43HD10 Convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 10, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Apex convergence
Try resoldering the convergence chips.
Nov 08, 2007 | Apex Digital GB5108 51" Rear Projection...
Apex 43 inch tv
Convergence is when you aim all three of the projectors, your tv has three, so that the images they produce all line up with each other. This usually doesn't generate a white line across the middle of the screen though, there is a button on the front panel of your set that automatically converges the three projectors, you can try using that.
Nov 06, 2007 | Apex Digital GB4308 43" Rear Projection...
Convergence and wavey picture problem
Actually you have 3 problems. The two that you listed and the third which is: Apex does not support their units. Ask anyone who has tried to get any service. Your problem sounds like a bad digital convergence box. I fix this problem several times a week but on name brand sets. Cost is usually less than $100 for the part. Some problems with Apex equipment can be fixed if the part is a common off the shelf part. That is not the case with your problem. Apex equipment is cheap for a reason. All posts that I have read say that they do not last long and you can't get parts. That has also been my experience as a technician. We don't even accept Apex units for repair anymore. Next time spend the extra money to buy a name brand unit and it will more than likely be repairable.
Jun 01, 2006 | Apex Digital GB5108 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
