Question about Dell OptiPlex SX280 PC Desktop
Optiflex sx280 does not start.
When Iturn the computer on, it shows a amber light blinking. None of the diagnostic lights turn on. I can't see anything on the monitor.
  • Dell Master
  • 5,660 Answers
Http://www.dell.com/html/us/products/optiplex/sx280.html
First time I've seen one.
Power Supply is bad.
How do I know? The Amber LED light that is blinking.
It is a standard diagnostic LED light now, and shows the Power Supply is bad.
Is the inside of the computer dirty also?
This 'kills' power supply's.
Computer unplugged from power, Anti-Static Precautions FOLLOWED, use a can, or two of compressed air for computers, and clean the inside of that computer out.
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-sx280_setup%20guide_en-us.pdf
Post back in a Comment.
Regards,
joecoolvette
Posted on Jan 02, 2013
  • Dell Master
  • 7,627 Answers
Fans working? Maybe a PSU failure? Replace CMOS Battery. Reseat/replace Memory Mods. It's getting a bit old. Hard to say with a older computer thing start to go one by one. I replaced a PSU after 7 years. CMOS battery dead, replaced, Then the Sound Failed, new sound card. etc. I stripped it of useful parts and sent it out into the world.
5 Suggested Answers
  • 2427 Answers
SOURCE: black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Posted on Jan 12, 2008
Bubbabear64
  • 2794 Answers
SOURCE: does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Posted on Jun 11, 2008
  • 54 Answers
SOURCE: Dell dimension 5150 Diagnostic Lights 31 BLINKING 3,4 SOLID
Hi you've either got the wires on the wrong connectors or they need to be turned around, i.e. red needs to be where black is. Hope this helps
Posted on Mar 31, 2009
ajx13
  • 110 Answers
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Posted on Aug 11, 2009
How do I fix problems of Dell computer 780 with power light yellow and black screen?
getnet,
What do the diagnostic led lights show. The diagnostic LEDs are located on the front of the chassis next to the power button. These diagnostic LEDs are only active and visible during the POST process. Once the operating system starts to load, they turn off and are no longer visible. Below is the manual that provides information on what the led pattern shows to help resolve the issue.
Optiplex 780 manual
http://dell.to/1HqoNmD
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Nov 20, 2014 | Dell Computers & Internet
DO you have any error messages on the screen? Or is just black? Please provide details. THank you
Jan 02, 2013 | Dell OptiPlex SX280 PC Desktop
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
IN dell optiplex sx280 model system we are using in this amber power led blinking continuly yellow color because of this not able to boot the system. kindly give the solution for the same
Hi there!
A blinking amber/orange light on the power button of your Dell Optiplex means a hardware failure. If you know how to strip down your computer to basic component, then I suggest you turn on with only the motherboard, processor, memory and PSU. If you are not familiar with this, I suggest you bring the computer to a qualified technician.
Hope this helps
May 09, 2011 | Dell OptiPlex SX280 PC Desktop
Dell 4700 blinking amber light. nothing else happens no fans no beeps.
HERE is the troubleshooting section for your PC from dell. It will give you at least a strating point as to what the problem may be. If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Apr 27, 2011 | Dell OptiPlex SX280 PC Desktop
When i turn on my pc a orange light starts blinking and the fan is not working and i'm not seeing anything
run a diagnostics on the system, press and hold "fn" key and then turn on the system it will go to the diagnostics mode and then it will comeup with and error or it will show you the malfunctioning component
Oct 26, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
I have a dell optiplex sx280 computer and monitor that has lapsed into ''power save mode'' and I have been unable to ''awaken'' it (I'm not sure which is ''asleep'': the monitor or computer!) from sleep. I...
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Jan 08, 2010 | Dell OptiPlex SX280 PC Desktop
Dell OptiPlex SX280 PC Desktop Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
