Question about Janome Memory Craft 9000 Computerized Sewing Machine
Do I have to put oil in the machine and if I do where
    New Friend:
Check your owners manual. Old machines need to be oiled newer one probably not
Posted on Jan 02, 2013
Where do i put the oil?
one drop, just one drop, on each moving part where two pieces of metal touch each other.
Jul 21, 2015 | Sewing Machines
Where do I put oil drops in my janone 2049, sometimes it gets stuck
Put just one drop of good quality sewing machine oil on moving parts. You can set machine back gently on towel. Remove bottom plate by removing each screw. Set each screw in a bowl so they don't roll anywhere. I have 30 years experience, so I personally run my machines when oiling so I can observe the parts that move. I d on't recommend this if you have pets & children, and leave that up to you! You should probably unplug machine and just look for anything that is NOT a gear, and just put one drop oil on those parts. Singer lubricant should go on actual gears, but ONLY if not already "greasy". Reassemble bottom plate. If your machine left front section opens up, one drop on those moving parts, and smear one drop of oil on hook. One drop top of needle bar. Do NOT oil or lube plastic parts. Never use cooking oil or bath oil; it will coagulate & damage machine. Always run machine with a scrap of fabric for a bit to distribute oil and to make sure excess does not get on your good fabric. Then rethread machine and replace bobbin and put fresh needle in. Yes, removed thread, bobbin, and needle BEFORE you lube & oil. Did this help? Best of days and nights sewing, Jimmy
Mar 31, 2012 | Sewing Machines
How often should it be oiled?
sewing machine oil is a very light oil so it does not hang around very long. if you are a heavy user of the machine it is best to oil it every month or so. if when it is stored for a long period it should be oil then too. there are one or 2 bits that need some light greasing too. some 3-1 oil is good for the job and do all the moving parts lightly and not too much oil as it will mark your clothes. hope this helps.
May 02, 2011 | Janome Jem Silver 662 Mechanical Sewing...
Trying to figure out where to oil my old White 265 machine. the manual only talks about how to oil the bobbin shuttle.
Hi. The rule of thumb is to put one drop (just one drop, that's all it takes) of sewing machine oil wherever two pieces of metal move against each other. You can also look for the oil ports(see tip on where to look for oil ports and for a photo, see www.robbiesews.blogspot.com). Your machine may also have small oil holes in the sewing machine housing, so put one drop of sewing machine oil in each of those.
Please use only sewing machine oil to oil your machine.
Hope this helps!
Robbie
Apr 13, 2010 | Sewing Machines
Do i need to put oil in my huskystar 224 sewing machine If so where do i put it in the machine
Check your user manual. More than likely there are a couple of holes along the lower part of the machine where the material goes (throat of the machine). Usually oil goes in those holes but only a drop. The best oil is from the bicyle shop used to oil chains--Tri-Flow. I have a huskystar 217 for 5 years and have never felt that it needed oiling. Sews like a gem.
Feb 09, 2010 | Sewing Machines
How to oil Spartan 327k sewing machine
Use only sewing machine oil. Get an oiler with a long spout so you can reach far places, put a single drop of oil on every place that has metal moving on metal.
How to oil old featherweight
Hi! I love the old Singer sewing machines!! Do you have the user's manual for your machine? The manual has great diagrams showing where to put oil and grease. If you don't, check out http://www.221parts.com/
In the meantime, look for little holes, often with raised edges and put a drop of oil in each. Put a drop of oil wherever metal moves against metal. You'll need to oil inside the head, on the right-hand side where the motor is located (DON'T oil the motor--use grease instead), and also underneath.
Good luck and let me know how it goes.
Dec 15, 2009 | White Sewing 1300DE Sewing Machine
Where do i put the oil in for the machine
You can only oil the moving parts that you can see very lightly
Oct 18, 2009 | Singer 2950 Mechanical Sewing Machine
Janome Memory Craft 9000 Computerized Sewing Machine Logo
27 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
