Question about JVC BR-DV3000U DV/Mini DV VCR
Can not record on JVC BR-DV3000
When pressing the record and play button the rec inh indicator lights up....and the dvcam tapes are set to rec
3 Suggested Answers
mistersony
  • 320 Answers
SOURCE: With MiniDV tapes, the DVCam indicator ignites and the reading becomes jerked.
It could be several things causing your problem. The video head may be worn, the tape guides may be out of alignment or you may have a mechanism problem keeping the tape from wrapping securely around the rotating drum. If you can use an oscilloscope, you should check the RF signal coming off the drum test point to see if it is clean, or if half the signal is missing (bad drum or video head) or not smooth (guides out of adjustment).
Posted on Nov 08, 2008
mistersony
  • 320 Answers
SOURCE: JVC BR-DV3000 Mini DV-DVCAM issue
If the problem only shows with Mini DV tapes, it can be a tape guide issue or a mchanism loading problem where the tape is not being properly "seated" into the tape mechanism. You will need to use an oscilloscope to look at the RF waveform coming off the tape to try and figure out where your problem is.
I HAVE A PROBLEM TO RECORD A DVD TO DVCAM MINI DV, JVC - BR-DV3000
If it is a commercial Dvd it probably has copy protection.
Dec 30, 2014 | JVC Video Cameras
JVC BR-DV3000 Mini DV-DVCAM driver
Try JVC first but what do you expect to find a driver for?
Jun 13, 2012 | JVC BR-DV3000U DV/Mini DV VCR
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Apr 13, 2009 | JVC Audio Players & Recorders
Jvc a 55u plays a movie from the store but I cant get it to tape a regular tape,it's a nice vcr and I have never seen this problem, the moves from the store are played great but when I put in my own tape...
Hi Diane,
Just downloaded the manual for your vcr it says:
1 Press menu
2 press up/down arrows to Function Set then press ok
3 press channel up/down arrows to Auto picture then press Ok or shuttle plus right arrow to set to on or off when using rental tapes set either to on or off to give the best picture
4 to return to normal press menu
For recording
1 load a cassette make sure the tab on the cassette is intact if not put some cellotape over the hole
2 set channel press up/down arrows then press enter
3 select tape speed sp/ep
4 press and hold rec and press play on remote or just press record on unit
5 to pause recording (cut out ads) press pause on remote to continue again press play
6 to stop recording just press the stop button
hope this helps and reflects in my feedback lol all the best
Jim Scott
Feb 28, 2009 | JVC HR-VP693U VCR
Nov 08, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Aug 22, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
panel.
• AV2: Audio/Video Input mounted on front
panel.
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Tapes not in 24p play for 2 seconds than stop, WHY?
The BR-DV3000 DV deck has LP inhibit function which is set in the operations menu. JVC does not recommend the use of LP mode and therefore locks this mode out by default. You can change this setting to allow operation in LP mode if you like but I don't recommend it. Using LP mode on DV tape causes the error rate to escalate due to the narrower track width produced by the slow moving tape. Good Luck, this is a nice machine! Joe Weibel Custom Electronics (customelectronics.org)
Feb 13, 2007 | JVC BR-DV3000U DV/Mini DV VCR
JVC BR-DV3000U DV/Mini DV VCR Logo
32 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
