Question about Dayton Permanent Split Capacitor Motor Fan
How to wire Dayton capacitor start 6K321BA 1HP
I need to replace my old Dayton capacitor start 1HP with new Dayton capacitor start 6K321BA 1HP but has different wiring colors ..etc. Need to connect wires, black( hot ), white( neutral ) and green( ground ) to the motor but which?
  • 579 Answers
SOURCE: Installing a Dayton G73
If that is a 240V unit then you are correct wiring L1 and L2 to black and red. Unless the unit uses 120V for something like a control panel, it doesn't need the neutral.
Posted on Jan 14, 2008
  • 108 Answers
SOURCE: Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Posted on Oct 23, 2008
protek480
  • 1723 Answers
SOURCE: dayton blower wiring instructions
Look at the name plate on the motor. If it's 'duel voltage' it will show a 'high' and 'low' voltage hook up. If it only shows one hook up config, then use the rated voltage on the name plate. If 240 volts, use L1 and L2 for incoming power @ 240volts.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 30, 2009
  • 221 Answers
SOURCE: I have a Dayton 3UG73D heater that I need to hook
Here is your manual: http://www.air-n-water.com/manuals/G73.pdf
Posted on Jan 24, 2010
MOTORWIZJ
  • 1384 Answers
SOURCE: I have a Dayton 36
GRAINGER.COM THEY HAVE A TECH LINE, BUT ON THE MOTOR LABEL IT SHOULD HAVE THE WIRING DIAGRAM .. GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
Posted on May 28, 2010
I have a Dayton 1hp electrical motor model no. 6K2328 i want to change it to 230 volts, how do i wire it?
Seriously, if you need to ask, it might be better left to an electrician. Alternatively, the manufacturer should be able to provide guidance. Be sure to lock out the breaker during your efforts!
Apr 13, 2017 | Dayton Pool & Spa
Replaced a ge condensor fan 3 wire with new dayton the wires are different...old fan has a wire connectort mouted to it orange,black yellow, the new one 2brown 1 with white stripe, purple, black, i have...
the new ge fan requires its own capacitor, the brown and the brown/white go direct to new fan capacitor. black to relay (leg one of power) purple to relay (leg two of power. the compressor will have a wire to the relay and the other to the herm terminal. you now will have nothing to the original capacitor fan terminal.
The new motor will have the diagram showing this. you need the capacitor that goes with the new motor. the grainger guy should have sold that to you with the motor.
Apr 11, 2013 | Heating & Cooling
What the codes
You want delay fuse instead of fast-acting fuse. Look for delay on product description.
Since the motor has a high amp draw when first starting, then that means surge of heat traveling over wire.
Fuse trips when sensing heat.
Delay fuse will accept high heat for longer period of time before tripping.
You have 1 Hp 6K321 motor from WW Grainger. You can contact grainger.
http://www.grainger.com/Grainger/DAYTON-General-Purpose-Motor-6K321?Pid=search
I recommend that you use 12 gauge wire and 20 amp fuse. Over-sizing wire will save heat loss and prevent damage to motor, and heat damage fuse box.
If you use smaller 14 gauge wire and 15 amp fuse, the motor will heat the wire, especially if length of wire is longer than 100 feet from fuse.
The motor has thermal protection, so motor is not overheating.
The wire is overheating.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 27, 2012 | Dryers
Have craftsman 1hp motor with two capacitors,
you posted this under dryer problems , but i give it a shot. Maby your compressor is out of oil or rings worn out and its to tight to turn under pressure. Or your not getting the voltage or amps you need. You cant run on a extension cord or at least a cheep cord. Your plug is or outlet is burnt not tranphering volts and amps.
Nov 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
1hp Water Ace dual jet water pump hums, doesn't pump
DOES YOUR NEW MOTOR HAVE A START CAPACITOR BUILT INSIDE OF IT TO HELP IT START. OR DOES IT REQUIRE A CAPCITOR START / RELAY BOX ABOVEGROUND. ALSO IF YOUR OLD MOTOR WAS 220V AND THE NEW ONE IS 115V YOU HAVE 2 HOT WIRES AND NO NEUTRAL. THE NEW MOTOR REQUIRES 1 HOT AND 1 NEUTRAL. HOPE THIS HELPS, JODY
Jul 18, 2009 | Plumbing
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Dayton Motor and capacitors for Carrier AC Unit (model # 38ck030300)
The 2 brown wires to the cap in first legend is how they are wired electrically,inside that motor the run winding is common to that brown one they cappped off in the 2nd option, but the powers still going to Run.ommon and run get the juice either way, its just another way to do it, but electrically as to sides of power and where they go is no different, just different way to do it.you can run power in on the Run terminal on the run cap, the run winding and run cap and start cap if equipped are Run to Run to Run.So the hot leg for the run winding also goes to run on the caps, run to run to run.,run winding to run cap to run on start cap.
Apr 07, 2008 | Carrier 38CKC036 Air Conditioner
Dayton Permanent Split Capacitor Motor Fan Logo
1,011 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
