Question about Garden
MTD snow thrower won't start
About one month ago I pulled the snow thrower out of the shed, changed the oil, cleaned the plug and had it running on pull number two. Moved it under the deck awaiting the first snow. We had 9" of snow Saturday night and I went out Sunday morning to clear the driveway and the old boy gave me nothing. Pulling the cord multiple times and there wasn't on sign of starting. Made sure the key was in, carb primed, choke on and engine in the run position. Tried again and had the same result. OK. so I pulled out the cord to start it electrically, plugged it in, pushed the start button and again, nothing. Poked around for a smoking gun and found no signs of a cause. Grabbed the shovel and began to clear the driveway the old fashioned way. Luckily, my neighbor saw my wife and I out there hauling snow and offered his snow thrower, which I gladly accepted. Thank you Jay. I am figuring there must be an electrical problem and will be pushing it into the garage tomorrow after work to look into it more. I am hoping for some ideas of what to look for beside the obvious mouse chewed or disconnected wires. I appreciate any ideas. Thanks
SOURCE: Electric starter won't engage with the engine.
I have just taken apart my Troy-Bilt Model 5521 so now I can see how all the bits fit together.
The electric starter is a separate device that engages with the cogs on the outside of the engine flywheel.
The cord pull engages the flywheel at the centre.
The fact that the cord pull starts the engine is a good thing.
If you dismantle the blower and take of the top cover (very annoying with many bolts all over the unit, take a look at the spare parts guide to see the exploded view) the starter it comes away with the power cord.
You can plug this in to the main supply and press the start button and you should see the small cogged teeth turning about 200 rpm. Keep your fingers clear.
I am guessing that this is not working at all. Either that or the cog wheel has shaved the teeth off or it is jammed.
This is a good do it yourself project for someone who doesn't mind getting their hands dirty.
It should take about 3 hours to take the unit apar and another 2 to put it back together.
Troy Bilt doesn't sell the starter motor or the engines (mine had an engine seize with a broken main bearing and a broken piston).
I suspect that the resellers don't have these parts either. But someone does.
Good luck
Posted on Dec 22, 2008
  • 109 Answers
SOURCE: Can't keep mower running without consistently pushing the primer.
It sounds like there is water in the gas. The only way to remedy this is to take the carb off of the gas tank and replace the diaphragm, there is a small reservoir between the tank and carb...clean with WD-40 to remove water
Posted on Apr 21, 2009
goofduck
  • 490 Answers
SOURCE: I just pulled out my Snapper Ridding Mower with a
the rings have seized on the piston and the fuel is running by into the crankcase or you have a valve bent i would pour marvel mystery into the jug and leave it sit for a couple of days
Posted on Apr 27, 2009
  • 127 Answers
SOURCE: Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Posted on Jun 30, 2009
smartr10U
  • 1305 Answers
SOURCE: Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Posted on Jul 23, 2009
MTD Snow Blower will NOT start up!
fuel float stuck --- need carburator repair -- to check it has spark then pull spark plug --- if wet blow off spark plug and check spark on plug then squirt a small fuel out of oil can into plug hole and put plug back in -- if engine fires on first pull carburator needs fixing -- check by squirting fuel in carburator with oil can and see if you can keep it running
Feb 23, 2014 | Garden
Engine start to run rough and shot off after 3-4 minutes running
Possible solutions:
You could have water in your gas if so a $3 additive will unfreeze and eliminate this which will cause rough idling. If your carb is clean make sure to let the blower warm up for several minutes, take off the choke as it warms and it will run smoothly. Last if those dont work, adjust your carbs mixture setting screw (when the engine is warm). (and check your oil! Hope this helps.
Feb 04, 2014 | Mtd Snow Thrower 28" 357cc Ohv
Snow thrower backfires and stalls
sounds like carb needs cleaning or plug changed
id do both
Jan 30, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
I just bought a Sears Craftsman snow blower,put gas and oil in it.Itried to pull the starter cord but it will not pull. I then tried the electric starter but it just grinded.Why won t it start?
Sounds like a serious flooding issue, perhaps due to having blower on its side, take out spark plug and place plastic bag over and try pulling over, be careful that it doesn't spark and ignite any fuel expelled out of cylinder.
if that is the case pull over several times blow off plug and try again, fuel might be trapped in muffler so be aware of spray, ignition.
If it doesn't pull over with the plug removed take it back as a valve might be sprung.
Mtd 31a 140 062 snowblower won't shut off with key
Here is the MTD Model 140 Manual for the snow blower / snow thrower. You can refer to section 11 for trouble shooting guide..
Feb 03, 2013 | Garden
Trying to change the oil on my snow thrower & can't remove the drain plug
Use a wrench to twist it off or it it pries of then use pliers to pull it off.
Dec 30, 2012 | Garden
Snow Thrower Won't Start. I have a Sears 26" Snow Thrower Model No 247.889702. It will not start. Changed fuel, new spark plug, propoerly primed the engine, tried both pull start and electric star
does it have spark? if you can start it with starting fluid chances are the carb needs a good cleaning or replacement. fuel these days goes bad in about 2 months without stabilisers in it. gums up the tiny passages in the carbs. i suggest seafoam as a treatment but anything is better than nothing...good luck
Nov 18, 2017 | Garden
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
