Question about Desa International White Wireless Plug In Door Chime
We lost are chime
We Change are batteries and did not solve are problem
On the main unit see if the red light comes on (indicating it is transmitting) when the wired chime rings. If not, there is a little manual trigger button (to the left of the battery compartment) press this for a second, if the red light lights up then it is transmitting. If the chime unit rings, it means the main unit isn't picking up the wired chime noise. This happened to me, for no apparent reason. By sticking the main unit directly on the top of the wired chime unit, the problem was solved.
Posted on Apr 14, 2009
  • 423 Answers
Check to make sure you don't have anything that would impede the connection at the battery terminal
Posted on Feb 16, 2009
How do I change the batteries in my Carlon RC8800R doorbell
Do you need to replace the batteries in the chime button or the receiver? To change the batteries on the doorbell (chime button) for most Carlon models, you need a ballpoint pen first to remove the chime button from the back. Press the pen point in the small round hole at the bottom of the button. Then gently push in on the tab. Finally rotate the chime button cover up and away from the back cover. Next take the ballpoint pen or a small screwdriver and place it in the slot below the top battery. Lift the battery up. Repeat this with the second battery. Then place the replacement CR2032 batteries into the battery compartment one at a time with the positive side up.
For the most of the wireless receivers, press the center of the brass tubes and lift those free to replace the 4 D cell batteries (2 behind each tube). A few models have a more obvious battery cover for a set of 4 AA cell batteries.
Many Carlon wireless chime manuals are available here: http://www.lamson-home.com/WirelessChimes.php . The direct link to the manual listed for the RC8800R is http://www.lamson-home.com/ProductSupport/WirelessChimes/RC3304_4300IM_3.06_v2.pdf .
I hope this helps.
Oct 09, 2016 | Carlon Home Security
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 | Home
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
I have a Strausbourg chime mantel clock. It chime 2 minutes late every 1/4 hour, how do i fix this. Rae
I lost directions to my clock, it takes two double a batteries for the chime but i dont know how to set it.
thanks
Dec 06, 2009 | Seiko Mantel Clock
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
Adventure tech doesn't have chime
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: info@goamfix.com
web: www.goamfix.com
Sep 14, 2009 | Timex Expedition Adventure Tech Compass...
How do I trun of the change of hour chime on my son's tghk watch
Press the bottom right button and while holding it down press the bottom left. All the days will show and the hourly chime is off, if the days aren't lit the hourly chime is off.
Sep 11, 2009 | Watches
Chime not working on a Columbia CL-5017
This is because you lost the coil spring when battery change took place. Coil spring works as a conductor to the membrane inside caseback and transmits the signal. If you can not find it, you will need to find your nearest watchmaker and ask for new coilspring.
I am pretty sure that you think you did not lost anything, but I can assure you that you did. Coilspring is very tiny and hard to see when dropped and you can not hear it as well.
In case if you find that spring, you have to open the watch and put it back in. There is a small hole in the watch movement and it is designed for coilspring.
Rate me, please.
Mar 23, 2009 | Columbia All Sport Digital watch
My doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
Dec 29, 2008 | Desa International White Wireless Plug In...
Desa International White Wireless Plug In Door Chime Logo
422 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Steven R
Julian Pearson
Level 1 Expert
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
