Question about Summit SPWD1800 Laundry : Washer/Dryer Combos
Dryer not heating
The washer works, but then the dryer does not get hot. error 13 often shows up, the dryer stops after 15 minutes.
3 Suggested Answers
SOURCE: dryer proplem
Rather than try to give you answers, I'm giving you this online link that COULD lead you to a solution: http://appliantology.org/topic/42011-washer-dryer-combo-error-code-er13-haier-summit-ariston/
I looked at it for a few minutes and answers are up and down between encouragement and discouragement. One suggestion is a bad thermostat at the top of the unit, but I'm not sure if you'll be successful in locating replacement parts according to some of the things I glanced at. Hope this helps.
Posted on Jun 28, 2014
daimaxboyce
  • 281 Answers
Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores.
Posted on Nov 15, 2014
The dishwasher doesn't finish the 30 min program. The display shows 1 minute remaining but the washer doesn't stop.
It sounds like the d/w has a heating issues. Possible internal failure of the heating relay.
Jun 20, 2016 | Dishwashers
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Fh showing on my kenmore washer
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Feb 27, 2013 | Kenmore Elite HE4 Electric Dryer
My dryer will run, but won't heat. After about 15-20 minutes, the dryer stops and all the indicator lights (drying, cool down, etc.) flash but no error code shows. I took off the front panel and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Frigidaire GLGQ2152ES Gas Dryer
My dryer is not getting hot. After 10-15 minutes of running, it stops and all of the lights on the control panal flash. The screen that usually reads the time reads "Aj"
it is more then likely the heating element, here is a website to assist you, Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Mar 06, 2011 | Frigidaire Electric Dryer
Dryer smells hot and back panel near heating
your duct is clogged or the limit snapstat is not working. turn dryer on and go outside to the duct vent , their should be a minimum temp of 10 degrees, and a maximum 15 degrees outside. also sometimes just cleaning the lint from inside the dryer, can cause this smell for no more than 5 minutes. thanks karl
Dec 15, 2009 | GE DBXR453EV Dryer
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
Beeping dryer & broken hinge on the washer
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Dryer not always heating
Hello cab-0131,
Welcome to fixya.com
Huuum at your service!
It could be a relay!Or thermostat!
But first try this to reset the system!
As with an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.If you can't reach the plug, use the breakerto cut the power for 5 minutes
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know???
How old is the appliance?
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Sep 22, 2008 | GE Profile Harmony DPGT750EC Electric...
Error code F 13
f-13 is heating element or thermostat.
remove plastic panel at bottom back, look for black marks in line with the heating element at bottom middle of drum.
part number: 1604486 may fix your problem
Mar 24, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Summit SPWD1800 Laundry : Washer/Dryer Combos Logo
20 people viewed this question
Top Summit Washing Machines Experts
ray gallant
Dai Boyce
Dai Boyce
 Russ Hill
Russ Hill
Are you a Summit Washing Machine Expert? Answer questions, earn points and help others
