Question about Amana SXD524VW Side by Side Refrigerator
No water from the dispenser
No water from dispenser. The switch closes at the dispenser and there's a relay clicking at the back bottom of the unit, forward of the place where the supply line enters from the plumbing
There are dual solenoid valves that control the main supply line. Those are not making the clicking noise.
If it sits for a few hours, I can get an ounce or two from the dispenser, then nothing.
I replaced the filter and no change. I can't even hear the air being flushed from the filter air as when I normally replace it. Usually the filter gurgles and spits until it fills with water.
Ice maker still works. The ice trays are filling properly and ejecting into the bin. The ice dispenser also works fine.
Thanks in advance
Bill
  • 62 Answers
You need to replace the dual solenoid one side is for the water the other is for the ice.
Posted on Feb 16, 2010
Maytag side by side. auger for dispnseing ice will not stop what is wrong?
Are you able to switch the controls to dispense water? I see three possibilities that could be happening. The cup dispenser switch, the dispenser control board or a relay on the motherboard is stuck closed. MSD2274VEM00 Parts
Appliance 911 Sea Breeze
Nov 03, 2015 | Maytag Refrigerators
Samsung Refrigerator water dispenser does not work? Ice maker works
The electrically operated valve that opens when you attempt to get water is probably bad. This unit may have one unit with two valves. One each for the ice maker and water dispenser. This valve unit will be in the back of the refrigerator and have a copper or plastic supply line from your house. This line will be "live" so be sure and find and close the valve attached to your house's water supply.
Mar 02, 2015 | Samsung Refrigerators
Rf samsung refrigerator
check the relay on the water dispenser you have to open the back cover on the bottom and follow the line or switch them over and see if this will help.
Dec 16, 2013 | Refrigerators
We own a Kenmore Side by side refrigerator, model #253.54622406. The water has stopped coming out of the water dispenser in the door. What could cause this?
if the ice is opperating normaly listen for a click or humm from the water valve if nothing it may be the switch first check for power at the valve when switch depressed if present replace the valve if valve has power and you hear it oppening and closing it or the line to the dispenser may be plugged. if no ice either check the water supply to the fridge and the filter in the fridge if there is one.
Mar 08, 2011 | Kenmore Refrigerators
Hooked up the water supply to my beaumark fridge and there is currently water in the line to the fridge, however, I cannot get the fridge to dispense water from the dispenser, everything else appears to be...
Is the unit brand new? If so there may still be packing / shipping materials preventing the switch activation arm from contacting the micro switch. You should hear an minor click when the water dispenser arm is depressed. If you do not hear a click locate and remove the packing material. If you hear a click then watch to see if the water line in the back of the unit moves at all when the switch is depressed. If it does not move then the water dispenser valve is not warking. Again if it is new this would be a warranty repair.. It may be something as simple as the water valve connector is not properly connected. If it is an older unit and you just now started to use the water thru the door function the water supply vavle could simply be stuck from lack of use. A good thump on the side of the valve lower body can sometimes freel the valve plunger. Getting to this point would require opening the back of the unit. One last thing is if the line moves when the water switch on the front door is activated then you may just have to wait until the air in the line clears. I am assuming you have already tried this method.
Jan 03, 2010 | Refrigerators
Water is not dispensed when the dispensor is activated. Only a clicking noise under the fridge can be heard. model srd2555w
When you try the water dispenser you should hear the water inlet valve which is on the back where the water supply comes in. If you do hear it then Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
If you don't hear the valve working the dispenser switch is bad.
Aug 16, 2009 | Amana SXD524VW Side by Side Refrigerator
The water will not stop coming out of the door dispenser
1 of two things. 1)the switch at the dispense flap has failed. 2) the water valve solenoid that the sitch activates has failed. you will need to pull the unit away from the wall and remove the bottom panel...on the right side you will see the valve assembly. remove the power connection to the vavles....then turn your water on...water out of dispenser means bad solenoid/valve....no water means bad dispenser switch.if its the switch you can leave the solenoid to the dispenser unplugged until you get the part.
Jun 11, 2009 | GE Profile Stainless Bottom-Freezer...
MAKING ICE BUT ICE AND WATER DISPENSER QUIT WORKING.
Sounds like a plugged water filter, assuming the water is turned on to the fridge. If you have a manual, refer to the section about water filters. The filter is usually accessible from the front of the fridge at the bottom....requires about a 1/2 turn counter-clockwise. Some units require that the water be turned off first but not all.
If you do not hear a click when activating the dispenser, there could be an issue with the water solenoid (water valve) that opens and closes when you use the water dispenser....agai...check the manual if at all possible.
Apr 17, 2009 | Frigidaire Refrigerators
Water/ice maker not working and freezer/frig not cooling evenly(top warm/bottom cool)
the relay valve that controls the water is stuck.
likely hard water deposits,
Feb 03, 2008 | Jenn-Air JCD2295HES Side by Side...
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Amana SXD524VW Side by Side Refrigerator Logo
259 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
