Question about Sansui Vintage Receiver 800, In Near Mint Condition With Original Owners Manual
Sansui 800 receiver makes pop sound when switching on
Snap sound in speakers at switching on moment
2 Suggested Answers
  • 520 Answers
SOURCE: Hooking up external speakers to Sansui HDLCDVD320
I'm sorry, but the Sansui HDLCDVD320 has no analog audio out jacks. If you have a cable or sat box, etc, you might be able to get audio from their outputs. I hope this helps you.
Posted on Jul 17, 2010
I have a Sansui 2000A Stereo Tuner Amplifies that powers up but has no sound. the fuse for the 220-250V 2A was blown and replaced. The speaker fuses look good. Should I replace them too or is there...
If the fuse was blown on the 220-250 V side, I am assuming that you are in the UK, if you aren't , but are in the US, change the power setting dial/switch on the back to 100-120v and you might be good to go. Also, I know this may sound silly, but make sure that the speaker selector switch is pressed in or set to a speaker set ( A or B). Love the Sansui gear, have many complete systems myself!
Oct 17, 2013 | Sansui Classic Vintage 2000a Stereo...
Sansui hdlcdvd26s
see the diagram attached, you can have wrong connection. However clean the contacts and test the wires.God bless you
he speakers are not connected properly. Check the speaker connections. The sound level on the rear or center speakers is turned down. Adjust the sound levels. The receiver is not in the proper surround mode. Set the receiver to a surround mode. The speaker settings are incorrect. Check the settings as per the user's manual.41a9b9c6-64e2-4745-adf3-95fdac1fe686.jpgba7a1620-dfc0-4e45-8fea-6237135735f9.jpeg
Jul 26, 2013 | Televison & Video
SANSUI STEREO AV RECEIVER RZ -2605AV NO SOUND
Sansui RZ-2605 A/V Receiver no sound
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 07, 2012 | RCA Audio Players & Recorders
I have a Sansui RZ-7001 home theater system but cannot get surround sound when connecting my LG Blu-ray BD 550 to it. What am I doing wrong?
fred i dutoi,
Check your connections first. Make sure your input on the Sansui RZ-7001 menu is selected to dvd. Also, make sure the blue ray cables are also inserted in the correct inputs on the rear of the receiver(dvd input). via. rca cables(red, white & yellow) the yellow is the video, hdmi, or optical. If you do not hear sounds coming from your speakers you need to check the separate volume levels for the speakers within the receiver itself. Front and rears having different volume levels within the receiver. Hope this helps. Also make sure you check the volume on the dvd player. Thanks for visiting FixYa.com. Have a great day !
techguy21
Jul 06, 2011 | Audio Players & Recorders
Have blu ray player and dishnetwork hd receiver hooked up to receiver with hdmi cable. getting picture from both and sound from tv but not thru surround speakers.
Sounds like you have both inputs going into your receiver correctly since you're getting the right picture. Your problem is the output - are the speakers hooked up to the output on your receiver? Is the receiver switched to the right setting? Many receivers have settings so you can switch what inputs are on at the moment. Try looking at the back to see which input they're on and make sure the audio portion of the receiver is switched to this as well.
These are the most common solutions. Hope it helps!
Mar 07, 2011 | Audio Players & Recorders
Have an older (mid '70's) receiver, only get sound out of one speaker. What would you suggest?
Ah, 70's receiver, that what I used in my systems (SANSUI, YAMAHA, PIONEER, ONKYO, JBL) still today, built to last.
I would look at the back to see if it has fuses holders in the back for the LEFT and RIGHT speakers.
They may be inside also. I hope it is not due to shorted out output transistors.
Do you get sound on both sides using headphone?
You may also want to activate the TAPE MONITOR switches a bunch of time also to make sure the switches have no dirty contacts. It may be due time to use Deoxit cleaner on all controls and switches.
Please leave rating if it helps.
Jan 05, 2011 | Harman Kardon Audio Players & Recorders
Tone switch causing loud pop in speakers tripping protectiveRelay
The tone control on this one sounds like it is an active one and either using the low or high pass filter you would be boosting the higher or lower frequencies. Boosting the lower frequecies will be harder on the amplifier, in which case if you would like to use then you may need to connect speakers with a lower impedance or higher sensitivity.
Dec 12, 2009 | Sansui RZ-5300AV Receiver
One speaker making a popping sound
try switching the popping speaker to the other side and see if it still pops if it does then you have probably damaged the driver in the speaker if it doesnt pop then the problem probably is in the receiver
May 27, 2009 | Samsung Audio Players & Recorders
I own a classic Sansui intergrated amplifier (AU-717). It has a short in one channel. At low volume, the sound shorts out. I've had this unit for about 20 years now. Otherwise, it's a great product!
Hi mellemcee
Cool amp mate, and becoming collectable now to. Sansui amps from the era where the best in the world of HiFi. iT may have lost bias control to the offending channel, it may have dirty source switches, tape monitor switch, or even speaker switching. The speaker protection relay may also have a dirty contact, will usually burst back into life with a quick rotation of the vol control. Can you pin the problem down a little more with the info i have given you, try all the controls to see if it impacts on operations, you will need to fix those problems first. Low bias would make that channel sound distorted at low levels also. Is this what is happening to you??
regards
Graeme
Apr 18, 2008 | Audio Players & Recorders
Pioneer SX1280 repair
I have taken my 1280 to Austin Stereo, they are honest , upfront, and guarantee their work. So impressed that I took a 1080 that two previous techs had butchered and they fixed it to like new specs.512-451-0408 is their #. They go out of their way to help those of us that are not well versed in techspeak. Both units sound superb with the big 15 inch Cerwin Vega speakers!!!
Feb 02, 2008 | Sansui RZ-5300AV Receiver
Sansui Vintage Receiver 800, In Near Mint Condition With Original Owners Manual Logo
44 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
