Question about Dayton Permanent Split Capacitor Motor Fan
Need wiring diagram for 6k321ba 1hp - Dayton Permanent Split Capacitor Motor Fan
I have a haldex 1hp 115/208-230 volt motor ac. i need to make sure i hook it up right for 230 power. the diagram just confuses me and im a mechanic. white wire, black wire, push button switch, and 7
the spade terminals in the wiring box are marked the chart tells where the color wire goes to what terminal for what voltage then l1 and l2 is the incoming power hookups
Sep 09, 2014 | Heating & Cooling
Replacing switch on 9" task force band saw & need wiring diagram
I couldn't find a manual or wiring diagram available online. A 9" Ryobi band saw looks like the Task Force saw. You may check for it. However, the two saws may have different instructions for the wiring layout. Your best option is call Lowes or see a electrician. They should be able to help you with that.
Sep 04, 2013 | RTO 7 X 12 1HP Turn Pro Band Saw
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 | Plumbing
Im replacing a 2 speed Hayward motor with a AO smith 1 speed motor. I need to no how to wire the 1 speed
to wire a single speed motor you use only the black, white and green wire. there is usually a wiring diagram on the side of the motor to show how this is done.
no wiring diagram then put the black wire on the L1 or H1 post and the white wire to the common and of course the green to ground
Aug 21, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
Motor mod#c48l2pa105 need complid wiring diagram
What is the serial number? We'll need it to know which version you have and therefore which connection diagram to provide. We'll also need an email address as the file will be to large to post as a pic on this site.
John
Arrow Motor & Pump
Feb 27, 2011 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Can you please tell me the correct wiring for a Hayward 120V pool pump (not 240V) Thank you
Follow diagram on the tag. typically low voltage and high voltage volt are diagramed on the tag. Most manufactures send pumps out already for 220. the A and B terminals are for pump wires. and the lines are for the power cord. follow the diagram and you can't go wrong;
The Pool Tech
Jul 10, 2010 | Hayward 1HP Super Pump II Inground Pool...
Dayton Permanent Split Capacitor Motor Fan Logo
46 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
