The motor on my shredder does not run smoothly anymore. The motor is pulsing. This started when I think I feed the machine too much paper.
    Top Expert:
  • Office Equip... Master
  • 34,814 Answers
Turn off power and turn the shredder upside down. Check for paper shreds jammed in the shredder wheels. Remove all that remains. If the motor continues to pulse, you may have damaged the drive mechanism
Posted on Jan 02, 2013
fellowesrep
  • 102 Answers
SOURCE: Rexel rdx1750 shredder jam
This is the available numbers for ACCO Rexel 0845 658 6600 or 01296 732466/732468 in the UK or you may contact by email mailto:informationeurope@acco.com and this is the web address http://www.acco.co.uk/
Posted on Mar 06, 2008
SOURCE: NoviTech Paper Shredder will not feed paper forward.
I had the same problem with my Novitech Model: PS-026/B2 only working in reverse but not forward. So I decided to take it apart and see if I could find any loose wires, broken parts etc. Keep in mind I am not a paper shredder mechanic, but I was able to fix it, at least for the time being, and here is how:
1. Unplug the machine, and I mean it. Make sure you unplug the machine before you start any fixin'. Unplug the machine!
2. I unscrewed the 7 screws located at the bottom of the case
3. I carefully separated the cases and made sure I did not allow any tension on the few wires that span the case halves
4. With the can of electronics duster I use for my computer keyboard, I sprayed all of the electric contacts, making sure I did not spray any of the grease at the gears. I poked the straw in all of the switch housings and the motor.
5. If you feel a little adventurous, you can remove the 6 screws that hold the cover and safety switch in place. At this point pay attention to how the safety switch arm is positioned ( take a picture if you have to) so it will be in the correct position during assembly. Remove the cover and look for anything that could be caught in the shredders. Remove any foreign matter with tweezers or needle nose pliers. Replace the safety switch and cover, make sure the switch arm is in the same position before you took it apart.
6. Put the two case halves together making sure there are no wires pinched inbetween. Put the seven screws back where they belong and tighten snugly ( do not over tighten cause you will break the plastic, guaranteed!)
7. Place the machine on the waste bucket and plug it in. And voila the motor should start buzzing and humming like it was brand new.
Posted on Mar 22, 2009
SOURCE: Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Posted on Jun 03, 2009
JayBlair
  • 328 Answers
SOURCE: Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
Posted on Jun 05, 2009
  • 3 Answers
SOURCE: My shredder runs but won't grab the paper that I'm
Look down into the slot to see if the teeth are sharp. They should have little J-hook thingys that look like the teeth in your mouth. If it looks ok, give it some food to chew. If it burps it up, throw it away because its a junker and not worth your time.
Good Luck.
Posted on May 12, 2010
My shredder squeaks when in use, does it need regular lubrication? If so, what do I use?
Visit the link below for various types of shredder oils.
http://www.factory-express.com/Shredder_Oil__Bags-2025.htm
Regular use of paper shredders creates paper dust that can dry out components, dull the blades, clog the machine and burn out the motor. However, with proper oiling and maintenance, a paper shredder can last for years.
Oiling a shredder can be accomplished using one of two quick methods. The paper method limits excess oil to the paper, reducing the chance of it splattering when you turn the machine back on. This method is more common than the second and can be used with all kinds of shredders. The paperless method may be less common, but it is just as effective at removing dust buildup from the blades of the shredder.
The Paper Method:1. Place a sheet of paper on or above a surface that will not be marred or damaged should you spill oil on it.2. Apply the oil to one side of the paper in a wide zigzag pattern across the whole face of the page to ensure sufficient coverage. Do not saturate the paper with oil.
3. Turn the shredder on and run the oiled piece of paper through the shredder. As the paper shreds, the oil that has been absorbed by the paper will lubricate the blades. The motion of the blades will distribute oil so the shredder continues to operate smoothly.
3. Feed a few more papers into the shredder to absorb residual oil from the cutting assembly. The Paperless Method:1. Set the shredder to manual mode so you can control the direction of the blades and the amount of time the blades are in motion.2. With the paper shredder turned off, squirt a solid line of oil into the paper entry lengthwise across the paper-shredder blades.
3. Start
the paper shredder in reverse, allowing it to run for 10 to 20 seconds before stopping the blades. This will evenly distribute the oil to all parts of the cutting assembly.
4. Return
the shredder to automatic mode. Then feed two or three sheets of paper into it to absorb the excess oil from the machine. Tip:
How often you should oil your paper shredder depends mostly on how much you use it. Office shredders that see heavy use every day will need to be oiled several times a week, while home machines used occasionally need be oiled only a few times a year. Cross-cut shredders will require more frequent oiling than other paper shredder varieties because they have more blades and create much more paper dust.
You can purchase a shredder lubricating oil from any major electronic or office supplies store or you can contact Royal customer service at 908-429-4357.
Feb 20, 2012 | Royal Sc120 Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Paper no longer feeds in. Motor works.
Please check the sensor is on or off.
if paper is feeding completely then it means you need to buy a new one.
May 22, 2009 | Royal 160MX Shredder
Ativa DQ120D shredder
I had the same problem with my Shredded. In the centre of the paper feed slot is a little sensor that detects when you put paper in, it breaks some sort of light beam that is connected to the motor circuit.
Over time paper dust gathers on this sensor, covering it completely and fooling the machine to think that there is ALWAYS a piece of paper being fed into the shredder, the result being that the motor just runs continuously.
Clear the dust from this sensor and you'll fix this particular problem - a toothbrush worked great for me - don't use it to clean your teeth afterwards :-)
FIXYA!!!
Dec 11, 2007 | Office Equipment & Supplies
Problem ts 6000
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Nov 30, 2007 | Tech Solution TS-6000 Shredder
Aurora Electronics AS1018CD Shredder
Nov 28, 2007 | Office Equipment & Supplies
Paper will not feed into machine
Most likely the sensor in the insertion area is not recognizing a paper when you try to insert it to be shredded.
Try to clean out the gears, and oil the grinders.
Clean around the insertion area to remove any debris from around the sensor. (Be sure to turn it off/unplug it first!).
If you can remove the shredder head/grinders from the body of the shredder box, turn it upside down and clean it that way as well.
Sometimes the little pieces of paper get clogged up inside the gears.
I got some of the dust spray with the straw...inserted the straw deep into the shredder grinder/gears and sprayed.  I got tons of stuff out.
My motor/grinder worked perfect after I did all this.
Oct 28, 2007 | Royal VF1000MX Shredder
My techko SH 3112Fa won't turn off
FIXYA!!!
Oct 11, 2007 | Office Equipment & Supplies
66 people viewed this question
jasbo
jasbo
