Question about Microsoft Kinect Sensor for XBOX 360
My Kinect right now has a red light and won't move up and down why?
Right now my kinect is on with a red light sometimes the light on the kinect will turn green, then red, and go off. I unplug it and plug it somewhere else no improvements what so ever its not even tilting up and down like its supposed to.
5 Suggested Answers
  • 25 Answers
SOURCE: when am playing on my kinect the game goes off
they kinect wants you to install video updates for online chatting, if you do not install this it will not work right, thankyou for using fixya.com
Posted on Jan 21, 2011
SOURCE: The replay on the kinect is slow. On the kinect
I have the same problem. did you find out why????
Posted on Jan 30, 2011
Swwils
  • 132 Answers
SOURCE: my kinect sensor says "it cant move enough" though
Return the item under warranty for a replacement.
Posted on Mar 14, 2011
  • 5 Answers
SOURCE: my kinect does not turn on the light stays on red
Try unplugging the kinect and then the x-box power for a few minutes. Then plug the kinect in before reconnecting the power. If that doesn't work you may have to contact microsoft support, there should be a phone # on the package.
Posted on Sep 11, 2011
Twister Mania start up issues
Make sure to run the Kinect setup and calibration in the Xbox 360 Dash. Move all the way to the right and select kinect settings. Run the setup and follow the instructions there. Make sure to have a Kinect setup card handy. (comes with games.) This should help with any calibration issues. If that doesn't work, try signing in with a different account, or doing an xbox live sign in test.
Jun 01, 2012 | Majesco Twister Mania X360 Kinect
My 360 kinect won't read disks. It says open tray,
my x box 360 Kinect want work because when I put the game in it said open and close the tray
Apr 08, 2012 | Video Game Consoles & Games
Xbox kinect has red light with no message on tv
Hello, this is a first for me. I have yet to come across a Kinect with a problem. A quick search and I see that it's actually kind of common. From what I can find, and after a few calls, it seems the only solution I can find is this at xbox support. It seems to say it could be the cord or the power outlet or simply needing an update. From the Kinect, the cable should go to what looks like a splitter. There should be a little green light on it. If not, it may not be getting power but the red light would come on powered from the xbox itself which is not enough to power the Kinect of course. Try to plug the Kinect into another outlet. They say the xbox and Kinect are not suppose to go to a power bar, surge protector or extension cord. I know that sounds crazy but it's true. If another outlet works then you know it's just the outlet. If that doesn't work, can you borrow another cable from someone to try, that can eliminate issues too. If the other cord works you know that's all you have to replace. The other thing to try is putting a Kinect game into the console and see if it asks you for an update. That could be your issue too. Try these and if none of them work, I would think you need to replace the Kinect cables. Hopefully it's not the Kinect itself. If these don't help, you will most likely need a repair or the connect will have to be replaced :( I hope this helps, let me know.
Dec 01, 2011 | Microsoft Xbox 360 with Kinect
My kinect does not turn on the light stays on red
Sep 11, 2011 | Microsoft Kinect Sensor for XBOX 360
The problem with the kinect is C000022D
http://support.xbox.com/en-us/pages/kinect/more-topics/errors/red-light-kinect-sensor-5.aspx Red light on the Kinect sensor Last Modified 4/22/2011
Page Content kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive one of the following errors:
A problem has occurred with your Kinect Sensor (C000022D)
A problem has occurred with your Kinect Sensor (C00000C2)
Here's what to do to fix the problem:
update_error.jpg Solution 1: Update your console software
  1. Insert a Kinect game disc.
  2. Start the game from the Xbox Dashboard.
  3. If your console software needs updating, you will see the following message:
    Update Required: An update has been found, to apply this update you must restart your console.
  4. Select Yes, Restart to install the update.
If you still get the same error message, try the next solution.​ ​ ​ Solution 2: Check the cables ​ ​new360cableconnect.jpg
Xbox 360 S console
  1. Turn off the console.
  2. Unplug the sensor from the console, and then plug the sensor cable into the AUX port on the back of the console.
    Important Remove the power/USB adapter cable if your Kinect sensor came with one.
  3. Turn on the console.
Original Xbox 360 console
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
  4. The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure that the cable is working properly. If you still do not see a green light, your cable might need to be replaced. Contact
    Xbox Support.
  5. Turn on the console.
If these solutions do not solve the problem, please contact Xbox Support
Jul 19, 2011 | Video Game Consoles & Games
My kinect has a green light on but wont adjust to find me. i last used it a few month ago. but it hasnt moved since. iv done the kinect tuner but it wont move to find me
On the front of the Kinect sensor are windows that hide depth sensors, an RGB camera, and a multi-array microphone. Tilt it at certain angles and you can even make out a slightly flickering infrared light that helps the advanced Kinect camera scan the room. A green LED light flashes upon Kinect's bootup and remains solid when connected.
May 28, 2011 | Computers & Internet
I can not play kinect with my xbox 360. i can do everthing except acess playing sonic etc. please help.
Do you have the Kinect hardware that you need to play kinect games. It looks like this..
If you have bought your Xbox 360 before kinect came out you will have to buy this hardware. If you do have this and you have the older XBOX did you connect the power adapter to the kinect that is provided in the box as only the newer XBOX S does not need a power adapter for it. If all is present then look at the bottom right corner for a video display which will show you what the kinect is looking at. If present then wave your hand and a hand icon will be presented on screen at the bottom, complete the wave and you will get a hand cursor. You can then use the cursor to select kinect hub and then select play game from it. Hope the kinect hardware is placed at an appropriate height to allow for it to see properly and has enough swivel space too as the camera automatically tilts up and down to keep the player in the center.
Hope this helps..
Mar 01, 2011 | Video Game Consoles & Games
What does it mean when the kinect says "The kinect sensor can't move" We have tried multiple things to fix it and nothing it working. Thankyou.
The Kinect sensor has a motorized mount so the camera can adjust itself up and down to follow movements in the room. If you are getting that message something is either physically preventing it from moving or you have a manufacturing defect (any Kinect should still be under warranty and you should be able to simply exchange it for a working one)
I have a Kinect as well and can tell you that message isn't normal in its use so definately clear the area around the sensor or simply just return it for exchange as stated.
Feb 18, 2011 | Video Game Consoles & Games
When am playing on my kinect the game goes off then when i restart it keeps asking me to download updates and the kinect bar stays red
Jan 21, 2011 | Microsoft Kinect Sensor for XBOX 360
Microsoft Kinect Sensor for XBOX 360 Logo
200 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
