Question about Maytag Performa PAV2200
Maytag Performa Washing Machine
Here is my problem. My washing machine fills up with water, but does not switch into the agitate cycle. So, my washing machine has been sitting, full of water, for the past day. Hopefully, someone can help me fix this problem and have my washing machine start working OR at least tell me how to drain my washing machine. I just bought the house (machine included) and the previous owner did not leave the owner's manual. Thanks, Brian
  • 13 more comments
  • Anonymous May 17, 2008
    not gettin power
  • kmmfish Sep 16, 2008
    I have the same problem. However, the motor gets very worm and there is an electrical burning smell. The machine fills with water and then wont agitate. It then clicks,clicks,clicks...and then "Nothing". It all stops. After a few minutes, I can turn the timer back to fill and it will do the same thing all over again. Any suggestions?
  • Anonymous Nov 27, 2008
    My Performa fills with water and then won't drain and spin.
  • culooken913 Dec 14, 2008
    I have the same problem and i have owned my washer for only 3 weeks, it is as if the washer does'nt know when to stop filling. I emptyed my washer by using a cup and a bucket, and tryed to start it over but, it did the same even on the mini load.
  • clock 59 Jan 02, 2009
    my washing machine fills up but not switch on to start washing and its sittig there full of water and can not pushe it to get the model number please help sally
  • busymom7100 Feb 08, 2009
    Wow! We have the same problem, fills up with water and then doesn't agitate. My husband says it's the motor. I am a bit disappointed by the recurring problem this machine has. I just saw on Craigslist someone trying to GIVE this machine away for the same reasons. I'm going to post a complaint with Maytag. I'm curious how long everyone has had their machines???
  • poodoodle Mar 14, 2009
    fills with water,then thats it. noise, no nothin
  • amwinsor8 Apr 18, 2009
    it filled and now nothing wont drain wont spin. i wondered if theres a fuse i dont have money to pay to get it fixed .
  • pclafferty Apr 26, 2009
    tank filled, then nothing. simply nothing. won't drain either when I try the "spin only" solution mentioned here,
    ugh.
    any solutions?
  • sara994 May 11, 2010
    Belt on Maytag Performa washing machine broke replaced agitator belt and pump belt went thru all cycles fine until spin cycle then it sounded like like belt was slipping onpulley smelt like it also
    Belt on Maytag Performa washing machine broke replaced agitator belt and pump belt went thru all cycles fine until spin cycle sounded then it sounded like like belt was slipping onpulley smelt like it also
  • Anonymous Mar 19, 2014
    I need someone to come to my house in Gloucester Road to fix the Washing machine up asap please
  • Anonymous Mar 22, 2014
    My washing machine is leaving the load full of water
  • Anonymous Mar 28, 2014
    doesn't wash clothes
    yup
    Sergeant:
  • 349 Answers
Before you do anything else..UNPLUG it from the 240volt supply ! Read ALL of this before attempting the fix. After draining out the water, lay the machine down to expose the inner workings. You'll need to find the pressure switch which is connected by an thin rubber or plastic tube from the wash tub. Check that it is is properly connected.(YOu may have to cut off a little of each and to give you a an "as new" airtight sealed fitting. A little smear of quikgrip glue around the nozzle at each end will ensure a longlife airtight fit of the tubing.) BUT before you do the final glueing and fitting of the tube. Just have the tube at the pressure switch nozzle connected and BLOW into it. You should hear an audible click when blowing and relesing the air. Even if you hear this, it only confirms that the diaphragm in the pressure switch is ok. It does not tell you if the two way switch inside it of good integrity. By integrity I mean the condition of the switching CONTACTS, As they carry high current, they eventually burn and pit and can become of such HIGH resistance to the flow of current that there is none when the switch is in fact physically in the on position. Further advice from me can be had by accessing the PAYG "Let our Experts Solve YOur Problem" FixYa Link.
Posted on Aug 30, 2007
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Maytag this model anyway is forever going OFF BALANCE and Think that is what caused my washer's problem.
My Maytag washer when filling continued to fill until it began coming out the bottom. The water just kept on going. Before opening reading all of the helpful hints on the internet, it suggested that it was some valve....
What to do?
We unplugged the machine first. Then found the the hardest thing was getting straight answer about how to get the cabinet open. Wow simple as looking to the top front of the cabinet and seeing sqare pads that were around the joining. It takes a flat strong Broad tool to wedge ietween the bottom and the top of the washer. But that is how it is done.
Once we got the machine cabinet open a flash light around the tub soon revealed a 1/4" clear plastic hose that had a simple pinch clap had slipped off of the plastic nipple on the tub.
Pliers to pinch the clamp open and reconnected it to the nipple connection on the tub.
Once the machine was back together and plugged in, it worked.
If you haved washed heavy blankets, rugs, towels, or anything that went off balance badly and you then have issue with water leaking from the bottom.. I would be you money that your machine has the same problem that our machine had.
Hope his is helpful to someone. Sure would have been helpful to me if I had read it before stressing out over the thought of having major repair bill.
Posted on May 15, 2009
    President:
  • 1,294 Answers
To drain out water press the 'spin only' option, if it does not work drain out the water with a tube, ie, siphon it out of the tub.
Posted on Jun 25, 2007
Sounds like your belt is either off or broken.Happened to ours and the repairman told us it was the motor. We turned over the machine ourselves and found out the belt had come off. It is on the bottom of our Maytag. Simple fix me did ourselves...the repairman got $50 for doing nothing. Not calling on him again.
Posted on Jul 15, 2007
Washing machine does not agitate or spin.
get a new control board /timer switch (Depending on your make of machine)
Jan 18, 2016 | Washing Machines
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Beginning of wash cycle starts agitating instead of filling w/water.
the water pressure/level switch contacts are welded together,usually the load selector switch for the amount of water lets it fill to a determined water level and the water level creates pressure in a tube from the tub to this switch and stops water fill and starts the wash agitation cycle,replace this switch inside the control panel
Mar 19, 2011 | Whirlpool Washing Machines
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine agitates at beginning of cycle without filling
Chances are either:1) the water pressure switch has failed or 2) the hose that connects to the air bell has debris in it and it will not allow the switch to reset
Mar 02, 2009 | Washing Machines
Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Sep 01, 2008 | Washing Machines
    Washing machine fills, but won't agitate
    my kenmore washer will fill up but it will not agitate.
    Dec 17, 2006 | Hotpoint Aquarius WD63 Front Load...
    Washing Machines Logo
    3,850 people viewed this question
    Top Maytag Washing Machines Experts
    jimorris77
    Sheldon Dedek
    Bill Long
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
