Question about SimpleTech Simpledrive Computers & Internet
Simpledrive 500gb suddenly not readable though it is recongnized by windows 7; message "the file is corrupted or unreadable" is received when I attempt to open it, then it prompts me to reformat which
Fabrik
    President:
  • 650 Answers
Same thing happened to my hdd I ran this test http://www.hgst.com/support/downloads/ and it fixed it hope it works
Posted on Jan 03, 2013
PauldLucky
  • 268 Answers
SOURCE: SimpleTech SimpleDrive Portable Hard Drive
No need to pay money to get back the data.
Open the link given below you can have all the information with images.
Just follow it.
http://lifehacker.com/software/disk-recovery/geek-to-live--rescue-files-with-a-boot-cd-192982.php
I hope this will resolve the issue.
Good Luck.
Live, Love, Laugh.
Posted on May 09, 2008
  • 13433 Answers
SOURCE: external hard disk problem
Chkdsk /F /X D:
(replace D: with the letter of the drive)
you can also try CHKDSK /F /X /R D:
Posted on Jul 26, 2008
cgpatel1948
  • 258 Answers
SOURCE: external hard disk unreadable
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
  • 397 Answers
SOURCE: Simpletech external 500GB Hardrive corrupted
PC INSPECTOR™ File Recovery 4.x is a data recovery program that supports the FAT 12/16/32 and NTFS file systems. The current version 4.x replaces the previous version 3.x, which is now over 6 years old.
http://www.pcinspector.de/Sites/file_recovery/info.htm?language=1
Posted on Aug 03, 2008
SOURCE: my iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Posted on May 23, 2010
My dell computer with windows 7 will not recognize my device - tried it on an apple and found 2 files but could not open - said corrupt and unreadable? how to I retrieve my photos and docuements?
run a virus scan on the device (from a good licensed antivirus company and a windows machine recommended) then later go to folder options and untick 'hide hidden items' and 'hide system extensions' options (basically untick all options related to hidden files and folders and say yes when prompted). your data is there do not format.
Jan 25, 2016 | SimpleTech SimpleDrive Pininfarina 320GB...
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
Error message that says Drive is not accessible. The file or directory is corrupted and unreadable.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 31, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
It says the drive is corrupted and unreadable.
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 05, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Unfortunately I dropped my Trekstor 500GB hard drive on the floor and now it registers as a removable disk with message "please insert disk into removable disk". My computer is a Windows vista. Can the...
An external unit has two main parts:
* the disk-drive
* the USB-to-disk-drive adapter
In your case, the adapter seems to be working OK.
But, when Windows tries to read the 'table-of-contents' from the disk-drive, it cannot,
and so you get the 'please insert' message.
You might want to disassemble the unit, and remove the disk-drive,
and connect it as a 'slave' disk-drive in a desktop computer,
just to bypass the adapter, to see if the disk itself can be read.
So, about 0.1% of the blocks on the disk-drive are 'unreadable'.
This means that the other 99.9% of the disk-drive _could_ be readable,
namely all your files.
Search online for 'DATA RECOVERY' software -- it reads through the blocks on the disk-drive,
block-by-block, trying to 'stitch' blocks back together (like assembling a jigsaw puzzle) to
reconstruct the (unreadable) table-of-contents, and thus make it possible to copy the files
from that drive onto the 'C:' drive of the desktop computer.
Oct 06, 2010 | Trekstor Computers & Internet
Corrupt file messge
Boot into safe mode and clear you temp and %temp%.
Run diskcleanup tool, your issue would be fixed
Sep 13, 2009 | Microsoft Windows XP Professional
Aug 03, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Computers & Internet Logo
75 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
