Question about Toshiba Satellite A135-S2386 Notebook
Toshiba my problem is PXE-E61 media test failure!! i need your help plz..... I have a Toshiba 4600 and its showing the same things except I can not the PXE from boot, though in bios it shows boot from cd/floppy. It boots to the floppy and that is about it. Getting another PXE but this one involves the cd. It sees it in dos but when you try to access the information on the disc it says it can't read the drive. HELP...
  • 916 Answers
This is a problem with the MBR file on your hard drive run the recovery tool from your windows disk and when the prompt comes up run CHKDSK once you have done this please post the results.
Posted on Jan 18, 2009
    President:
  • 2,559 Answers
Put the disk in and Restart,while it restarts tap the F11 key until it says booting from cd
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Enter the CMOS/BIOS configuration of the Toshiba. Determine if the hard drive is auto detected, if not try to manually detect/enable the hard drive. Your described problem is that the computer could not find a bootable media and reverts to booting from the network.
Pls post back result(s). Good luck and Thank you for using FixYa.
  • Toshiba Master
  • 6,487 Answers
This is a sign of a corrupted hard drive , so you really need to reload your operating system to that computer so everything will be working
Toshiba nb300 windows starter won't boot. PXE-E61 media test failure. check cable.
If your computer is working fine, then disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
For the most part not a real problem. More of a warning. Some corporate models use PXE to mass image.
If there is a problem (won't boot) then it lost communications to hard drive, and you need to check BIOS for hard drive.
Oct 03, 2012 | Toshiba mini NB305N410WH Netbook
Toshiba satellite pro l450-13q PXE-E61 media test failure check cable
This indicates hard drive issues, or windows files have been corrupted. If you have a backup disk try and load windows, no change! have the hard drive tested for possible replacement.
Jul 08, 2012 | Toshiba Satellite Computers & Internet
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
Toshiba
welcome to fixya
In the bios, set the NIC entry to "ON (PXE off)" and remove the option of PXE boot from the boot sequence. Make sure all IDE devices are set to cable select (hard drives, CDROM, CD-RW etc) and that only those devices you have present are set to AUTO in the bios.
this should fix the problem have a good day
Jul 13, 2008 | Toshiba Satellite A135-S2386 Notebook
PXE MOF problem
First, try and access your cmos setup. Look to see if your harddrive shows up.
Apr 06, 2008 | Toshiba TE2100 Notebook
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite A135-S2386 Notebook Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
