Question about Kenmore Washing Machines
Washing Machine not spinning water out of clothing
Model # 110 23832100
    Sergeant:
  • 291 Answers
Here is an idea:
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/478342-kenmore-110-23832100-no-spin-issue.html#b
Posted on Jan 02, 2013
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
SOURCE: spin water from clothes
i also have a kenmore model # 110.23832100. It drains the water but does not spin leaving the clothes soaked.
Posted on Jul 09, 2008
dh1200s
  • 335 Answers
SOURCE: Model FAV6800AWW will not pump water out if clothes are in machin
Hello domino14
Your experiencing symptoms of clutch malfunction with the FAV6800AW. Do you want to dive in and try to fix? Here is what is involved to pull the clutch out of your machine. Also read the last couple of post in this forum. If you call a repair service in your are looking at $300 +. If you can DIY the repair cost could be from $10 dollars if you just need a roller clutch clean up and re-lube to $50 -140 for a replacement clutch. I’m cheap and would go for the $50 Clutch.
First check is to lift lid and see if you can rotate the empty wash basket CCW with one finger. That will let us know if you are experiencing some drag with the roller clutches in the clutch assembly. Here is a step by step to remove the clutch. It is a tight work area but can be done with basic hand tools and basic mechanical skill sets.
What is the serial number of your machine? Just need the first two digits i.e. 10, 12, 14, 16. This info is located on the top right back side of the console.
Next comment will be the clutch removal process, this board has message limits.
Posted on Apr 24, 2009
  • 396 Answers
SOURCE: machine won't spin
If water remains in the drum the unit will not go into the final spin. There may be a couple of reasons which I have experienced resulting in your problem. If water remains in the tub the unit will not go into the high speed spin.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water. Shake the hose and listen for coins or a small object this unit will pass items through the pump into the hose causing blockage.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning. The hose needs to have a loop in it to work correctly.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. The pump is about $60.00 and is accessible after removing the front panel under the door. It is easy access from the front and the hose clamps will be the most difficult problem. I have a ratcheting hose clamp tool designed for this type of clamp but channel lock pliers will work.
Posted on Jan 21, 2010
  • 6 Answers
SOURCE: Our Crosley washing machine (Model
Three possibilities here,
One, you've overloaded the washer with clothes, throwing the washer basket on tilt because of the extra weight and force against the agitator. Remove the wet clothes from the washer and try continuing the cycle.
Two, One of the elastic/spring arms that centers the basket inside the washer housing has broken and is allowing the basket to simply flop around. Disassemble the washer and inspect the basket supports.
Three, The center post that the washer basket sits on is going bad - The most common reason is that the bearings have gone bad. Disassemble the washer and replace the bearings at the base of the basket where it connects to the motor.
Posted on May 04, 2011
What years was the marlin model 36 lever action .22 made
The Model 36 was introduced in 1936 by Marlin Firearms as an improved version of the Model 1893. Around the time of the First World War, Marlin dropped the "18" and started calling the Model 1893, the Model 93. But no significant change in the gun's design took place. In the period between the wars, metalurgy was changing, as were manufacturing techniques. So Marlin upgraded the Model 93 and re-designated it the Model 1936. This moniker lasted only one year, and in 1937 it became the Model 36.
Model 36s were made until the Second World War. In 1948, the Model 36 was redesigned and modernized again and was given a round bolt to replace the square . The model number was again changed to Model 336. Lots of versions and lots of small changes have been made since, but variations of the Model 336 are still in production.
Pete
Apr 06, 2017 | Firearms
Serial #3506979
any one of these sites will help you find the serial number and date of manufacturer. The forums will help with values, or the Blue Book of Gun Values.
  • Model 1894 (Mod 94 ) - Winchester Dates of Manufacture www.oldguns.net/sn_php/windateslookup.php?file=win1894.dat Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
  • Winchester Model 1894/94 Dates of Manufacture www.savage99.com/winchester1894_dates.htm Dates of Manufacture* for: Winchester Model 1894/94. Winchester Lever Action Repeating Firearms, Vol. 3, The Models of 1894 and 1895 by Arthur Pirkle.
  • Winchester Model 94 Serial Numbers - Gun Collections Online guncollectionsonline.com/winchestermodel94.htm 41 rows · Gun Collections Online. Specialists in Marketing Your Gun Collections ...
  • Related searches for winchester model 94 serial numbers
  • Serial Number info for Winchester Model 94 - The Firing ... https://thefiringline.com/forums/showthread.php?t=322230
    • 109 POSTS
    • FIRST POST: 2008-11-27
    2012-08-04 · I have a Winchester model 94 serial # 2775xx3. The chart in this thread for serial # id show a lapse between 64 and 65 models. The 65 models all start with ...
  • How can you find the age of a Winchester Model 94 - Answers www.answers.com > ... > Firearms > Winchester Firearms What is the age and value of a Winchester Model 94 serial number 3910875? ... What is the age of a Winchester model 94 serial no 1929746?
  • Winchester Model 94 Identification - 8's Garage 8sgarage.com/Armory/Rifle/Data/Manuals/Winchester 94 Identification... · PDF file Winchester Model 94 Identification PRE-64: The Winchester model 1894 was introduced in October of 1894 apparently starting at serial number 1.
  • What Is The Year And Value Of My Winchester Model 94 ... www.gunvaluesboard.com/what-is-the-year-and-value-of-my-winchester... What is the year and value of my Winchester model 94 serial number 5271797?
  • Value Of A Model 94 Winchester Rifle 30-30 Serial Number ... www.gunvaluesboard.com/value-of-a-model-94-winchester-rifle-30-30... also have 3 winchester model 94 32 specials all are in fair condition stocks are worn and bluing has light scratches serial numbers are 3133157...2822367...2889678 ...
  • Model 1894 ' Winchester Collector winchestercollector.org/models/model-1894 ... the Model 1894 became the first Winchester ... The 1,000,000th Model 94 was presented ... from serial number 1 thru 353999. The Winchester Model ...
  • Jul 19, 2016 | Winchester Model 94 Short Rifle .30-30 20...
    Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
    many machine spin a full tub as they are pumping the water out
    this helps to even out the washing load and reduce the unbalance situation
    when the water is removed , the machine progresses the program to a high speed spin
    call a technician as there may be a problem in the program board
    Jun 11, 2016 | Kenmore Washing Machines
    Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
    2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
    Jun 09, 2016 | Kenmore Washing Machines
    I got a win model 70 308 serial number 862911
    You don't say, but I presume you want the date of manufacture?
    http://oldguns.net/sn_php/winmods.htm
    Other info for you.
    1. Date Your Model 70 and 94 - RifleShooter www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803 These tables indicate the years of production for the Winchester Model 70 and 94 rifles ... Date Your Model 70 and ... the tables below show serial number range by ...
    2. Winchester Rifles Modern Bolt/Auto/Single Model 70 For ... www.gunsamerica.com > ... > Login To Save This Search Winchester Rifles Modern Bolt/Auto/Single Model 70 for sale on GunsAmerica. Find guns for sale, gun auctions and more on GunsAmerica.
    3. Winchester Model 70 rifles (Win. Model 70) - Chuck Hawks chuckhawks.com/win_70.htm Chuck Hawks shares information about the Win. Model 70 ... .264 Winchester Magnum, .270 Winchester, 7x57 Mauser, .300 Savage, .308 ... the Winchester Model 70 has ...
    4. Related searches for win model 70 308 serials
    5. Winchester Rifles - Model 70 Pre-64 For Sale www.gunsinternational.com > Rifles Browse all new and used Winchester Rifles - Model 70 Pre-64 for sale and buy with ... Pre 64 Model 70 Alaskan in 338 Winchester Magnum Caliber. Serial ...
    6. Winchester Repeating Arms www.winchesterguns.com The Winchester Model 70 in Vietnam. ... "The Prize for Capturing Geronimo" about the famed serial number one, 1886. Read the article on the Rock Island Auction website.
    7. WINCHESTER DATES OF MANUFACTURE - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... Model 70 Model 72 Model ... Model 59 Shotgun ...
    8. Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 The Winchester Model 70 series rifles are marketed as sniper rifles for military forces and law enforcement agencies under the ... .308 Winchester.300 Winchester ...
    9. Winchester Model 70 Information - MGW www.midwestgunworks.com > ... > Winchester Model 70 Winchester Model 70 Information ... and there are many "legends" about why the historic serial number records for Winchester rifles and ... .308 Win: Long Action: 7 5 ...
    10. Blue Book of Gun Values - WINCHESTER RIFLES: BOLT ACTION ... bluebookofgunvalues.com/Gun_Values/Manufacturers/WINCHESTER/... (new 2006), .308 win., ... model 70 custom special "70 years of the model 70" get pricing.270 win., ... winchester rifles: bolt action - post 1964 model 70 custom grades
    11. Winchester Model 70 Featherweight ( Pre ' 64 ) .308 Win ... www.cabelas.com > Gun Library > Wheeling Gun Library ... Winchester Model 70 Featherweight (Pre '64) .308 Win ... Shown: null. More Views: Additional Media: Winchester Model 70 Featherweight (Pre '64) .308 Win. Caliber ...
    12. Pagination
    May 24, 2016 | Optics
    Looking for what year my Winchester model 94 was manufactured in. The serial number is 2374881
    Here you go. These sites will help you.
    • 108 POSTS
    2012-08-04 · Serial Number info for Winchester Model 94 User Name: ... Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 ...
  • Winchester Model 1894/94 Dates of Manufacture www.savage99.com/winchester1894_dates.htm Winchester Model 1894/94. Winchester Lever Action Repeating Firearms, ... Our database contains values of serial numbers through 5103248 which ended the year ...
  • Model 1894 (Mod 94) - Winchester Dates of Manufacture www.oldguns.net/sn_php/windateslookup.php?file=win1894.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 1894 (Mod 94): ... Please enter a serial number and click the submit button. ...
  • Winchester Model 94 Serial Numbers - Gun Collections Online guncollectionsonline.com/winchestermodel94.htm Winchester Model 94 Serial Numbers. In 1894 Production began with Serial Number 1 and the Winchester Model 94 Serial Numbers run more or less, ...
  • Winchester Model 94 Identification - 8's Garage 8sgarage.com/Armory/Rifle/Data/Manuals/Winchester 94 Identification... · PDF file Winchester Model 94 Identification ... The Winchester model 1894 was introduced in October of 1894 apparently starting at serial number 1.
  • winchester 1894 serial number decoder ' Jeremy blog fitubangscam.blog.com/2013/05/04/winchester-1894-serial-number-decoder Ladder sight CARBINE Winchester 1873 1892. Winchester Model 1894 - Wikipedia, the. Winchester 1894 Serial Number ' Gun. Winchester Model 94, winchester model 94 ...
  • Winchester Dates of Manufacture - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... (Mod 94) Model 1895 Model ... Model 59 Shotgun ...
  • How can you find the age of a Winchester Model 94 - Answers www.answers.com > ... > Firearms > Winchester Firearms How can you find the age of a Winchester Model 94? ... What is the age and value of a Winchester Model 94 serial number 3910875?
  • How do you find out if a Winchester Model 94 is pre-64 ... https://answers.yahoo.com/question/index?qid=20081128210042AA3vaql
    • RESOLVED
    • 14 POSTS
    • 13 TOTAL ANSWERS
    2008-11-28 · Best Answer: The serial number is the best bet 95s had grip safeties as late as my 1982 model Put the serial number in here and it will give you ...
  • Dates ' Winchester Collector winchestercollector.org/dates Serial Number. Get Manufacturing Date . Manufactured Date. ... History of Winchester; Winchester Model Information; When Was Your Winchester Made? Winchester ...
  • http://www.bing.com/images/search?q=winchester+model+94+serial+number+decoder&FORM=HDRSC2
    May 22, 2016 | Optics
    Can you tell me the year my Winchester Model 94 32 special was made? The serial number is 1380891. Thank-you
    Hello Mark
    my connection here doesn't permit weapons searches, but all the info is below.
    Serial Number info for Winchester Model 94 - The Firing Line Forums
    https://thefiringline.com/forums/showthread.php?t=322230 Nov 27, 2008 - 25 posts - ‎17 authors Serial Number info for Winchester Model 94 The Harley Nolden ... a rusted $50 tomato stake Standard Carbine, or a $10-20,000 Special Order ...
    Winchester Model 94 32 Winchester Special. ' Gun Values Board
    www.gunvaluesboard.com/winchester-model-94-32-winchester-special.-... My question is why is there so much variance from site to site on this model gun. I have one with a serial number 115,814. According to most sites that serial ...
    Winchester Rifles Modern Lever Model 94 Pre 64 For Sale ...
    www.gunsamerica.com/Search.htm?C=767 108 Listings - This is a pre-64 model, serial number 14375xx, and features a straight grip .... Winchester Model 94 Top-Eject Lever Action Carbine .32 Win Special ...
    Winchester Model 94 - Gun Collections Online
    guncollectionsonline.com/winchestermodel94.htm Winchester Model 94, Winchester model 1894, 30-30 caliber, lever action ... The post-64 Winchester model 94 begin with serial number 2,700,000. ... .22 magnum, .38 Special/.357 Magnum, .44 Special/.44 Magnum, .45 Colt (or .45 Long Colt), ...
    www.savage99.com/winchester1894_dates.htm Our database contains values of serial numbers through 5103248 which ended the year 1982. Our sources disagree a bit, but this seems to be the best set of ...
    Winchester Model 94 (.32 Winchester Special) - YouTube
    2q==? 7:01 https://www.youtube.com/watch?v=fNRDe5H--S0 Nov 24, 2013 - Uploaded by 88zukcrawler Short video of my favorite gun....the Winchester 1894 (94). Mine is a post 64 model (1972 year by the serial ...
    winchestercollector.org/models/model-1894/ .32-40 - introduced in 1894 ... .32 Winchester Special - introduced in 1901 ... As serial numbers approached the one-million mark, the official model designation ...
    Winchester Serial Numbers - ProofHouse.com
    www.proofhouse.com/win/index.html Model 1885 Single Shot · Model 1886 · Model 1892 · Model 1894 (Mod 94) · Model 1895 · Model 53 · Model 55 · Model 64 · Model 65 · Model 71 · Model 88
    Feb 29, 2016 | Optics
    Winchester model 74 serial # 11901, what year was that gun made
    My Internet at work doesn't like 'weapons'. These links will help you find the date.
    Model 74 - Winchester Dates of Manufacture
    oldguns.net/sn_php/windateslookup.php?file=winxx74.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 74: Covering numbers: 30890 - 406574. Please enter a serial number and click the submit ...
    oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. Lever Action Rifles. Henry Rifles · Model 1866 · Model 1873 · Model 1876 ... Model 1892 · Model 1894 (Mod 94)
    Winchester Model 74 .22 sr dating question ' The Firearms Forum
    www.thefirearmsforum.com/.../winchester-model-74-22-sr-dating-questi... Sep 8, 2010 - I have a Winchester model 74 .22 short rifle and am having a hard time looking up the serial number to date it. The serial is 22736. Winchester Model 74 22 Semi-auto Rifle 28 Mar 2014 Winchester Model 74 .22 Long Bore 6 Oct 2007 Winchester Model 74 3 Mar 2007 More results from www.thefirearmsforum.com
    Winchester Model 74 Value And Date ' Gun Values Board
    www.gunvaluesboard.com/winchester-model-74-value-and-date-158857... Nov 17, 2011 - Winchester model 74 value and date ... Posted on Winchester ... This is a barrel date of manufacture that is helpful in approximating the date of manufacture of ... Winchester 74 Serial Number 6694 Value 1 Jan 2016 1941 Winchester 22 LR Model 74 Serial Number 106978 15 Jul 2012 Winchester Model 74 22 Short 3 Jan 2011 More results from www.gunvaluesboard.com
    Jan 22, 2016 | Winchester Optics
    I need a users manual
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    Jan 09, 2016 | Cell Phones
    My model is zanussi easy iron washing machine capacity 6 kg spin 1400 ,my problem is that clothes are not getting dried, water remains in the clothes, what is the problem .
    Your washing machine has a problem with the water unless it is washer-dryer. Water remains in the appliance because drain pump is not functioning properly and laundry is wet.
    Dado
    Mar 16, 2015 | Zanussi Washing Machines
    Washing Machines Logo
    224 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
