Question about Maytag MSD2456G Side by Side Refrigerator
Bad Coil ?
Maytag Side by side MSD2456 DE - Bad Coil During the summer of 2006 our refrigerator stopped working on and off. It made a loud humming noise ending with a loud clunking noise and shut down. We had a repair man come out and he told us that the freezer coil was going bad and it would cost too much to replace it. He also mentioned that we should start looking for a new frig. He showed by husband the coil that was frozen at the top but as you looked downward it was not frozen. While we still have the frig, it continues to make this horrid sound on and off. We are now in the summer of 2007 and are afraid that it will stop working again because of the warmer temps. < >It is still very nice. We purchased it in 2004 and would like to sell it in order to buy a new one but we want to make and effort to repair it. Do you have any suggestions?
We just spent $389 to have the compressor replaced on our side by side. Cheaper than another $1500 for a new one. Plus, we got a 2 yr. warranty with the new compressor. better than the one year with a new fridge.... I would repair it. Also, while they repair the compressor, have them by-pass the yoder. They will know what this is, and shouldn't cost any more since they are already doing the compressor. We thought long and hard... should we but new or Fix. We chose to have it fixed and are glad we did. Hope this helps.
Posted on Jun 29, 2007
  • 35 Answers
The prob.sounds like a compressor prob.the motor in laymans terms.yes you probably would be better of shopping around now.before it totaly goes on you.comp.are more on the exp.side.
Posted on Jun 25, 2007
SOURCE:
Would dust cause my refrigerator not to cool
In a way, yes. Under the refrigerator is a condenser coil. Now, yes this coil collects dust. The more dust the less air can flow over this coil and that coil has hot gas flowing through it. Now this coil has to be cooled buy a fan. So, if it has too much dust, not enough cool air can pass over the coil, coil gets hotter and hotter. That causes the gas pressure to climb and the compressor will now get too hot. This will cause it to shut off due to a safety feature built into the compressor for just that reason, (to safe the compressor, your fridge, and your home from fire). Then the fridge gets warm inside, food thaws out. Yes, dust can cause this. It is very, very, common during the heat of summer, not so noticeable in the colder months. Hope this helps FixYa up.
Aug 16, 2011 | Maytag MZD2766GES Side by Side...
Maytag freezer does not work. it hums and stops
if you evap fan is not working this wouldnt produce any coldness,, or possibly it sounds like your compressor start realy is tryin to start but not working,,,
Feb 03, 2010 | Maytag MZD2665HE Side by Side Refrigerator
Have a Maytag MZD2766GES Side by Side Refrigerator, somehow it just stopped working. The freezer part is just a little cold but the other side is not cool at all. What can it be?
check the freezer compartment, remove the shelves remove the cover in the back if the condensing coil is frozen solid your adaptive defrost board or defrost coil is bad. a temporary fix is turn off refrigerator, defrost coil ( I used a space heater). turn refrigerator off . you will need to do this every third day until adaptive defrost board is replaced. to check defrost coil check with ohm meter It should have resistance. this website should give you the gory details http://www.appliance411.com/faq/howdefrostworks.shtml
Dec 15, 2009 | Maytag MZD2766GES Side by Side...
Model MSD2735GRB Refrigerator and Freezer stopped working yesterday. I can hear what sounds like a humming for about a minute, and then a contact making noise when they close, then the humming stops. Any...
The overload/relay , which is pluged onto the side of the compressor , is bad . The manufacturer part number is 12002794 . It is easily replaceable , with only 3 wires attached to it .
Nov 18, 2009 | Maytag MSD2454G Side by Side Refrigerator
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
MY GE Refrigerator-Freezer , model TCX20 motor is humming!!!
There may be a build up of ice in the freezer compartment and ice touching the fanblade. The unit needs to be defrosted.
Nov 06, 2009 | Samsung RS2630WW Side by Side Refrigerator
A side by side GE refrigerator with a loud hum
Hello Kchoffman73,
It sems we developed the same problem.
The hum seems to be coming from the bottom rear of the
fridge.
we have a GE side-by-side model TFX25JR.
The fridge is about 12 years old.
Whats the status of your fridge ? Did it ever stop
humming ? Did you replace or repair it ?
Does it still work ?
Thanks
Sep 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana/Maytag ACD2234HRS sometime not working
If your compressor is running with the noise you described, I would make sure the parts that were replace on compressor are working properly. Also use a amp meter and get a reading on amp draw while it is humming. Anything that is above normal readings for the compressor would indicate compressor is bad or the relay and starter are not working properly. I need a series number also like a number 15 before the model number, Thanks, Sea Breeze
Mar 21, 2009 | Maytag MZD2766GES Side by Side...
Comppresor stoped working
Go to the back of the machine and take the lower rear plate off. Taking this plate off will expose the compressor. Check to see the compressor is humming or is hot. If niether take off the relay (located on the side of the compressor) Shake it and if a loud rattling noise is heard replace it. If no rattling noise or the compressor is hot or humming then the compressor is bad.
Jan 15, 2009 | GE Profile PFS22 33" Artica French Door...
Maytag Side by side MSD2456 DE - Bad Coil ?
Karen Most likely the problem with you fridge is a bad compressor. The compressor is a part of the cooling (professionally called "sealed") system which included also the evaporator coil (the part your "repair man" called freezer coil), Freon and all tubing. This sealed system has FIVE years manufacturer warranty. You do not have to by a new fridge. Just call Maytag and they must fix it free of charge to you. Even if you do not have prove of purchase Maytag will go by the manufacturing date coded on the serial number. Good luck. Gendos. post back...
Jun 25, 2007 | Maytag MSD2456G Side by Side Refrigerator
Maytag MSD2456G Side by Side Refrigerator Logo
233 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
