Question about Gateway Computers & Internet
I used isoprophyl alcohol to clean the glass touchpad on my laptop and now there is a spot on the touchpad where it is not smooth to move around as the rest? PLEASE NEED SOLUTIONS!!!!
    New Friend:
  • 17 Answers
It sounds like the glass had some kind of coating to help slide your finger over it, and that coating has been removed by the alcohol. I don't think there is anything You can do about that, other than to replace the Touchpad. If you can live with the looks, you could try to put one of those "Screen protectors" for Smartphones which is a clear sticky-plastic sheet, that cut to size and applied could help you out if you don't want to shell out the $ for a New touchpad.
Posted on Jan 02, 2013
  • 1 more comment
  • Krista Perry Jan 02, 2013
    I don't think you are able to get a new touchpad for this kind of laptop... but could you give me a bit for description of what putting a screen protector on it would do, and what the feeling would be like and once I put it on would it be removal if I wanted to take it off? Thanks in advance.
  •  Per Jensen
    Per Jensen Jan 02, 2013
    Which make and model is your Laptop? The plastic sheet is just a protector your put on a Smartphone LCD to protect it from scratches in your pocket. It's just a sheet of self-adhesive plastic that You stick on. It's perfectly removable again, you just pull it off, leaving no residue. The sheet is glossy, so it should work fine on your Touchpad.
  •  Per Jensen
    Per Jensen Jan 03, 2013
    I cannot say for sure what is the best solution. Try putting on that protection film and see how it goes.
sandrew
  • 2961 Answers
SOURCE: touchpad on laptop
You should have a little icon in the right corner of your taskbar, right click on the touchpad icon and click enable.
If that does not work, right click on my computer icon,properties, hardwrae tab, device manager, look down list for mice and pointing devices, click on the + sign, select synaptics(if that's the make) and select uninstal.
Restart laptop and the drivers will automatically re install and should work as normal
Posted on Nov 20, 2007
  • 3 Answers
SOURCE: power cord
Happened to me, I just bought A new cord
Posted on Dec 27, 2008
  • 40 Answers
SOURCE: touchpad right and left clickers womt work
this is due to the driver missing or uninstalation of the touchpad you must try to reinstall the driver again.
for any harware problem you can check the status in
DEVICE MANAGER present in CONTROL PANNEL(WINDOWS VISTA)
for
WINDOWS XP you can search this application in windows search.
Posted on Apr 21, 2009
kevin000
  • 1847 Answers
SOURCE: Problem with my laptop cursor or touchpad
The first step that you should try is to reinstall the touchpad drivers.
Still no good reinstall the OS,
Still no good replace the touchpad.
Thanks
Kevin
Posted on May 27, 2009
  • 1019 Answers
SOURCE: Can move the mouse but not clikc with the touchpad
if you installed an external mouse, it would over-ride the touchpad.
try removing the external mouse, and tap the touchpad twice as if you were double clicking it.
also you could try re-installing the touchpad device driver, usually synoptics or similar.
Mike @ compurepair.
Posted on Jun 11, 2009
My cursor keeps jumping and moving the letters in my emails.
Step 1:
If you are a frequent user of a notebook or netbook computer, then you likely use a touchpad to navigate your computer's on-screen cursor. However, there are a number of issues that can cause your cursor to seem jumpy or unresponsive. To find what is causing these issues, you can troubleshoot both your hardware and your operating system and find a solution to the problem.
Turn your computer off and then clean your touchpad. Dampen a clean cloth with some isopropyl (rubbing) alcohol and then pat the pad dry with a paper towel. Even a small stain or sticky spot can throw off your touchpad's sensitivity, so it is vital that the pad remain clean of all extraneous substances. Re-calibrate your touchpad. Go to the hardware section of the "Mouse" utility (in the Control Panel) and find the device settings. There should be an "Advanced Settings" or "Calibration" utility under this tab. Follow the prompts to calibrate your touchpad for maximum efficiency. Use manual troubleshooting wizard. If you suspect that your computer's software or drivers are at fault, run the manual troubleshooting wizard. Go to the "Mouse" utility (in the Control Panel) and then go to the "Hardware" tab. Select your touchpad and then click on the "Troubleshoot..." button. Follow the prompts to troubleshoot software issues that could make your touchpad jumpy. Reduce cursor speed. In the "Mouse" utility, go to "Pointer options" and reduce the speed. This will prevent the cursor from going too fast when you move your finger on the touchpad, which could be the source of the "jumpy" effect.
Feb 15, 2013 | Toshiba Computers & Internet
Jumping cursors and letters
Step 1:
Feb 15, 2013 | Toshiba Satellite Computers & Internet
My cursor moves around but to get any where or scroll I have to left click every time
Enter your control panel from the START menu select CONTROL PANEL open it scroll down to mouse and adjust settings there.
Apr 07, 2012 | HP Computers & Internet
We have an LG DVD DR7621W and it keeps telling us no disk although we have put a disk in.
try to insert other disk, make sure the file format with in the dvd that you use is applicable to the dvd player if not it will not recognized.now if still other dvd's doesn't read try to clean the optic sensor with cd lens cleaner might be dusty.another way is manual cleaning with the use of smooth cotton buds with isoprophyl alcohol wipe the optic sensor do this gently not to damaged the optic sensor. good luck hope this will help you.
Jul 18, 2011 | LG Televison & Video
Model: PSR 620. The floppy drive is not working and needs to be replaced. Original floppy drive uses DS DD 720kb floppies. Where can I get a replacement drive? How much does it cost?
The replacement cost of these is prohibitive often greater than $200.
You should try to clean the heads in your drive and see if you can spot a mechanical problem. Clean the heads carefully with 91% isoprophyl alcohol and Tube Gauze on a tongue depressor. Be very careful.
Aug 09, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
MY Yamaha psr 550 stopped giving sound after cleaning its buttons inside but the beats and other parts are working properly.only the keys are not giving out sound.please tell me how to fix this...
When cleaning buttons HOPEFULLY you did NOT use DeOxit or other contact cleaners like Blue Shower as these can damage the buttons that are conductive rubber.
The conductive rubber buttons should ONLY be cleaned with 99% isoprophyl alcohol and Q Tips. Both the conductive "pill" and the traces they contact on the circuit board should be gently cleaned with the Q Tip wetted with the alcohol.
If you used anything but the 99% isoprophyl alcohol, you can TRY cleaning properly and hopefully they will not have permanent damage.
Jul 15, 2010 | Yamaha Music
Couple of keys dont respond well and I tried cleaning pad under keys
The conductive rubber pill contacts AND the traces oin the circuit board should be cleaned with 99% isoprophyl alcohol, nothing else. Use a Q-Tip moistened with the alcohol.
Jan 28, 2010 | Roland Juno-D
How to clean screen on laptop ,buildup of dust and spots on screen
There are LCD screen cleaning products. You can use a soft clean cloth moistened with water and a little alcohol. Wipe the screen with light pressure. Do not apply heavy pressure to the screen, it can crack the glass surface.
Oct 25, 2009 | ASUS P20 Black, Ms Vista Home Premium,...
A black streak appears on faxes that we send and on our confirmation page. How do I correct?
If you mean that the receiving party is telling you your fax has lines, then the problem is the scanning glass. Depending on the make and model, you should be able to lift the paper feed assembly on a hinge. If you look inside you'll see a long strip of glass that scans the paper. Chances are that you have specks of white-out or pieces of label stuck to this glass. Clean it carefully with a soft kleenex dipped lightly in either isoprophyl alcohol or Windex. Wipe carefully along the length of the glass, back and forth, until all debris and other stuff is cleaned off the glass. You should be good to go!
Aug 28, 2009 | Brother IntelliFAX 4100 Laser Fax
Computers & Internet Logo
57 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
