My friend dropped my Hard Drive and it wont work any more. What do I do?
My friend dropped my Buffalo HD-LBU2 Hard Drive and it doesn't work anymore. when it is plugged in to the power point the green light comes on for about 30 seconds and you can hear it is working but then the whole thing turns off. The computers wont pick it up and i have all my work from the past 2 years. What do I do? NEED HELP!!
  • 32,281 Answers
Hard drives are easily damaged by dropping them onto the floor. There is nothing you can do to fix this hard drive.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services. The reason for this high cost, they dismantle and remove the platters in the hard drive in a clean room environment and set up the platters up in jig/drive to retrieve/copy the data.
Posted on Jan 02, 2013
4 Suggested Answers
Flat48
  • 77 Answers
SOURCE: Hard Drive dropped and not recognized by the computer;
Bad news is, it sounds bad. Good news is, you can take drive to local shop and have the data recovered at a reasonable price. As for me I like Digilink. You should get a agreement with whomever you choose that, if they don't recover anything you don't pay, or at least a fixed price. More than likely they will be able to recover whatever is on there. Above all go to a reputable dealer that has been around a while and will be there next week. Good luck.
Posted on May 22, 2009
Crankstart
  • 696 Answers
SOURCE: buffalo drivestation 500 gb wont start
Certainly we can help,
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 09, 2009
bob_computer
  • 3153 Answers
SOURCE: Lacie Hard Drive won't connect via USB anymore
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
DO NOT PLACE IN A FREEZER !
THIS IS VERY OLD ADVICE FOR VERY OLD TYPES OF HARD DRIVES THAT ARE NO LONGER EVEN MADE. A FREEZER CAN CAUSE MORE DAMAGE.
Posted on Sep 26, 2009
How to access my Buffalo HD-PNTU3 external hard drive?
dropping it while turned on is fatal as it usually damages the write heads and/or the platters.
if it hit the floor, changes are it's physically damaged the mechanism.
recovering data from a drive with this damage is not cheap as you will have to send it away to be rebuilt. It's impossible to rebuild it yourself.
Feb 21, 2016 | Buffalo Technology Buffalo MiniStation...
Error code 127
What does the manufacturer's information say a code 127 is? We need to know that to give you any help. What did they try to fix already?
Jul 21, 2014 | Buffalo Jeans Buffalo 1.5TB DriveStation...
Transformer in buffalo hd-lbu2 external hard drive working but no power in the unit
Well that is a pickle. If there is no warranty left on it you can allways try to open it up a bit and check with a geiger if the juice is running through it.By Geiger i mean a voltmeter
.http://www.youtube.com/watch?v=T1BT5kw6sqY that should help a bit and if the connections are good you might wanna get yourself one of theese
http://www.amazon.co.uk/Buffalo-HD-LBU2-External-replacement-adaptor/dp/B007FI1PH2
Oct 20, 2013 | Computers & Internet
Buffalo HD-LBU2 not reconised by computer
Try a drive dock on the Removed Hard drive. The usual problem is the enclosure.
Apr 12, 2013 | Buffalo Technology DriveStation HD-HC500U2...
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Jan 01, 2013 | Buffalo Technology Buffalo MiniStation...
My buffalo ministation 3.0 external hard drive wont be recognised by my comuter. to be honest i dropped it, but when i plug it into computer green light starts flashing, after a while fashing stops green...
My ministation was doing the same, beeping and flashing green light after a light drop on the floor. Soo... I took my ministation usb drive out of the plastic enclosure and smacked it on the table a few times. Plugged it in and it spun back up!! Now my computer recognizes it and everythings working smooth! I assume something with the drive became jammed and the couple smacks loosened the drive head.. Anyway, if all else fails... beat it!
Nov 05, 2012 | Buffalo Technology Buffalo MiniStation...
Buffalo ministation hd-pct500u2 won't allow me access to it
Go Here
And you will have to download the CD image and then burn it on to a disk. This would possibly be why you can't see it in your device manager because it doesn't know what it's looking for and how to run it. by downloading, burning it, and then installing it. The computer will then know exactly what the peripheral is and how to recognize it and run it as a hard drive. I sure hope this has helped.
Thanks, Cody
Sep 13, 2012 | Buffalo Jeans Buffalo MiniStation...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
My buffalo external hard disk can not read since yesterday, I/O device error. previoous was working fine. Do not know why? my Buffalo external hard disk model :HD-PX320U2
it is a PNP (PlugNplay) device. Try using a different cable to connect to your pc. Should the problem remain, hook it up to a different computer and if it doesn't see the drive, it will be an electronic circuit failure inside the box. The data is still on the hhd but you will have to obtain a new circuit to bring the hhd back online for use.
Apr 13, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
Computers & Internet Logo
189 people viewed this question
David Payne
David Payne
